November 23, 2024, 05:38:39 am *
Author Topic: iPad connection problems anyone ?  (Read 5006 times)
« on: July 15, 2016, 09:42:55 am »
On behalf of a user I'd like to know whether someone ever had the problem of not being able to use the iPad directly for Remote, but solved it (and then with the question of How).
With "directly" I mean :
iPad -> WiFi -> Router -> LAN Cable -> Audio PC (where XXHighEnd runs).
A property of the problem is that the connection works in Normal OS but not in MinOS.
I just tested it myself and all is fine here. So now I'm hoping that any one had similar but was able to solve it ...
Thanks !
Stanray
« Reply #1 on: July 15, 2016, 01:05:56 pm »
For a short time a had the connection this way (before I started using the Music Server PC) and I recall I had a similar problem.
I'm not sure, but I think it did work when I made the connection in MinOS directly (and not in Normal OS and then to MinOS - which  didn't work).
But it was some time ago  scratching so not really sure.
Stanley
