April 05, 2025, 01:39:37 pm *
Author Topic: RAM OS Disk - Upgrade 10565 TRIAL  (Read 31269 times)
« Reply #15 on: July 20, 2016, 02:16:41 pm »
Juan, leave all to default when using the DVD DownloadTool.
(I can't even imagine that it asks for that and if not indeed, where you get your question from Happy).
I got it from Robert´s isotousb.com, there it asked for the file system but anyway I´m going to try first the DVD downloadTool.
PS after this installation I´ll go for the 2.06a upgrade, we´ll see... scratching
« Reply #16 on: July 20, 2016, 02:42:29 pm »
The DVD DownloadTool is from Mr Windows himself, so it should work (haha).
But as said elsewhere : run it on a 64 bit system or otherwise nothing works and you won't see/undestand why (it needs additional stuff then).
« Reply #17 on: July 20, 2016, 02:47:52 pm »
Here in my laptop with W10 64bit the DVD DownloaTool doesn´t work. I used instead Robert´s isotousb.com and all is ok and now I have the bootable USB.
In a while I´ll proceed to the upgrade  Cool
« Reply #18 on: July 20, 2016, 03:52:22 pm »
Can you tell ... why does it not work ?
« Reply #19 on: July 20, 2016, 06:05:41 pm »
Why?, I don´t know, the first time it looks that there wasn´t enough free space in the USB key (15GB free) but the second time the message was the same.
« Reply #20 on: July 20, 2016, 07:47:24 pm »
Peter, the upgrade was made correctly. I changed the date in the bios previously as you said. In fact I didn't touched it because it was January 2016. After I finished the installation the date changed to July /09/2016. Is that correct? Otherwise all seems to work perfect.
« Reply #21 on: July 21, 2016, 08:20:40 am »
Hi Juan,
Great that it worked out.
If you don't use 10074 you can set the date to "today".
Might you ever again want to try 10074 or 10565 (BASE or RAM) you can set the date to Sept 2, 2015 for both.
« Reply #22 on: July 22, 2016, 11:30:26 pm »
Hi
I ran into the same adversity as Juan and solved it the same way (with IsotoUSB). Patience is a virtue that is being called upon. Putting the ISO on my USB took as much time as the Win 10 update. It seemed to last forever but it actually was "only" 70 minutes.
Note that I had to reboot another time for the UAC thing.
Now I can start my vacation in peace!
regards, Coen
« Reply #23 on: July 23, 2016, 08:25:18 am »
If all is right the USB device will be erased completely anyway. Maybe it did not ? (you're asked questions about it by the program)
Something else is that think I see that you used Windows 10 for it - is that right ?
Coen ?
If so, maybe that is the problem and that by now a newer (working) tool exists. I always apply it on a 64 bits (!!) W7 machine. Takes maybe 3-4 minutes ...
Coen, enjoy your vacation !
« Reply #24 on: July 23, 2016, 09:49:22 am »
Peter, I answered all the questions and even I formated previously the USB key, so the problem must be when using W10 instead W7.
« Reply #25 on: August 13, 2016, 10:21:41 pm »
Before adding the new Win 10 build 14393.0, I took the opportunity to switch from W10 build 10565 to !0 build 14388.
All went fine, but I accessed regedit at the end to change UAP with the value from 1 to 0. I used the instructions you wrote here: http://www.phasure.com/index.php?topic=3680.msg39255#msg39255
PS: I also used isotousb (tried again DVD DownloadTool with no success).
« Reply #26 on: September 06, 2016, 11:32:47 am »
All,
I added this to the first post in this topic :
Edit Sept. 6, 2016 : When there's a "3" written on the green sticker, it means that you have a version with W10 14393.0 installed on it plus this 14393.0 and also 10586.0 have been adjusted for OS Timers set for optimal SQ when the OS is booted from RAM. Notice that from of XXHighEnd 2.07 this can be set by XXHighEnd.
W10 10565 BASE + RAM now have been removed. Notice that the screenshots more below do not reflect this.
