November 23, 2024, 01:40:11 am *
Author Topic: Strange problem with xxhe pc  (Read 20043 times)
jhmvl
« Reply #15 on: July 14, 2016, 11:31:21 am »
Yes, problem solved indeed. I had to change a lot of settings but now it works again.
There is still one strange issue left though and that is the following: in the bios I can only select if the computer boots from
1 - the 3.5" bay or the DVD, or
2 - the 2.5" bay or the DVD.
For some reason that I do not understand yet I cannot get it to boot from all three (not all three at the same time of course, that is not what I am trying  innocent ). In the boot order I can only pick the DVD and the 3.5" bay or the 2.5" bay even though I just cannot select that.
I checked the bios manual for this, but from that I understand that it should be able to do it, but no...
The reason I wanted this is because the 2.5" disk that contains win8 gives me a boot error that I thought I could fix when I booted from the 3.5" bay and then fix the 2.5". But that did not work. When I boot from the 3.5" harddisk I cannot even find the 2.5" harddisk in the explorer (or the dvd for that matter), so although the computer works again, there is still some strangeness going on.
Hans
« Reply #16 on: July 14, 2016, 01:31:34 pm »
Hans,
The problem you may have now, could be solved my means of reading the text under the second picture (and up to where the list begins) in this post :
Operating System Upgrade XXHighEnd PC
What it's really about is not supported by pictures, but maybe you can make something of it.
Let me know if it helps you,
jhmvl
« Reply #17 on: July 16, 2016, 09:21:30 pm »
Have been playing around with it, but if I understand this correctly I can not set it up so that the 3.5" disk and the 2.5" disk are bootable (where boot order would be set so as to boot from 2.5" first of course since that is the ram os)? I can only set it up so that it either boots from 2.5" or from 3.5". Is that interpretation correct ( a bit annoying if it is, but hey, so is life I guess  smile ).
Hans
« Reply #18 on: July 17, 2016, 09:56:58 am »
Hey Hans,
I wouldn't know why that whould be so, but some times I wonder myself. So yesterday, coincidentally, I wanted to boot from the removable 2.5" (with the normal OS HDD inside of the PC) and I could only exchange it. This looks like your issue. Btw, this exchanging thus goes with the "Hard Drive BBS Priorities" under that large white arrow denoted "See manual" in the second screenshot here :
What you also need to know is that a new SATA connection (which would be the same as inserting a bootable HDD in the removable bay) rearranges (read : destroys) your set boot order. This always has been so with SATA as far as I can remember. So this already makes in unmanagable (in my view) when you have one boot device and add another temporarily. Maybe this is related to these HDD BBS Priorities - I don't know.
jhmvl
« Reply #19 on: July 17, 2016, 10:40:48 am »
Yes, this is exactly the same issue. I guess we will have to live with it.
Hans
