April 02, 2025, 09:28:11 am *
Author Topic: New PC, new sound  (Read 33076 times)
« on: July 02, 2016, 11:40:31 am »
Hi all,
After the crash of my music/audio PC, I took the opportunity to upgrade to the -old- XXHEPC. I haven't found the time yet to properly install all options like the music/audio pc devision or RAMDisk yet already the sound is in another universe.
I should have done this earlier :very happy:!
I'm also happy forum stuff is now making sense. even the intona is much more of an improvement than I experienced with my other PC.
Connected again!
regards, Coen
« Reply #1 on: July 02, 2016, 01:17:26 pm »
Ha !
Well Coen, I have been waiting with some excitement for such a message and am very glad I could help you with it (as how it turns out).
For others :
We spend a day with quite some hours to show that with today's Windows 10 nothing much is wrong. However, it didn't last long before we (both) started to seek new XXHighEnd settings (I forgot the reason, but maybe you still know, Coen ?).
What actually happened was the spending of a quite large amount of time on comparing settings which in the end resulted in a change from :
Q3,4,5 = 1,1,1 with Q1 of 14 x1 and SFS = 0.11
to
Q3,4,5 = 0,1,0 with Q1 of 14 x10 and SFS=120
(the 14 x10 and SFS=120 part I actually already set earlier on)
Later I also changed the Custom Filter from Low to High (2nd one) and this is what I am still happy with.
Careful : this is for the Stealth LPS PC and does not tell much about other PCs. However, I already heard from a customer with the "old" XXHighEnd PC that the settings work for the better for him too, except for the Custom Filter change.
To be clear : this is with XXHighEnd 2.06 (or 2.06a).
Anyway ... I don't recall that I ever payed to much attention to changing settings, which possibly happens already because two hear more than one. Funny thing is (well, for me it is) that actually super small changes like Q 3,4,5 = 1,1,0 to 0,1,0 are enormously audible and actually we had a great time in tuning the S'es together with the best basses. And about two hear more than one : I really needed Coen's remark that at a certain setting voices were not present any more and with the flip of a button they were back.
I hope you will be having fun again with all !
« Reply #2 on: July 02, 2016, 02:47:39 pm »
If I recall correctly the different SFS had to do with the Silverstone being disconnected or maybe it was you who just wanted to compare with an older favorite. Doesn't matter, I had a great and very educating day in Oene! It was clear that the system was enormously responsive to any change in setting or configuration and that it sounded superb with the right ones.
One thing that still echoes in my mind is the impact of the B'Ass being on or (half?) off. On it lifts the sound spectacularly, everything gets much clearer en a certain poise or swung is added that makes the sound extra believable. Imho it could not save Windows 8, but that is another matter  naughty.
Thanks again for your hospitality and the listening opportunity!
Now let's see how far I can get with my system... Happy
regards, Coen
Robert
« Reply #3 on: July 04, 2016, 05:18:08 am »
Trying these new settings in my setup certainly improved the sound, even going to the High filter setting for my setup helped(174/192). I have swapped back to Mobo USB3 this has always been good sounding somewhat smoother than the Silverstone. More listening required to see what is better Silverstone or Mobo.
Hires files play complete albums at 120 SFS.
Robert
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #4 on: July 05, 2016, 03:21:00 pm »
One thing that I have not clear yet is if using the mobo USB3 requires to connect the ground in the NOS1a. Could someone clarify it?
« Reply #5 on: July 05, 2016, 04:52:00 pm »
Hi Juan,
My personal answer is similar as always : I still have the famous black wire disconnected - this time because the Intona is causing the isolation.
Anyway I have it running like this for 4-6 weeks (I forgot) and all remains to be OK.
« Reply #6 on: July 05, 2016, 04:59:27 pm »
Thanks Peter I'll try it
« Reply #7 on: July 06, 2016, 03:04:59 am »
Hi Juan,
I probably have it wrong but I thought that turning the 3rd swith ON on the NOS1a was similar to detaching the ground wire from the NOS1a USB ?
« Reply #8 on: July 06, 2016, 10:44:01 am »
Alain,
If you consider that On is always "connect something" plus the knowledge that our personal On's are always down, The On/Down is thus to connect the (ground) wire.
« Reply #9 on: July 06, 2016, 12:21:33 pm »
Wink
« Reply #10 on: July 07, 2016, 12:39:37 pm »
I've been testing the sound without the Silverstone card and  I found a sound with more  presence and with the highs a bit smoother.  But most of all it helped me to look for better settings as it's easier to tell the differences. That could be a good sign that's better to connect the dac, or the Intona, directly to the mobo USB3.0.
Robert
« Reply #11 on: July 09, 2016, 01:40:39 am »
Juan,
Yes I found the same with Mobo USB input. Although I did say the silverstone sounded better I did have problems with the Silverstone USB dropping out on occasions(fixed by reinstalling usb software) and going back to Mobo always sounded very good.
The more I listen though with new settings(xtweaks, SFS, Custom Filter) xx206 and Mobo USB input its definitely an upgrade in sound.
This is a lot of changes in a short space of time. I will listen longer then go back to original. I won't be changing xx206 though.
Has no one else tried the new settings????
Robert
Oppo 205 UDP Dac
phantomax
« Reply #12 on: July 09, 2016, 10:14:26 am »
hello Robert,
Yes I tried and, although I can't go up to SFS 120, with SFS 46 the SQ is the best I've never had.
Recently I mounted a poor's man version of the XXHE PC.( Asrock Z97M pro, i3 4170) Peter's offer was a great deal but my (auto) limited budget didn't allow me go for it (austerity syndrome I'm afraid  Old)
So many changes in a short time too but the result is fantastic.
Maxi
« Reply #13 on: July 09, 2016, 02:48:57 pm »
Robert
Hi Robert, yes I tried it and with those settings the sound is very well balanced although I like it more with the Low filter or even with the High 4.14% than with the High 3.72%,  I find this last one a bit disturbing, it's like if I'd need to down the volume at least one step.
Actually there are endless possibilities and many of them sound wonderfully, for example Maxi's one.
For me the last and best discovery is that the sound is better without the Silverstone card. Now looking for better settings seems to be easier.
« Reply #14 on: July 10, 2016, 12:13:34 pm »
Definitely I like very much the new Peter settings: Q3,4,5 = 0,1,0 with Q1 of 14 x10 and SFS=120. My preferred filter is the High 4.14%. In a few days if I still think the same I'll update my signature.
