November 23, 2024, 08:08:20 pm *
Pages: [1] 2 3  All
Author Topic: Vista users, again, prepare yourselves ...  (Read 50461 times)
« on: February 04, 2008, 09:08:08 pm »
Dear world of music lovers,
The upcoming 0.9u version(s), dedicated to say, bit manipulating like 24 bit playback from 16 bit versions, will have a high surpise for you all; yes
In my pursue of 24 bit playback, I found something that comes down to applying the same principles as a non oversampling DAC, but in quite another area. If my theories and my ears tell me right, it will be a revolution in playback of digital sources. grazy
Ok, you might say I dare to challenge myself to anounce this kind of prematurely since I'm listening to various kind of music right know to prove my theories right, but let's say I want to be those theories right. You can always call me crazy afterwards.
I'd like to be this propriatary for the time being, but *if* I'm right it would be a kind of revolution. Could *I*, me, myself and I incur for that ? innocent
This really is up to you. swoon
I say : what I found surpasses the influence of jitter (by far).
Until I put up the first 0.9u version, I'd really like you to prepare yourselves and (with Engine #3) play particular tracks and pay extra attention to :
1. Clarity;
2. Spatiousness (not to be confused with fuzzyness);
3. Being there with the music without compromise;
4. Dynamic response;
5. How deep your bass goes;
6. The tinyness of PC playback (which often is a problem, depending on many things in the chain);
7. The balance between the loudness of cymbals and the other instruments;
8. The balance in general between frequencies, the possible unimportance of varying that balance (if you can at all) and standing waves (not only the lower frequencies, but also annoying unequalities of higher notes);
9. The SQ at various volume levels of listening.
Please note that any implied "negative" is to be hold against the recording as far as you can interpret that. Also note that a "good" recording not necessarily gets the best out of everything and "good recordings" often boost low frequencies and only sound good to our commercial ears. General boost ("loudness") can also give additional problems with 0.9u, I think. Also. I may imply only positives in any of the phenomena above, of which at least not all are positive (to my own judgement).
Anyway, since I cannot be 100% sure about the result being better than everything existing on this world so far, I like you to be as honest as possible. Ok, for now this means "preparing" at listening to the various phenomena I indicated, as long as it takes to get a decent idea of judging the upcoming 0.9u. I can promise you it will be so different that without decent preparation you will be confused and keep on A-B'ing without clues; All fits or it just does not. Either way I'd be very glad to know.
Before you (and I) forget : it is my advise to try 0.9u with Q1 at 14 as being a rather neutrally jitter influencing setting; At your first judging just leave it like that (14). Leave your soundcard buffer settings (if applicable) at where you had them.
Thank you !
« Last Edit: February 05, 2008, 01:45:15 pm by PeterSt » Logged
xp9433
« Reply #1 on: February 04, 2008, 10:35:38 pm »
Dear Peter
This sound both tantalising and highly exciting!
I assume it only applies to play back through Vista?
Frank
« Reply #2 on: February 04, 2008, 11:41:04 pm »
Yes Frank, it does. Engine #3 only.  this
Leo
« Reply #3 on: February 05, 2008, 08:58:41 am »
It will arrive shortly I presume ?
PLEASE !
« Reply #4 on: February 05, 2008, 10:44:53 am »
Uhhmm ...
I hope I did not suggest that 24 bit playback would be available in the first 0.9u version. It certainly will be not. nea
As I indicated earlier and elsewhere, it appears that Vista Exclusive Mode just doesn't allow it. I've been again working on it over the weekend, to no avail on this moment. Now, the most sad thing happened :
I anticipate Vista/SP1 having solved this, although I must say that there is no real indication for this on the Net. So yesterday just before I created this topic, I got myself the link to the download of Vista/SP1 RC (Release Candidate). Then I wrote this topic, had some dinner, and sat down to download SP1 RC. To my surpise the download just had been removed (and I've been looking well over 2 hours to find other live links) and now it's waiting to half of March at least for SP1 RTM. Or one or two months longer depending on the language you need.
So there went my kind of last hope for the being nearby of 24 bit support. swoon
Anyway, this topic wasn't about 24 bit support but about the "technology" I applied in the upcoming 0.9u-0. In order to get it up definitely I have to solve one relatively small problem, and I want to have another listen tonight first to be more sure. But if all is right it's worthwhile some waiting for sure.
PS: But if someone has a link to Vista/SP1 RC (not a beta !) for me I'd be very happy to download it and proceed from there for the 24 bit quest. Note that AFAIK it would not be illegal to provide such a link from e.g. your own server. There has been a December 17 (2007) version and a Januari 13 (or something like that) version. Either will do.
« Reply #5 on: February 05, 2008, 12:15:22 pm »
Did you have contact with Microsoft about this bug? I'm afraid the soundsystem is not their highest priority, and if they don't know the problem ...
I checked for the SP1 update, seems only to be a registry entry which starts windows update. Maybe somebody can give you a complete image (not me, I'm sorry for both of us, even I have a dutch vista  Cry Cry)
Will your revolutionary update work without exclusive mode ????? unhappy unhappy
« Reply #6 on: February 05, 2008, 01:12:41 pm »
I think so yes. At least I got Shared Mode running in my Exclusive Mode "capable" system. The more difficult point is that I can't test it in a "not Exclusive Mode capable" system. But now I recall ... you just *have* it running in non-Exclusive Mode, right ? Well, then it will work.
No. But it would be without use. All people asking questions in this area never get any answers. Man, I must have been very lucky I got the base of it running ... which officially it could not in the original Vista RTM. So I put my horses on that now (SP1) it officially can, and one of the reasons it could not before was that not everything was supported in the kernels. Another indication that it just wasn't finished (which nobody admits of course) is that I receive an error message number which is not in any list. So that's where I got stuck last Sunday, but now I will proceed on getting the message behind that number (no, Google never heard of it Happy).
« Reply #7 on: February 05, 2008, 02:39:27 pm »
All very interesting.
I will see if i cand find a vista SP1 RC for you to download.
andy74
« Reply #8 on: February 05, 2008, 03:44:23 pm »
Guys HELP !!!
I would like to join your exciting expectation of the new version.
But I don't understand what is this all about. Probably my poor English again. unhappy
Can anybody explain to me what are we waiting from 0.9u and most importantly what is this BIG CHANGE? from the technical point of view.
if it is not 24 bit playback then WHAT?
I am completely confused!
Thanks
Andrey
« Reply #9 on: February 06, 2008, 09:16:19 am »
oops When I was ready last night with typing and all to post the upgrade, all the connections to the server concerned were dead (you probably noticed it too). No, I carefully saved my typing this time. Later today I'll have another attempt.
« Reply #10 on: February 06, 2008, 11:30:44 pm »
And did your attempt succeed?
« Reply #11 on: February 07, 2008, 10:42:48 am »
Hahaha, what do you think ? nea ...
No, yesterday I gave myself the freedom to get 24 bits working in the mean time, and after a whole day of trying I indeed got it working, BUT, with Shared Mode only. Note that so far this works with native 96/24 files only, and *not* with upgrading 44.1/16 to 44.1/24.
A kind of major problem as of now, is that I am starting to adopt the idea that this is caused by my RME drivers and not by Vista. Today I will ask RME about it, and knowing how responsive they are, I expect some result from that soon. If it's them, even the solution might come soon.
Of course this is -then- related to me only, and not necessarily to "you". The breakthrough however, is that I *do* have a working situation now which I can apply theoretically to Exclusive Mode, so then it just might work for "you".
Since I have been messing the program all over yesterday, currently I have to get things back in order first before I can upload an upgrade. This time I better say "maybe not today", but I will try anyway.
On the danger of getting too much off topic (as how it seems, but it is not ! Happy here's a premature "advise" on how to deal with Shared Mode and the means how XXHighEnd plays the audio stream (which is *not* equal to anything else !) :
As soon as Exclusive Mode won't work (and I think this is your situation with the Terratec, GerardA) there must be a strict match between what XX outputs and what is set as rate/bits in Properties - Advanced of the audio device. If not, the message "Sample rate does not match ..." is given by XX.
One really major problem coming from this, is that it would be quite impossible to play various rates/bits in a mix without adjusting those properties all the time. Thus, supposed 44.1/24 could work, then when the properties are set to that, a genuin 96/24 file can't play. And the other way around. Keep in mind : this is only when Exclusive Mode is rejected. Thus, suppose that 96/24 can normally work in Exclusive Mode (like 44.1/16 can), and 44.1/24 can not, then there is no problem because you can set the properties to 44.1/24 and all is okay all time. Uhhm ... mind you, NOT when you also want to play a movie which is always 48/16 but ... which might "resample" to 44.1/24 then.
To get the merits of it all (and I hope I understand it a bit by now), as said, keep in mind that only the way XX plays REQUIRES that exact setting when it plays in Shared Mode (for "why ?" see below). Thus, supposed the properties are set to 44.1/16 and you play this movie of 48/16 there is no problem. Vista will resample that to 44.1/16. Okay, if you don't call this a problem ...
Why does XX require the exact setting ? because otherwise the same will happen as with the movie example. You insert that e.g. 96/24 file, and in the mean time Vista makes 44.1/16 of it (or whatever the properties are set to) ... and you wouldn't even notice it (but for poorer sound of course).
An in fact very important thing is that you *must* be able to see the playback rate and bits as output by Vista. So, I can imagine that a lot of you just can't, but if you indeed can't you will not be able to check whether your - and XX' settings work out as intended.
In my case the RME driver (screen) can show the samplerate, but not the bits. And mind you, those too get "resampled" if Vista likes it (Shared Mode). Ok, IOW, if you could find software that shows what's really output to the matter of rate and bits ... please let it know.
In the very end it is not all that much important, as long as we can trust the messages from XX. Thus, as said, when XX just rejects a non-matching rate/bits then it wouldn't play anyting you did not intend. Right ?
Apart from a messy program, currently it is my task to find out my the most "structured" means, what is and what is not possible, in order to show you the appropriate message. So this is something I have to do too now.
Last thing : As far as I can determine, playing in Shared Mode under the restriction of Vista (the soundcard) playing the rate/bits as requested, does not harm the bits. I did not check the output with the source, but my interpretation of all tells me it whould be ok. But :
For those who pursue that 96/24 (or possibly 88.2/24) I personally don't think it is better for SQ. Why ? well, because it would need an inheritently worse DAC to play it. In my case it would be the 96/18 TwinDAC+ vs. the 192/24 Fireface800, and no matter the Fireface is used at 96/24 vs. the TwinDAC+ at 44.1/16, the TwinDAC+ wins. Or I must have picked the wrong Linn examples ... which I don't think is so. And of course *I* must add to it : any 24 bits DAC will be an oversampling DAC. For me this is good-bye to good SQ.
On the other hand ... you will soon see why the being able to playback those 24 bits is important afterall. grazy
Leo
« Reply #12 on: February 07, 2008, 11:11:55 am »
The Altman DAC claims to do non-oversampling up to 192 kHz  Happy.
It is way beyond my knowledge to say whether that is bluff or true, nevertheless if it is true you are in for another challenge Peter
« Reply #13 on: February 07, 2008, 01:11:01 pm »
Hi Leo,
No ... no challenges here. The sample rate isn't the problem. The problem is the bit depth. Similar to the Altman allowing for 192KHz while it is 16 bits only. 16 bit non-oversampling DAC-chips just exist, 24 bit nos chips do not. So a first "problem" would be that e.g. 96/24 files just cannot be played with the SQ I myself have in mind. A derived "problem" is, that files with 88K2 and higher, in 16 bits just do not exist (which is perfectly logic). In the end, any 88K2 and higher DAC not being able to use 24 bits at all, is a kind of worthless. E.g. what Altman provocates is that DVD-A can be played because of that 192KHz. Sadly DVD-A's are not in 16 bits. So the bits will be just cut off implying not only a lower resolution, but noise as well. It just doesn't work (with such a simple approach).
In the near future you will learn more of this. Just watch these pages ...  Happy
« Reply #14 on: February 07, 2008, 05:31:57 pm »
Got it working for Exclusive Mode now too. Even padded to 32 bits ...  Happy
Pages: [1] 2 3  All
