November 23, 2024, 06:02:48 pm *
Author Topic: XX HighEnd-206 doesn't start because of Active X message  (Read 29035 times)
« Reply #15 on: June 28, 2016, 10:52:34 pm »
I had the same problem here but so far it's solved changing SFS Mx to 60 (initially it was 20). No matter the SFS value, I was using 0.7 but now I find better SQ at 4.00. The value that produces the problem is a low Max value. At least that's what I've found.
« Reply #16 on: June 29, 2016, 10:17:43 am »
Hi Juan,
Thus only when the Max is low you have the problem, and when setting only that to higher the problem goes away right away ?
D*mn I wish I could mimic at least one of the situations so I can solve the Message to show what it wants (so if not clear yet : the error message itself fails at this moment and always shows that ActiveX thing).
« Reply #17 on: June 29, 2016, 11:45:08 am »
YES !
It is that Max setting !!
So with the first hint of Stanley and now the totally clear post from Juan, I got it !!
So now I can solve the Messages failing in general.
Thank you guys - Super !
« Reply #18 on: June 29, 2016, 12:06:29 pm »
That's not totally correct Peter. I've discovered that  if I set the Max to 20, 30, 40, 50, 70 and 80 the message appears and when I set it to 60 all is ok. So, here it only works correctly when Max is set to 60.
There's no other error messages than the ones shown by Stanley in the first post.
« Reply #19 on: June 29, 2016, 12:09:32 pm »
That's great Peter, I haven't seen your last post.
« Reply #20 on: June 29, 2016, 01:38:20 pm »
The 2.06 Download now contains an UpgradePatch 2.06a which solves this issue.
Again, great thanks.
« Reply #21 on: June 29, 2016, 01:47:19 pm »
Peter , I used the upgrade patch on 2.05 to ugrade to 2.06, isn't it possible to get just the new patch or do I have to install the new 2.06 version?
« Reply #22 on: June 29, 2016, 01:57:29 pm »
Juan,
Just look at the name of it. This should be clear.
Is it not ?
(I do not explain on purpose at this moment, because I like to have it automatically clear)
Just ask again if it is not clear, or try to explain what is not clear. Ok ?
« Reply #23 on: June 29, 2016, 02:36:34 pm »
That's totally clear now, I haven't read the name in the download area, I was a bit lazy this morning, too hot here in southern Spain besides not very motivated with the Eurocup. At least I have some part of the family living in Italy and they seem to be happier  don't do that
Thanks
« Reply #24 on: June 29, 2016, 02:41:24 pm »
Eurocup ? what Eurocup ...
Out of here
« Reply #25 on: June 29, 2016, 02:52:16 pm »
Ok Peter, sorry... whistle
« Reply #26 on: June 29, 2016, 03:37:11 pm »
Better than to lose from Island.
Eh ... which we already did eralier on. arrogant
« Reply #27 on: June 29, 2016, 03:37:45 pm »
Yes Peter, the problem is solved.
Thanks
Stanray
« Reply #28 on: June 29, 2016, 09:56:09 pm »
Indeed problem soved!
Thanks Peter and Juan.
Stanley
