November 22, 2024, 09:59:56 pm *
Author Topic: eSata + RAM OS does not work  (Read 21707 times)
« Reply #15 on: May 18, 2016, 09:29:04 am »
So, solved for you ?
« Reply #16 on: May 18, 2016, 09:55:01 am »
yes.
Another possibility would be to install an Asmedia (controller) driver from 2013 or an Intel driver from the Asrock site for this mobo, but nobody knows how that will work. He, he.
The RAM-OS PC is running around the clock now and this scenario is a solution I can live with.
Thanx.
« Reply #17 on: May 20, 2016, 04:15:05 pm »
Hi Joachim,
Strange indeed Happy I have 3 different brands of sata controllers on my motherboard... Go figure...
found out today, that in the BIOS (X79 chipset) under (South Bridge) "Storage configuration" all remaining eSata's connections shall be disabled, otherwise the external eSata drive will not be recognized by the running W10 OS.
« Reply #18 on: May 20, 2016, 05:08:19 pm »
The fun thing is that if the "ram" load is effective, loading Windows in ram and booted from ram - all should be ok. It's only when one tries to "attach" the drive that something will be wrong (it will not connect)...
