« Reply #90 on: September 07, 2016, 05:57:43 pm » |
Mani, Peter must have been enjoying using it as it was still in MinOS!  , indeed I have (day before yesterday's listening session of 4-5 hours). I had to know how "28 cores" sound. And I must honestly say that I considered to get such a processor myself. Then I thought I was crazy enough without it ...  Thank you Mani. Peter
« Reply #91 on: September 07, 2016, 06:02:32 pm » |
PS: I see that blue led shining in your beautiful picture; this can be quite bright during sleeping office hours.  On the inside of the (opened) front there's a small plate which can be shifted in front of the led. I never really tried it myself, but mine went in front of the led by some accident and I really like it better. This is not mentioned in the provided little guide (I never thought of it). Peter
« Reply #92 on: September 07, 2016, 07:47:18 pm » |
Jamming ... Playing the guitar ... on a keyboard. Btw, Kaya is about finished by now. Yes, try Crisis for some load of bass.
« Reply #93 on: September 08, 2016, 12:24:45 pm » |
Jamming ... There's one guy who looks totally out of place - doesn't have the 'cool' gene. Mani.
« Reply #94 on: September 08, 2016, 12:32:43 pm » |
Hi Mani, But we know he is cool  And with all he has done and is still doing he can also be quite hot  You have a very cool system btw Alain
« Reply #95 on: September 08, 2016, 01:55:37 pm » |
Hi Alain. You have a very cool system btw  Yeah, not bad for an office system, hey? I'm quite happy to experiment with different amps and speakers in this room (and probably will continue to do so going forward), but XX and the NOS1a are a permanent fixture. My BIG dilemma right now is where to put the Mach II. I haven't tried it in my main system yet, and won't for a few more weeks. But I just know that I'll really miss it when I take it out of my office system. If this is the case, the only solution will be to order another one! Boy, running two systems starts getting very expensive. Having said that, it's just sooooo nice to be able to work with beautiful music filling the room as you do so. This is becoming almost more important to me than having a dedicated listening room... Mani.
« Reply #96 on: September 08, 2016, 03:45:02 pm » |
Hi Mani, You certainly have good taste  I also understand your dilemma; when I am not at home (I have been for the last 3 weeks at my girlfriend's home - her mother is in loss of autonomy), II miss my audio system a lot... Music is such an important part of my life... Having the chance to listen to music and with marvelous SQ is a gift of life for us I hope that Peter knows how many smiles he triggers  Please keep on bringing your perceptions And let the good times roll !  Alain
« Reply #97 on: September 09, 2016, 11:09:32 am » |
Having the chance to listen to music and with marvelous SQ is a gift of life for us  Listening to Henryk Górecki in my office right now (trying to concentrate on work)... with my eyes full of tears... Only music can do this... Mani. Edit: Now listening to KLF to cheer myself up...
KnB
« Reply #98 on: September 15, 2016, 09:12:43 am » |
Congratulations mani, the new computer from Peter is a big step forward imho  Have been using mine a while now and it's performing very well. Using 10586 ram version, not sure about 14393.0 -very impressive at first..., but I spend a lot more time listening when using 10586
Phasure system: XXHighEnd stealth Mack III LPS PC, Xeon scalable 14/28 - Lush^2 Blaxius^2 - NOS1a/G3 75B Dac - Orelo mkII speaker
Win 10 14393 - XX 2.11 - min OS - RAM drive - Music on LAN - Adaptive 4096 - Allow format change - Core 3/5, low, Real time - Clock res 15ms XTweaks 52,10,1,0,1 - Boost at xxhighend startup - SFS 10.19/10.19 SC - Incl garbage - Copy to xx - Always clear proxy - Use remote desktop Use touch facility - Stop desktop/remaining/wasapi services - Keep LAN - Use remote desktop - OSD text - Show as wallpaper - Q1,3,4,5,xQ1;14,1,1,1,10 Prosessor set to 20 cores - Driver 1.04; USB buffer 16ms
toddn
« Reply #99 on: September 28, 2016, 05:10:01 pm » |
So I just received my new Mach II PC the other day, and WOW! What an essential piece to pair with the NOS1. I would recommend anyone serious about computer audio must get the Mach II! It improves the sound on every possible level. "Detail with Musical soul and drive" I can't imagine what the up coming B'ASS might add to the increased "power" it presents, It is also a wonderfully built and finished product that complements audio gear and doesn't look like some DIY add on or out of place desktop PC.(Makes me feel the need to finish my amps and speakers cosmetically  ) Just for some background, my prior audio PC had the same modded motherboard with an external clock, an external PCIe clock and USB 3 PCIe card with an external clock as Mani's LeMonster PC. It was also running a full ATX linear power supply. Peter's Mach II destroys it! Todd
W10-10074 XX HighEnd 2.03 PC -> i7 3930K AS Rock MB W/ Dexa Neutron Star & linear PS supply mod. For Processor Clock, Hyperthreading On (12 cores) @430MHz (!), 16GB, Windows 10 Pro 64 bit Insider Preview build 10074 Samsun SSD, XXHE on 2GB RAMDisk (IMDisk), music on LAN / Engine#4 Adaptive Mode / Q1/-/3/4/5 = 14/-/1/1/1 / Q1Factor = 1 / Dev.Buffer = 4096 / ClockRes = 1ms / Memory = Straight Contiguous / Include Garbage Collect / SFS W10 = .14(max 60) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / W8 Scheme = Core 3-5, W10 Scheme = Core 1-3 / Not Switch Processors during Playback = Off/ Playback Drive 2GB RAMDisk (IMDisk) / UnAttended (Just Start) / All Services Off / Keep LAN - *Not Persist* / WallPaper Off, W10 Running Time Off / Minimize OS / XTweaks : Balanced Load = *63* / Nervous Rate = 1 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = On / *Custom Filter Mid 705600* / -> USB3 (Silverstone W/Dexa Neutron Star Clock & Linear PS> *Clairixa USB* -> Uptone Regen w/ Dexa Neutron Star & linear PS -> 24/768 Phasure NOS1a 75B (BNC Out) async USB DAC, Driver v1.0.4b (*4ms*) -> Blaxius BNC interlink -> 8 channels of Hypex NCore 400's -> DYI BD Orphean Horns w/ qty-3 custom 15" open baffle bass drivers and qty-8 12" open baffle subwoofers per channel
« Reply #100 on: September 29, 2016, 09:18:11 am » |
Thank you very much for that great read, Todd. I can't imagine what the up coming B'ASS might add to the increased "power" it presents The answer to that is quite simple : you write this because you see me writing in superlatives about the B'ASS so all is a bit virtual but imaginable. However, what if I tell you that last week I would have said the same as you just did (WOW and such) about my B'ASS relative to the week prior to that. And worse, yesterday I did that again. So true, it will be unimaginable what will happen soon, because the B'ASS is in it finalizing stage. But still some issues to solve. Also see new topic I will start soon (in Chatter). Regards, Peter
« Reply #101 on: October 14, 2016, 01:25:43 pm » |
Front as per October 2016 (change was necessary due to inconsistencies in the base front and engravure problems because of that) : High Resolution link XXHighEnd MachII LPSPeter
Leo
« Reply #102 on: November 01, 2016, 02:34:18 pm » |
Hello Peter,
I would like to order a 20 core Mach II PC plus ramdisk
all the best, Leo
Dedicated silent audio pc HFX classic, Windows 8 pro 64bit / Intel 3930 CPU 6 cores 12 threads, ASRock x79 Extreme4-M/ SeaSonic Platinum 400w ATX PSU / 16Gb RAM , music on (SATAIII), MinOS/ Engine#4 Special Mode / Q1/2/3/4/5 = *6*/0/1/1/1 Qf=1 (Dev.Buffer = 4096) / not Invert / Playerprio = Low / ThreadPrio = Real Time / *Scheme = 1-2* @ UnAttended /Services Off + No Running Time / Octo Arc Prediction Upsampling / *SFS=0,4 max= 120* XT Tweaks balanced load 43, nervous=100, cool when idle 1, Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = On / Double Octo Arc Prediction Upsampling / -> USB with Dexa clock -> 24/768 Phasure NOS1 async USB DAC, Driver v1.0.3 (2ms) -> direct to AMP: Gainclone mid high, Hypex DPS400 low, horn system (tractrix for mid/high, BD for bass with Oris200)
« Reply #103 on: November 01, 2016, 03:44:31 pm » |
Leo, great !! And yes, I noticed that you are one of the few who never got into the RAM-OS Disk yet. Now I can put that behind me, haha. Welcome to the club of Stealths !  Kind regards, Peter
« Reply #104 on: November 03, 2016, 03:02:24 pm » |
Leo, Maybe a strange path to communicate ... but somewhere I recall that your email address changed (and I use the same one as the one you use for the forum), while you also seem not to respond to the email I sent to you on November 1. Not that you really needed to respond, but your Stealth is about ready and ...  Best regards, Peter
