April 02, 2025, 09:51:21 am *
Pages: 1 2 3 4 5 [6] 7 8  All
Author Topic: Mach II XXHighEnd PC with Linear Power Supply  (Read 153767 times)
« Reply #75 on: June 10, 2016, 11:35:09 am »
please read my email concerning your Reply #74
« Reply #76 on: June 10, 2016, 12:58:16 pm »
Joachim, I just saw that my email to you from 10 minutes older than your last post, does not want to go out (with others). So keep watching your Inbox - I will try to repair ...
« Reply #77 on: July 12, 2016, 06:08:56 pm »
Hi All,
So ... what you see below is the picture of the first Stealth going out, just over a week ago.
High Resolution link XXHighEnd Stealth Mach II LPS Front
Switch at the right hand bottom is to turn on the cooling fan manually. Shouldn't be necessary but can be used to cool more than natural convection does, e.g. when you don't use the PC and now for even better longevity. Below you can see the (white) led for it ~1cm next to the switch.
High Resolution link XXHighEnd Stealth Mach II LPS Back
Large slider switch next to the power inlet is to cut mains Protective Earth, so it doesn't imply capacitance in the power cord when you want to play with without PE.
With some other jobs in between the lines, today the 6th of a first planned batch was going out. 2 have been shipped to new NOS1a owners so they won't know the difference anyway Wink and of two of the others we might hear something of, soon because they post here now and then.
Next batch is starting tomorrow with the knowledge that the due owners are all enjoying a vacation or are out for other reasons. bye So hold on for reports other than my own.
music33
« Reply #78 on: July 13, 2016, 03:14:42 am »
I am one of the new owners of the MachII with OS RAM drive.  I haven't been able to spend much time listening or optimizing.  I currently have a mouse, keyboard, monitor and USB drive for music hooked up to the Mach II, so again far from an optimal setup.  Prior to the Mach II I had a laptop which is my comparison point for sound quality against another computer.  I don't have a lot of comments so far, but here are a few -
- First it is a remarkable engineering job from the hardware to the software.  I will post more on this later.
- Read the directions carefully, it is all there, but easy to miss things (or maybe it is my reading comprehension).
- I originally hooked up a USB keyboard and then switched to a PS2.  The sound is better with the PS2 keyboard.  To me this gives you an idea of how sensitive the sound quality is to the computer and how with this system you can hear the difference...  Of course most of you have known this for awhile.
- I'm not great at describing sound differences, but I'll give it a shot - bigger sound stage, better clarity and definition, more natural, and a lot more bass. I think the most surprising thing is I've never heard bass sound so natural on my speakers before.  Even though I am coming from a laptop, before the NOS1a I had a great CD player and amp and all the things I mentioned are significantly better except the sound stage with the same speakers.
I plan on using creating a direct Ethernet connection from the laptop to the MachII so I can RDP in.  This way I can take out the video card, etc.
As I progress more I'll post.  Looking forward to hearing other people's thoughts.
Dave
« Reply #79 on: July 13, 2016, 08:22:52 am »
Hey Dave, congratulations whith your well-thought-over purchase, and thank you for this first report.
Now wait till the day that you can detach all devices (including the SSD for the OS) with as last step the video card. You will be (should be) amazed how much *that* alone will matter. After experiencing that, you will not be able to listen for one minute with the video card in. Promise. Anyway, that relatively bad suddenly.
fmanheck
« Reply #80 on: July 19, 2016, 02:35:40 pm »
Hi All
Just wanted to chime in with some feedback. I previously had the original Phasure computer and the NOS1a using the RAM OS. I was using a music server to provide music files. Installation of this is beyond my skills so I enlisted the aid of one of my friends to set up the connection between the 2 computer.
Last week the new MachII Stealth arrived. I had my friend back and he reconfigured for the new computer (more on that later) It was playing wonderfully with even better sound than before. It always amazes me how Peter makes the impossible happen. Each time I can't believe it actually sounds more realistic and lifelike. People come to my home and they are literally stunned.
After all was set up last Sunday I decided to remove the video card as recommended. For someone with my limited computer skills this is kind of scary.
I turned the computer back on and I started getting red and blue flashing lights instead of just the cool blue. I shut it down, emailed Peter and went to work for a couple of hours.
No answer from Peter....It was Sunday and he does have a real life after all good
I got home saw an email from Peter saying not sure what was going on and telling me to put it back in for now.
So not wanting to be without music I put back the video card. As it was rebooting I noticed the red flashing light again and then a light flashed in my head Haha
I never waited for the boot process to complete. Removed the video card again (Peter emailed me saying the same thing during this time) and all was well with my world good
Without the video card the sound was much better but I would say not as dramatically improved as with the new Stealth in the system. That improvement just on its own was fantastic. Removing the card is the icing on the cake.
I would be remiss if I did not make one comment: F*cking Windows !
My friend had a real tough time getting it all setup and Windows 10 is the culprit. He is not certain but what he thinks happened was since I wanted as easy access as possible, he set up the server user with no password. While Windows gave no messages or warnings, it was not allowing the Stealth to see the server music files until we set up the user on the server with a password. Once he did that it saw the drive and not until then. Pretty bogus if you ask me.
That's it for now. Gotta go listen.
 One thing that never sounds boring
PETER YOU DID IT AGAIN Good job !
« Reply #81 on: July 19, 2016, 05:36:00 pm »
Thank you Fred.  Happy Happy Happy
It is (sort of) quite well known that PC's which take part of the RDC communication require a password. Also, the XXHighEnd scene of PC's require a password anyways, because otherwise insufficient rights exist for various XXHE tasks.
Maybe it hasn't been dealt with the last year (or even 2), but I think the subject passed a couple of times.
Anyway you guys for sure did sort it out completely on your own, so well done ! very well done.
KnB
« Reply #82 on: August 14, 2016, 09:07:45 am »
Finally home again and new PC are up and running.
Arranged with music on Lan, remote and removed the video card -min OS on ram. All done in minutes  Wink
Sound? Yes, no doubt very promising  Happy
Did play about 6 hours yesterday, no serious listening as I just arrived from a very long travel (from Angola)
Anyway, just a smal feedback to Peter that I am very happy with all, and now I need some time to listen
« Reply #83 on: August 14, 2016, 09:46:33 am »
And give it a week for burning in !
KnB
« Reply #84 on: August 14, 2016, 06:48:32 pm »
Yes, will do.
Been listening a few hours today and it's no doubt big step forward  Happy
And now with the w10 14393  Happy Happy Happy  happy!!!
Its really a big difference!
« Reply #85 on: August 14, 2016, 07:42:15 pm »
Happy Happy
« Reply #86 on: September 06, 2016, 12:21:30 pm »
All,
The 2660v4 processor now has been tested too.
yes
And for those interested : the 2660 runs a bit cooler than the 2650, with the result that the 2660 can play Audio with continuous passive cooling (video card assumed removed !).
PS: And to the due owner : congratulations !  Happy
And of course, thanks for sticking your neck out !
« Reply #87 on: September 06, 2016, 12:55:52 pm »
Wow, very impressive to see all those cores !
« Reply #88 on: September 06, 2016, 08:43:07 pm »
You're welcome Peter!
The 2660 Mach II should arrive here tomorrow. Fortunately I'll be around to receive it and should be able to set it up immediately. I'll compare it to my current audio PC (3960X, Teradak linear PSU, 3x Neutron Star mobo/USB clocks, etc) at some point, but it'd probably be best to wait a while to let the Mach II burn in - other owners (e.g. Scroobius) have reported that the burn-in process can take quite a while. As always, I'll try to give my honest impression of the sound...
« Reply #89 on: September 07, 2016, 01:35:27 pm »
The Mach II has landed!
Very straightforward to set up - connected the monitor, mouse and keyboard first just to find the IP address via ipconfig. Once I had this it was a doddle to set the RDC up. Then removed the video card.
Peter must have been enjoying using it as it was still in MinOS! Had to go to normal OS to get my NOS1a to be recognized. But other than this, got into RAM-OS with total ease.
And the sound?
How can a PC make such a difference? I think for the first time ever I've now got 'real', deep, deep bass from my office system. Listening to Marley's 'Kaya' right now - I've always thought not the best recording, and generally lacking deep bass for a reggae album. But this just isn't the case, as I'm hearing it right now.
BIG smile on my face... Grin
Thanks soooooo much Peter!!!
Edit: Of course, lots more thoughts about the sound over time...
