« Reply #30 on: May 20, 2016, 06:16:23 pm » |
If you ever consider the possibility to sell your LPSU as a standalone - no matter if it is in a wooden box, a metal box, does come bare as is with the required cables, I would certainly be interested in getting one.
Thanks.
« Reply #31 on: May 21, 2016, 02:00:36 pm » |
This looks so interesting. Like many people here, I'm sure, I'd love to be able to simply go ahead and order a new Mach II without any worries. But having already invested heavily in my current audio PC, the decision to drop Euros 2k+ for a new one is difficult for me. I would do it though if there was a guarantee of better sound.
Are you happy to offer a trial period so that people could evaluate the Mach II in their own systems, with a restocking fee (plus two-way shipping costs) if they wished to return it?
Mani (Greetings for Melbourne BTW.)
music33
« Reply #32 on: May 22, 2016, 02:56:57 pm » |
Peter, in the Eureka thread you mention the issue of PE affecting sound quality. Did you solve it in the Mach II and if so is it by disconnecting it or some other means? I ask as this is a significant design improvement in audio PCs. Mind you ... that I have connected my devices' cabinets was not intended at all. As a matter of fact I only "dicovered" when I wrote the first post in this topic ... (at this moment this is still so, but the PE in the PC is disconnected and sound was great again).
« Reply #33 on: May 22, 2016, 05:24:52 pm » |
Hi Dave,
As a matter of fact it only this morning came to my mind that I forgot to mention that as a feature. So :
There will be a switch for that which by default connects PE and which thus also can disconnect PE; I forgot because the day that bracket in the back (for the power inlet) was finished I disconnected PE with good result, but the hole for the switch just was not there yet (it still isn't, but will be in the production machines).
Arjan
« Reply #34 on: May 24, 2016, 01:38:36 pm » |
I see in the specification that the internal memory is now 32Gb. Why is that? Does that mean that 16Gb is no longer enough or just anticipating for the future?
About the CPU. Do you have any thoughts about the much cheaper Xeon 2620V4 (octo) version? I know more cores will load a album faster but what about SQ?
Is the DVD player needed? I always use an external usb player if needed.
I am really interested in this MachII, but also a bit hesitating. What will it bring, it is not a DIY pc anymore and I am also awaiting the B'ass.
regards, Arjan
music33
« Reply #35 on: May 24, 2016, 02:50:42 pm » |
Hi Peter, I assume the MachII comes with an XXHighEnd version that has the PSU dials? Could you provide the details on what the dials are and how to use them? We need "PSU Dials" !! (oh, I have a new one in XXHighEnd already, especially for this)
Many thanks for truly being innovative and hence moving the digital sound reproduction by leaps and bounds forward. Cheers, Dave
« Reply #36 on: May 24, 2016, 06:34:11 pm » |
I see in the specification that the internal memory is now 32Gb. Why is that? Does that mean that 16Gb is no longer enough or just anticipating for the future? Hi Arjan, 16GB is enough but a. the 16GB in the "old" XXHighEnd PC did not anticipate any RAM OS Disk situation; b. the RAM OS Disks as have been provided so far anticipate everybody having 16GB in their PC (XXHighEnd PC or otherwise); c. since this is a new dedicated PC why not put 32GB in there. Ad c. Do notice that the normal RAM OS Disk setup has only 3-4GB of free "disk space" and ~3GB of free memory. This means that not a whole world of HiRes material can be played from one Playlist. I know, most of us are not into HiRes all that much but we shouldn't be dictative too much, right ? So now 5GB of "disk space" is added and the remainder of the extra 16GB is for free memory. Let all breath a little ... About the CPU. Do you have any thoughts about the much cheaper Xeon 2620V4 (octo) version? I know more cores will load a album faster but what about SQ? SQ definitely will be better the more cores are available. Notice that the old PC with its 6/12 cores also explicitly was about that (and not at all about track loading, although of course that matters too). Is the DVD player needed? I always use an external usb player if needed. No. Especially not since I actually can't get them anywhere any more at this moment. Still it can be convenient for loading drivers. I know, we can download everything these days, but still. Anyway, if I can't get them I can't get them. I am really interested in this MachII, but also a bit hesitating. What will it bring, it is not a DIY pc anymore True. But it also is something maybe nobody could have done "DIY" to begin with, which almost includes me.  By now there's also too much money involved to "play around" a bit and trial. If you don't pay attention (in this "leage") you fry a 1000+ costing processor; You don't want to know how many baby steps with IR thermometer pointed at all places at the same time, I took before it started to run for real. I hope this was something for an answer ...  Regards, Peter
Arjan
« Reply #37 on: May 24, 2016, 10:33:42 pm » |
Yes it is. Thanks Peter.
« Reply #38 on: May 25, 2016, 06:14:31 am » |
16GB is enough but
Peter, will XXHE 2.06 and the larger (32GB) RAM OS be available to people that do not get your new PC? I ask because I do have a nice hi-res collection that contains some of my favourite music. For example it is a p.i.t.a. to have to load half of the Max Bruch Violin Concerto (DXD) just so I can listen to it...then after that has played I load the second half. SQ definitely will be better the more cores are available. Notice that the old PC with its 6/12 cores also explicitly was about that (and not at all about track loading, although of course that matters too).
Interesting. I have observed this but not tested it but now you seem quite sure about it.
« Reply #39 on: May 25, 2016, 08:40:19 am » |
Hi Anthony, Interesting. I have observed this but not tested it but now you seem quite sure about it. Oh, I always have been, say since Minimized OS has been introduced. It is only that I myself never had the opportunity to test/listen with more than 12 cores (unlike you). It is very explicit strategy (just investigate how Core Appointment works). Peter, will XXHE 2.06 and the larger (32GB) RAM OS be available to people that do not get your new PC? Sure. By the time someone has 32GB and wants to benefit from a larger "OS Disk" he can announce himself. Regards, Peter
« Reply #40 on: May 25, 2016, 01:41:19 pm » |
Hey Peter, maybe I missed it, but has there been any published price of the new PC and what might that be?
« Reply #41 on: May 25, 2016, 02:57:47 pm » |
Yo Brian, It was all spelled out in this post : Re: XXHighEnd PC Mach II Low Profile Stealth. For better clarity I now put the same text in the first post of this topic as well (which wasn't so because I let evolve the PC graduately). I also just changed the title of the topic, might people still think that LPS was the abbreviation of "Low Profile Stealth".  Regards, Peter
« Reply #42 on: May 25, 2016, 04:05:50 pm » |
Don't know how I missed that!
« Reply #43 on: May 25, 2016, 05:29:27 pm » |
the RAM OS Disks as have been provided so far anticipate everybody having 16GB in their PC (XXHighEnd PC or otherwise); Hi Peter, I don't know if i misunderstand you but i'm using 32GB of internal memory. I do have the Ram OS disk, but it's still not operational. Do you suggesting that the ram os will not work in mine 32 GB configuration? I'm also using hires material. Regards Johan
« Reply #44 on: May 25, 2016, 05:48:14 pm » |
Do you suggesting that the ram os will not work in mine 32 GB configuration? Haha Johan, no. I was suggesting to "anncounce" yourself, which you just did. Watch your email ... Best regards, Peter
