November 23, 2024, 02:32:48 am *
Author Topic: Windows RDC From Mac  (Read 12958 times)
PaulF70
« on: April 29, 2016, 06:29:04 pm »
If somebody could tell me how to connect to my headless XXPC from my Mac laptop using Windows RDC, I'd appreciate it.
My XX PC in on my LAN - I can see it in Finder and connect from there.  However, using the XXHE account from the RDC client (which is current) does not work.
I thought I needed to activate Windows to setup another user but Peter says no.  I thought I would post here rather than continue to bug him.
Apologies if this is covered elsewhere.
« Reply #1 on: April 29, 2016, 07:04:19 pm »
Paul, always use the IP Address (of the XXHighEnd PC) to connect to via RD(C). When the connection works, you normally login with the XXHE account.
That is not really what I said. I said (or intended to say) it is not necessary to set up another account. That wouldn't even work elsewhere (in the audio (XXHighEnd) environment, later.
Btw, it is difficult to really bug me. But I am off for the day now ... yes
« Reply #2 on: April 29, 2016, 11:02:59 pm »
I had an issue once with RD where the IP address would not work, and against Peters advice I used the computer name "RAM-OS" and it works like a charm.
PaulF70
« Reply #3 on: May 15, 2016, 10:12:56 pm »
FYI, I got this to work, by following directions here:
https://social.technet.microsoft.com/Forums/office/en-US/1523bbbd-e1f1-43f6-8efe-fabe732fa487/problems-connecting-to-windows-10-with-mac-remote-desktop-connection?forum=winRDc
Even though I had just downloaded the RDC client the first one I had was not compatible with Windows 10.
« Reply #4 on: May 16, 2016, 09:15:05 am »
Paul, thank you for the feedback.
PaulF70
« Reply #5 on: May 16, 2016, 08:10:08 pm »
So... one teensy little hurdle left here.  I can't right-click from RDC on my Mac.  This means I can't do things like:
- Select tracks in the play list, right click, and remove
- Use the right-click menu on the Save button
On the Mac (native), ctrl-click is right click.  This does not work in Windows over RDC.  I have scoured forums and Googled and tried every damn thing to get this silly little thing to work.
So, if anybody is using RDC on a Mac to control their Phasure PC and you've figured out how to transmit a right-click using the Macbook keyboard/track pad, please do enlighten me.
jhmvl
« Reply #6 on: May 16, 2016, 10:50:04 pm »
Sounds like you should try activating "secondary click" for your mouse on the MAC. I have a MAC and I can right click the mouse because I have that option activated. Right clicking (with this option activated) replace the ctrl click on your MAC and presumably also on your RDC connection.
You can find this option under settings and then mouse.
Seems worth a try to me since the fact that you mention ctrl-click to use sort of tells me that you do not have that option activated.
Hans
PaulF70
« Reply #7 on: May 17, 2016, 10:55:53 pm »
Hans
I use the trackpad, not a mouse - but it has the same option, and I have it enabled (always did).  The two-finger tap just has no effect on the Windows side.
jhmvl
« Reply #8 on: May 17, 2016, 11:42:42 pm »
I see, but I know MAC has different settings for mouse and trackpad. I am unsure if activating the two finger tap for the trackpad also activates the right click for the mouse. I could easily be wrong but I don't think it does actually (I use both a trackpad and a mouse and I have to set the options separately). Could be worth a try I guess to just connect a mouse to the MAC activate the relevant option for the mouse and see what happens to the RDC.
Hans
PaulF70
« Reply #9 on: May 18, 2016, 01:25:12 am »
Hans
You're implying that RDC will actually make use of mouse settings even when a mouse is not connected (it won't be in normal use).  I kind of doubt that's true, but maybe - RDC seems to be a strange beast in many ways.  I'll give it a try.
jhmvl
« Reply #10 on: May 18, 2016, 08:04:06 am »
And you are probably right but what I am saying is that I would try it anyway  Wink
Hans
