November 23, 2024, 02:46:56 am *
Pages: 1 2 [3]  All
Author Topic: Albums pausing  (Read 39515 times)
« Reply #30 on: May 01, 2016, 11:40:45 am »
Hi Robert,
If you have such a file of which you are sure it always stops, can you switch on logging, let it play for a few seconds and send me the X3 log file of that ? (press Stop, grab the X3 log file and you can attch the file here if you want).
After that I may ask you to send the whole file to me (by filemail.com and if the upload does not take too long for you).
Regards and thanks,
« Reply #31 on: May 03, 2016, 05:38:11 am »
Well, home from holidays today so I burnt a couple of my problem CD's using EAC instead of dBpoweramp and they both played through perfectly, so it does appear to be a ripping problem as you suggested Peter.
Robert
« Reply #32 on: May 03, 2016, 06:02:46 am »
EAC is slower but both my CD's played perfectly after ripping. I will use EAC from now on although I have ripped most of my CD's. When I started out in computer audio I did in fact use EAC but paid and changed to dbpoweramp after TCA Chris C recommended it.
Robert
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #33 on: May 03, 2016, 08:32:23 am »
Robert,
For EAC counts : If you're ripping faster than about 4x - 6x, you often won't have correct rips. So this is just a hint that it needs its time (so to speak).
Robert
« Reply #34 on: May 03, 2016, 09:03:01 am »
Yes I thought this may be the case suppose I will re rip the db ones over time.
Have you any luck with the hi res file I sent you?
I'm slowly converting all Saracon files back to original flac or wave. They definitely are better unprocessed.
Robert
Oppo 205 UDP Dac
Robert
« Reply #35 on: May 11, 2016, 03:05:32 am »
I have ripped more CD's and each plays perfectly and whole albums with EAC. I've compared and although its close I now feel EAC is slightly better in sound over dbpoweramp.
Interestingly some of the problem CD's were encoded with HDCD but EAC ripped, now work perfectly. Thanks acg for bringing this to our attention.
All my HDCD encoded cd's  were problematic with DBpoweramp.
Robert
Oppo 205 UDP Dac
« Reply #36 on: May 11, 2016, 03:17:45 am »
No problems Robert.  I am glad that we have been able to find a solution albeit requiring a lot of re-ripping of cd's.  Peter did mention earlier in the thread that he may be able to get XXHE to handle the error, which would be great, but he is very busy with other things so I doubt it will happen overnight.
In the meantime I will re-rip more of my cd's.  EAC should sound exactly the same and dBpoweramp or any other bit-perfect ripping software..but who knows?
Robert
« Reply #37 on: May 11, 2016, 03:26:44 am »
It should sound the same but I think the problem is dbpoweramp works too fast as Peter mentions.
EAC is a much slower method but perhaps captures more(this is subjective in the digital world as we are relying on a mechanical device to read the original CD accurately and software to process it).
The difference was marginal, I had to listen to a sparse Jazz track(End of the Line) by Randy Crawford and Joe Sample from Feeling Good album. In particular the bass and her voice seemed more natural.
Perhaps I imagined it like the difference in cables!!!
Robert
Oppo 205 UDP Dac
« Reply #38 on: May 11, 2016, 09:06:13 am »
Robert,
Maybe I missed it, but what are your problems with HDCD albums and DBPowerAmp ? Or do you mean that it is always them failing regarding the subject here ? If yes, that would even be veeeery logic, because when a sort of natively those are 24 bits (or are converted to that, which I think is what happens) then it is not the easy "always two bytes" any more. It is now three (3 x 8 = 24) and if this is not recognized while the program chops off at /2 bytes (a bit hard to explain) then 50% chance this gives the problem of leaving one byte (and 2/3 of a sample) at the end.
I think it is fair to say that DBPowerAmp sounds worse for the resulting rips, because it has been repeatedly reported. Notice that I gain such data from posts like yours, Robert. Throughout time quite many of those popped up.
Robert
« Reply #39 on: May 11, 2016, 12:07:03 pm »
Actually my problem is with certain HD downloads not playing albums right through these are 24/96 and 24/192 or even more than one song would be good. None are ripped but downloaded in wave from respected web sites.
Robert
Oppo 205 UDP Dac
« Reply #40 on: May 11, 2016, 12:34:33 pm »
Robert
I have that problem too.
« Reply #41 on: May 11, 2016, 01:57:22 pm »
For the 24/ 96 and 24/192 HD downloads, as mentioned earlier in this thread, the problem goes away by increasing the SFS. I usually change it to 1 and those tracks play one after another without stopping. Also, as mentioned earlier, one loses the benefits of the lower SFS.
Robert
« Reply #42 on: May 11, 2016, 10:35:02 pm »
"boleary" Yes I'm aware of the SFS some Hi res play at 1 and the worst at 4. But quite a few play at .10. I think its solvable but not easy as some don't have this problem at all.
The more recent HD downloads of music recorded recently like Mark Knopfler's Tracker are perfect at .10 but Harry Belafonte's Live at Carnegie Hall will only play all at 4.
Robert
Oppo 205 UDP Dac
« Reply #43 on: May 11, 2016, 10:45:04 pm »
Thanks Robert, I was just clarifying the the HD HiRes issue has nothing to do with DBPowerAmp.
Robert
« Reply #44 on: May 11, 2016, 11:45:03 pm »
I have ripped HiRes with DVD audio extractor and these play back no problem at .10.
There definitely is a problem with dbpoweramp and some ripped CD's and in association with using XXhighend playback and my computer setup. After extended listening last night I feel the EAC re ripped albums are better sounding.
I must qualify this by saying that a lot of my early rips were done on a laptop so this could also be a factor.
Certainly using an Asus BC-12D2HT x12 blu-ray drive in my new i5 work station everything is working fine. I suppose this could also be a factor in sounding better. As all things laptop certainly can't be called great.
Robert
Oppo 205 UDP Dac
Pages: 1 2 [3]  All
