November 23, 2024, 09:49:20 am *
Author Topic: Can you hear the difference?  (Read 6663 times)
« on: April 18, 2016, 02:04:01 pm »
Here's a little test that I'm conducting over at CA. I could do with a larger sample size though. If you have time could you do the following please:
Firstly compare these two first:
T001 (click to download: https://drive.google.com/open?id=0B0...3FfY1c4WW9FQVk)
T002 (https://drive.google.com/open?id=0B0...zRiam9xU2dvNnM)
Hear any differences between the two? If so, what are they?
Now compare these two:
T003 (https://drive.google.com/open?id=0B0...l9MbWIyaXE4NVk)
T004 (https://drive.google.com/open?id=0B0...DFBLVRKR0hDck0)
Hear any differences between these two? If so, what are they?
It's only the opening 1 minute of quite a pleasant piece of music. Just a few words on 1 vs. 2 and then 3 vs. 4 would be really appreciated. No need to make any other comparisons (but you can if you'd like to of course).
Cheers, Mani.
Bigear
« Reply #1 on: April 18, 2016, 05:25:47 pm »
Download doesn't seem to work?
« Reply #2 on: April 18, 2016, 08:31:10 pm »
Oops, not sure why. Let me try again...
https://drive.google.com/open?id=0B0PU5LO5jVjfd3FfY1c4WW9FQVk
https://drive.google.com/open?id=0B0PU5LO5jVjfdzRiam9xU2dvNnM
https://drive.google.com/open?id=0B0PU5LO5jVjfSl9MbWIyaXE4NVk
https://drive.google.com/open?id=0B0PU5LO5jVjfMDFBLVRKR0hDck0
So it's 1 vs 2, and 3 vs 4.
« Reply #3 on: April 19, 2016, 12:08:54 am »
Sorry, but I locked this topic. Not appropriate IMO.
