November 23, 2024, 09:51:39 am *
Author Topic: How to install Tidal in the Music Server Pc  (Read 27597 times)
« on: April 09, 2016, 06:26:08 pm »
I´m trying to install Tidal but although I read the Tutorials I can´t find the previous steps in case I need to install XXHighEnd in the Music Server Pc. I remember reading something before about that it is necessary to buy a new license (to be refunded) but I can´t find it and how to proceed later once XXHE is installed to login to Tidal.
« Reply #1 on: April 10, 2016, 08:40:43 am »
Hi Juan,
I most probably for sure won't understand the question, but nothing is different from doing that with your normal (Audio) PC.
All it requires is (indeed) an Activated XXHighEnd (to be refunded, assumed you already have a license for your household).
Can't be difficult !
« Reply #2 on: April 10, 2016, 09:18:38 am »
And Juan, if that does not answer your question (which seems doubtful - haha), don't hesitate to ask more. But please be more specific, then.
« Reply #3 on: April 10, 2016, 10:16:50 am »
Juan,
If you go into "Getting Started and Further Tutorials" and have a look down near the bottom at "Streaming Services" I believe that you will find the information that you seek.
So you just instal XXHE on your Music Server computer as normal, get it activated, but don't necessarily set it up to play music if you don't want to.  Then you login into Tidal as Peter describes in one of those tutorials and it should all work as intended.  Be careful to set the locations of the Tidal Temp and Streaming folders in XXHE setting of both the Music Server and AudioPC so that they are both looking at the same directories.
Since I finally got fast internet a week ago I am using Tidal daily and it is really a much loved part of XXHE for me now.  Before when the internet was flakey....not so much fun...but that is the internet not XXHE.
Hope this helps.
« Reply #4 on: April 10, 2016, 02:51:32 pm »
Peter, yes I have a license but I wasn't sure if I need to buy another one.
Thanks
Hi Anthony, that's what I needed to know because in the tutorials I couldn't find that part clearly explained.
Is it truly so important to have a really fast Internet? I understood that in some way it's possible to store the downloaded files to be played in a later moment.
Thank you
Arjan
« Reply #5 on: April 10, 2016, 07:19:34 pm »
Hi Juan,
It is just a lot of data..... Therefore fast internet is nice to have.
But you are right, first download and then play.
I love the Tidal option, it expand your cd collection.
Regards, Arjan
March, 2024 (2.11)
« Reply #6 on: April 10, 2016, 07:38:26 pm »
What´s the XXHE version I have to install in the Music Server Pc to use Tidal?: XXHighEnd-204.rar, XXHighEnd-204c-x.rar...
« Reply #7 on: April 10, 2016, 08:46:14 pm »
Hi Juan,
Tidal support started with version 2.03, so the latest (v 2.04) will be fine Happy
Something was corrected after v 2.04 (it is called v 2.04c), so you should download and extract v 2.04 first, then download and extract v 2.04c over it. The version 2.04c has only the files that had to be changed over v 2.04...
« Reply #8 on: April 10, 2016, 11:19:25 pm »
Thank you
I had internet that frequently dropped out...right out...and Tidal was dropping songs as a result.
Regarding which version of XXHE, if you use RAM-OS you can use 2.05 by following the instructions Peter gives here.
« Reply #9 on: April 11, 2016, 08:50:00 am »
Thanks Alain and Anthony, I have a few questions.
In my Music Server Pc l'm not using Ram disk, yes in my Audio Pc. I'm trying to install XXHE in the Music Server Pc disconnected from the Audio Pc and connecting directly the Music Server Pc to the NOS1. Am I doing it correctly this way? When I have to register  with Tidal in XXHE?, I have not Activated yet XXHE and I can't see the window asking to register with Tidal. What about the updates in the W10 I have in the Music Server Pc? as I have it connected to Internet  it is updated and it was difficult to install XXHE, not sure though if it has something to do with it.
« Reply #10 on: April 11, 2016, 10:45:10 am »
Juan,
The Music Server never has to be connected to the NOS1...only the AudioPC is connected when you want to play music.  For best results the Music Server should have a direct ethernet connection to the AudioPC so the chain looks as follows...
Music Server >> ethernet cable >> AudioPC >> Clairixa >> Intona >> Clairixa >> NOS1a.
If you plan to run everything from a tablet such as an iPad then the Music Server will need to be connected to your network which means that you will probably need a second ethernet port on your Music Server so the AudioPC is kept separate from the rest of the network.
Just to be clear, the Music Server does not need to have XXHE configured to play music or even connect to a dac.  We just want to run Remote Desktop and XXHE (for Tidal only), so W10 updates won't matter at all to SQ or anything else.
From where you are, I would activate XXHE (but not worry about setting up a dac driver or anything like that), make sure you have a direct ethernet connection between the two PC's, and then bother with the Tidal stuff last of all.  The network stuff may be a little tricky to get setup properly.
« Reply #11 on: April 11, 2016, 12:17:36 pm »
Juan,
Yes Anthony that´s how I have it (see my signature).
Thanks Anthony, I understood that I had to configure also XXHE in the Music Server Pc. I´m going to try it as you say.
« Reply #12 on: April 12, 2016, 01:00:17 pm »
Hi Peter, I find it impossible to activate XXHE (v.2.05 or v2.04) in my Music Server PC. I have carefully followed the instructions of the email I received, I have configured Internet Explorer (no Edge) as the default browser, I have disabled Windows Defender. I've done everything I usually do to activate XXHE but the top bar does not turn red, although the Processor Core Scheme Appointment is Activated.
That's the reason why I can't log in Tidal. I guess that I´m doing something wrong but what? My Music Server PC has W10 Pro 64bit and 8Gb of memory.
nik.d
« Reply #13 on: April 12, 2016, 01:11:00 pm »
Hi Juan, you need to play some music from HDD before Tidal streaming Happy
Load one or two tracks in the Playlist Area and play one in Attended Mode for a short while;
Watch the blue 'XXHighEnd' in the title bar of the XX user interface;
Quit XXHighEnd and Restart XXHighEnd;
Again start Playback.
Once more quit XXHighEnd and Restart XXHighEnd;
The title bar now shows 'XXHighEnd' in red when Activation succeeded.
« Reply #14 on: April 12, 2016, 01:19:13 pm »
Thanks, that´s what the email says and what I did a dozen of times without results. I´ll try to install XXHE from scratch again.
Page created in 0.213 seconds with 19 queries.
