April 01, 2025, 12:28:16 am *
Pages: 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22  All
Author Topic: B'ASS Current Amplifier  (Read 337491 times)
« Reply #15 on: April 02, 2016, 04:02:32 am »
Pictures please Peter.  It is a pretty big box.
A couple of questions...
Can it be built into the NOS1a?  I would prefer to have fewer boxes rather than more.
Do you think a switch and phono-in and perhaps a volume control could be incorporated?  After all it seems as though this new device is acting as a preamplifier.
Do you have some specs for the new device?  Gain, power draw etc.
toddn
« Reply #16 on: April 02, 2016, 05:30:13 am »
Count me in for BNC as well Peter.
BTW, I love reading your description the difference with the B'ASS. It's always about those things that make live music instantly distinguishable from recorded playback. The fact that the difference is ever diminishing with each of your improvements, gives me hope that one day I really won't be able to tell!
Todd
« Reply #17 on: April 02, 2016, 08:14:08 am »
BNC for me also  Happy do we need 1 or 2 for 1 NOS 1a Peter? You now my situation what would be needed.
Tore
« Reply #18 on: April 02, 2016, 09:01:49 am »
BNC for me  Grin
Tore
« Reply #19 on: April 02, 2016, 09:09:58 am »
Hi Gerard,
Just one for one NOS1(a). So The Device ( Cool) is stereo (two channel) in and out.
Regards and thank you,
« Reply #20 on: April 02, 2016, 09:21:26 am »
One for me too, the BNC one.
Could you pls post pictures of the B'ASS box.
« Reply #21 on: April 02, 2016, 09:22:22 am »
Hi Gerard,
That is just great....  Happy
KnB
« Reply #22 on: April 02, 2016, 09:29:45 am »
#3 for me  Happy
« Reply #23 on: April 02, 2016, 09:30:08 am »
A #2 and a #3 for me please Peter.
So if I understand correctly, these boxes can be used at the output of any DAC... or any line-level device for that matter. Correct?
« Reply #24 on: April 02, 2016, 09:35:52 am »
If I would have that I obvisouly would show it. Happy
But I haven't, as I didn't go further last November than sorting out the possibilities for a real audiophile box without resonance (of e.g. the lid) and such and that it should be of the proper wood type (the type of which I say it feels good for audio). As it is now this is 18mm of poplar wood but which maybe turns into 12mm because it is possible for the joints required. But with the 18mm it is 67mm of height, which I think is nice (with 12mm the height drops with (2 x 6 =) 12mm).
Nothing will be shown of the lid as it drops over the base and is screwed from the bottom side. The bottom side edges are 45 degrees angled inwards. There's also some gravures, plus slits in the lit for venting.
The color is transparant white (there's a polished finish over the wood which itself is close to white).
No, not really. It could with quite some additional effort ($$) but it was my explicit idea to avoid the transportation this time.
You are probably right. But where you go wrong is where any small change which wasn't intended, right awy kills the sound. It is (or feels) similar to the attempt of having RCA next to BNC which I gave up after a month of trying different things. It just wouldn't work out, or say it always sounded worse as the one and only good set up : the genuine 75 Ohm.
So if I'd so this, then the first thing what happens is that I can't listen to it myself. Oh, I can, but then you're forcing me to listen to vinyl.
sorry
But quite easy do do it yourself ? This is all not even in the SMD domain. Just input cabling.
N.b.: The box size is a bit over-measured because I don't want the power supply to influence the amplifier boards plus I want the cabling guided around all what could influence for the worse. So there's really space left in there.
Gain I mentioned in my to long story : 1.
So, unity.
Power draw will be close to "nothing", although I need to measure which I will try not to forget for later today.
« Reply #25 on: April 02, 2016, 09:40:26 am »
Correct !
« Reply #26 on: April 02, 2016, 09:49:25 am »
I'll take at least one... Happy
BTW, do your comments regarding the "NOS2 Lego DAC" also apply to those differential amplifiers you were developing?  Or are those also "no go" at the moment?
Hey Matt,
Let's say that all elements are still alive and that it is a matter of finding "the" application for them. This B'ASS is part of it too as it is actually the same. So what it is, is the derivative from those power amps, which turn into power amps again when additional components cause gain and more power. Add a large heatsink and there you go.
Probably at some stage (hereafter ?) I will dive into that again. My personal problem is to some extend that it is hard to test myself sound wise because of the active speakers (which can be fed with external amps but the comparison will be apples to oranges because of then different filter arrangements). So point really is : I only want to make things when they are judged (by me) as the very best; How to do that ...
« Reply #27 on: April 02, 2016, 09:58:41 am »
So your New Device is simply lowering the impedance of the NOS1a and giving options for current delivery?
Mani, although I think it is clear by now, maybe this outlay makes things additionally clear :
The NOS1(a) too, has natively something like 0.8 Ohms output impedance. The 33 Ohms or 75 Ohms for BNC is created on purpose, which is related to capacitance issues under way otherwise.
With the B'ASS this happens the same (but is natively 2.8 Ohm or so).
With headphones this 33 etc. Ohms of output impedance at the amp is not allowed, or at least not with the low input impedance headphones. So things will go badly when both sides have the same impedance, or better : the input impedance at the other side should be ~10 times higher at least than the output impedance of the "sender". Say (roughly) that otherwise the current won't flow.
« Reply #28 on: April 02, 2016, 10:03:32 am »
Just to have an idea of the connections and how it can fit in my setup.
Hi Arjan,
Since you ordered #3 you thus have BNC. I assume also in the power amps;
So outputs of NOS1a goes to the inputs B'ASS and the outputs of B'ASS goes to your power amp(s).
Actually you just inject the B'ASS in the output of the NOS1(a).
If this is not what you meant, just let me know.
Arjan
« Reply #29 on: April 02, 2016, 10:29:07 am »
Yes, the point is that currently the Nos1a is just in the middle between the amplifiers. With the blaxius exactly at the right length. So to me it seems that the B'ass will be in the middle now replacing the Nos1a with the Nos1a left or right from it. So they will be positioned next to each other.
So will the 50cm enough to do that? I hope you understand what I mean.
Regards, Arjan
March, 2024 (2.11)
