April 08, 2025, 10:32:06 pm *
Author Topic: Foobar settings for NOS1a??  (Read 25804 times)
« Reply #15 on: March 29, 2016, 12:06:49 pm »
Ehm, Paul, good to hear ?
haha
But this already is a good reason why improvements (attempts for them) along such lines will not work out.
If it does, it does of course, but I don't give you much hope.
xp9433
« Reply #16 on: March 30, 2016, 06:46:53 am »
Do I read this to mean that the capacity for use of EQ, which you use freely in your speakers, will never be available directly using XXHE software? Or have I misinterpreted?
Frank
« Reply #17 on: March 30, 2016, 07:58:18 am »
Hi there Frank,
I meant to say that when we are to use any EQ means per random external playback software, we will be stuck to a lesser SQ. Not so much because the EQ is not executed well, but because that player doesn't apply all the SQ stuff XXHighEnd does.
That meanwhile in that EQ environment all gets only worse (because nothing takes into account that each small piece of processing deteriorates) is something else.
That, lastly, the EQ environment does all the opposite of what at least I myself adhere (no ringing and such) makes it painful. Of course it requires first a DAC that "does nothing" or otherwise things are distroyed from there and "destructive software" doesn't add much baddie.
xp9433
« Reply #18 on: March 30, 2016, 08:51:18 am »
Not sure you answered my question. Are there, or will there ever be EQ options available with XXHE software?
My enquiry is based more on using XXHE or XXHE/NOS1a in a headphone system rather than in a loudpeaker system. Not something you would necessarily be interested in!
However, parametric EQ in this headphone environment is basic, doesn't have to account for Xover or room impact, and is usually phase coherent. Therefore a well implemented EQ used for headphone listening should have absolutely negligible impact on SQ.
My experimentation with EQ on headphones with software like JRiver is positive and seriously enhances the listening experience. However, I am sure the basic/overall SQ from JRiver wouldn't compete with XXHE. Hence my enquiry.
Frank
doublelife
« Reply #19 on: March 30, 2016, 09:56:04 am »
Frank,
I too was experimenting with EQ on my headphones only. But I found the SQ with J-River and an EQ plugin was significantly compromised compared to XXHE without EQ.
PC  i7 / W10 10074 (x64) / hyperthreading ON (12 cores) / 32GB RAM / XX - OS on separate dedicated 256GB SSD - XXHighEnd: 2.03 / Engine#4 Adaptive / 4096 / Q1=14  / xQ1=10 / Q3,4,5=0/1/0 / SFS=4-120 / Straight Contiguous / Clock Resolution = 1.0  / Scheme 3-5 / 16x Custom / Peak Extend = OFF / Unattended / Minimize OS / Phase Alignment = OFF / XTweaks = 43, 100, 1, 1, 1 > 24/768 NOS1a 75B async USB DAC driver v1.0.4 1ms > KGSSHV Carbon amp > Stax SR-009
xp9433
« Reply #20 on: March 30, 2016, 11:34:05 am »
Don't doubt that! But think what could be achieved if XXHE had a parametric EQ option!
Frank
« Reply #21 on: March 30, 2016, 06:50:27 pm »
Yes, If ...
And If I had the idea that it would be for the better sound. But I don't have that idea; see previous post.
It can only be done in hardware (interface bandwidth problems oterwise) but the hardware does not exist. Unless I make it myself, as it seems ...
xp9433
« Reply #22 on: March 31, 2016, 01:43:28 am »
Apologies and thanks Peter.
I "assumed" that as you were active in designing EQ settings used extensively in the Orelo speakers that it would be a relatively simple process to include EQ facilities or VST plugins for XXHE.
It is not, so I won't refer to it again.
Frank
« Reply #23 on: March 31, 2016, 08:38:13 am »
Hi Frank,
I allow it in the speakers because in there it is used for the lower frequencies only (under 200Hz) which is very fine at the sampling frequency (of the internal DSP) applied (60KHz or so, I forgot). 2000Hz would require 10x that (600KHz) and 20000Hz again 10x more (now 6000KHz).
If all stays in the digital domain that would be fine, but it can't and this is interface bandwidth related.
Of course quite some more active speakers with DSP exist, but listen to them ...
PS: Refer to this again when you like, but when today then nothing changed yet ... Wink
