doublelife
« on: March 25, 2016, 04:01:15 pm » |
I'd like to experiment with some VST plug-ins so I downloaded and installed Foobar. I've installed the 1.04 Phasure driver and Foobar recognises several driver options related to Phasure. I've selected the ASIO option. Tracks will play but no sound is coming out (yes, volume control is turned up....). With the WASAPI options, tracks will not even play. On the Phasure control panel, I'm still selecting 'Multichannel 4.0' as output.
Has anybody here used Foobar with their NOS1/NOS1a? Does anybody know what could be wrong, what settings I need, or do I need to use the other 1.03 driver??
Thanks Paul
PC i7 / W10 10074 (x64) / hyperthreading ON (12 cores) / 32GB RAM / XX - OS on separate dedicated 256GB SSD - XXHighEnd: 2.03 / Engine#4 Adaptive / 4096 / Q1=14 / xQ1=10 / Q3,4,5=0/1/0 / SFS=4-120 / Straight Contiguous / Clock Resolution = 1.0 / Scheme 3-5 / 16x Custom / Peak Extend = OFF / Unattended / Minimize OS / Phase Alignment = OFF / XTweaks = 43, 100, 1, 1, 1 > 24/768 NOS1a 75B async USB DAC driver v1.0.4 1ms > KGSSHV Carbon amp > Stax SR-009
« Reply #1 on: March 25, 2016, 06:23:52 pm » |
Hi Paul, Maybe others know more, but it you'd ask me you need Stereo (in the Driver, thus not MultiChannel) and put Switch #5 in the up position (normally it is down). ASIO is shut off in the driver (by me) so not much chance with that. Foobar recognises several driver options related to Phasure. Hard to imagine, but alas. Anyway, with WASAPI, Foobar normally plays. or do I need to use the other 1.03 driver?? Exactly not. For players other than XXHighEnd, 1.04 is required. Best regards, Peter
doublelife
« Reply #2 on: March 26, 2016, 09:22:20 am » |
Thanks for your thoughts Peter....
So I selected 'Stereo full' in the Phasure Control Panel and then in Foobar there are now 4 x WASAPI options! (L and R for 2 different names, I forget what). On each option I only get sound from one channel, and the channel swaps depending on whether I choose one or the other.
Very strange. There must be a way to get full stereo sound? Anybody?
« Reply #3 on: March 26, 2016, 10:05:05 am » |
Paul, I forgot to mention one thing : switch off "Is NOS1" in XXHighEnd's Settings.
doublelife
« Reply #4 on: March 26, 2016, 04:51:45 pm » |
Peter, I'm not using XXHE when trying to get Foobar to work. XXHE is on another drive. Does that matter? Paul
« Reply #5 on: March 26, 2016, 05:57:31 pm » |
As Peter as suggested above, is switch 5 on the dac up?
doublelife
« Reply #6 on: March 26, 2016, 09:55:01 pm » |
Yes, the switch 5 is up, have selected 'stereo full' in the Phasure control panel, and still getting multiple Wasapi options in Foobar, each of which only plays one or the other channel. Have also disabled 'is phasure nos1' in XXHE.
« Reply #7 on: March 27, 2016, 09:27:58 am » |
Paul,
You can use Stereo Reduced so you have less options (and it works just the same).
Hey, I can imagine that by now Foobar has a 705600/768000 option ? If so, possibly you try to use that while they don't apply it how XXHighEnd does it (HQPlayer the same).
Maybe it helps you if I tell that I use the "other player" myself each week for watching a movie (like last night).
If you have suggestions yourself, don't hesitate ...
doublelife
« Reply #8 on: March 27, 2016, 03:52:54 pm » |
I tried 'Stereo Reduced' but that just seems the same. Still just get sound in one or other channel depending on which one I choose.
If I have Foobar on my C drive and XXHE on my D drive, does it matter at all what the XXHE settings are (it is not running?).
The WASAPI device options I am seeing in Foobar relate to Phasure WDM device only (Engine 3?). Should the (PCM Renderer Engine 4) option be there as well?
« Reply #9 on: March 27, 2016, 05:46:32 pm » |
Hi Paul,
Yes, there whould be KS: options as well. Just similarly prefixed (the KS:) as in XXHighEnd. But I recall that this must be switched on in Foobar or is a special plugin.
Maybe you did something to the inputs and the outputs in there ? IIRC all can just be clean (maybe a volume control ?).
doublelife
« Reply #10 on: March 27, 2016, 07:12:09 pm » |
Ah, a Foobar KS plug-in. Now we might be getting somewhere! Watch this space.
Thanks Paul
doublelife
« Reply #11 on: March 28, 2016, 10:02:45 am » |
Yep, that works! Also, I realised that switch#5 is (in my mind....) is in fact switch#1, so now when I press the true switch#5 tis singing....  Paul
« Reply #12 on: March 28, 2016, 12:05:44 pm » |
Nice! I've made that mistake too a long time ago.
« Reply #13 on: March 28, 2016, 12:38:48 pm » |
Paul, we can just allow your left and right being switched around. But back and forth ... no !
haha
Ok, good that you got it working ! Peter
doublelife
« Reply #14 on: March 29, 2016, 10:09:36 am » |
In my quest to use some EQ vst plugins for kicks, Foobar is working, also J-River. But I must say how shocked I was last night at the complete deterioration in SQ going from XXHE to both Foobar and J-R. Sound is etched, lacking microdynamics. Now for HQP!
