November 23, 2024, 01:55:22 am *
Author Topic: RAM -OS files do not load into 16GB memory  (Read 30208 times)
« Reply #15 on: April 29, 2016, 04:53:49 pm »
Hmm ...
It can't be about any little bit of too few memory, with the notice that nothing has been made to "fit" into 16GB exactly or something like that. Only if 3GB or more is lacking, it won't work.
I found a 'shared memory' option for the built-in GPU.
Maybe it is about that, somehow. So you're saying that you have a CPU with in-built graphics, right ?
Maybe it is something with that. Still no idea how ...
You're now the only one experiencing this (Joachim virtually too, but he changed his PC for another one).
scratchingscratchingscratching
« Reply #16 on: April 29, 2016, 05:00:22 pm »
He, he,
with the new PC the same info as before, but then a "probing process" is starting *to count up to 13000* and the OS is loaded into RAM. See pic attached.
*Sound is great and my wife asked "Something new"?*
« Reply #17 on: April 29, 2016, 05:02:44 pm »
So that's exactly the same as your old PC... but it works?
Peter???
« Reply #18 on: April 29, 2016, 05:03:55 pm »
One thing I will try is just 3x 4GB modules...
« Reply #19 on: April 29, 2016, 05:15:49 pm »
With 3x 4GB modules I'm getting exactly the same error with exactly the same values shown on the screen...
« Reply #20 on: April 29, 2016, 05:32:53 pm »
If I would only know how to Google for such a thing.
Mani, what about that on-CPU graphics ? is it so or not ?
And if so, can't you shut that off all together ? (I think Coen did that in a far past)
PS: Thank you Joachim.
« Reply #21 on: April 29, 2016, 05:56:40 pm »
Under North Bridge config I can assign the primary graphics adapter as onboard or PCIe, and I can allocate the amount of 'share memory', currently 32MB. But I can't disable the onboard GPU.
I can try a PCIe graphics card at some point... sometime over the weekend now.
« Reply #22 on: April 29, 2016, 06:03:28 pm »
It has to be something like that ...
Huh !?
« Reply #23 on: April 29, 2016, 06:48:09 pm »
Couldn't wait until weekend...
Put graphics card in and... everything works perfectly!!!
 very happy very happy very happy
(I wonder what will happen if I pull it out?)
« Reply #24 on: April 29, 2016, 07:05:59 pm »
During the PC being On ? I wouldn't attempt that ...
Anyway, so THAT is it ...
Man, if you hadn't mention that GPU thing ...
Very good.
dsm
« Reply #25 on: April 07, 2020, 03:45:30 pm »
I am finally considering adding the RAM-OS but I just noticed this post.
I use an onboard GPU (ASRock Z97M Pro4) and was wondering if it is still the case that the RAM-OS will not load unless there is a separate PCIe graphics card.
Has anyone been able to get things up and running with in onboard GPU or do I need to get a graphics card?
David
phantomax
« Reply #26 on: April 08, 2020, 12:09:47 am »
Hello David,
I am using an  ASRock Z97M Pro4 without separate graphics card and I have no problem loading a RAM OS with 16 Gb RAM. Well, mine it isn't  the canonic Peter's RAM OS, but I think you will not have any problem.
Maxi
