November 25, 2024, 11:57:06 pm *
Author Topic: RAM -OS files do not load into 16GB memory  (Read 30224 times)
« on: March 11, 2016, 12:24:19 pm »
the RAM -OS files do not load into 16GB memory. See picture.
The motherboard is a
Gigabyte GA-Z97N-Gaming 5
http://www.gigabyte.de/products/product-page.aspx?pid=4999#ov
any idea?
Thanx
« Reply #1 on: March 11, 2016, 12:42:01 pm »
Hi Joachim,
I suppose you added things to the BASE version and *then* this does not load into RAM any more.
Is this correct ?
Also, how much disk space is available when you booted from the BASE version ? (a screenshot (/photo) of rightclick on C: - Properties, would be best for me).
« Reply #2 on: March 11, 2016, 12:51:48 pm »
W10 Base installed drivers only, no additional programs from my side.
« Reply #3 on: March 11, 2016, 12:59:25 pm »
Ok, thanks.
Can you verify that the 16GB of installed memory is really available ?
I am not even sure how to check this in a decent fashion ...
But something must be going on, as I have not seen this before (yes, with many things added to the BASE version, but you did not do that ...)
« Reply #4 on: March 11, 2016, 01:12:56 pm »
the new PC creates a lot of problems in addition. Music stutters during loading of music files. (Access of the HDD)
I will return the PC and think about the next step. So don't waste to much time with this problem.
« Reply #5 on: March 11, 2016, 01:41:18 pm »
Sorry to hear about your problems, Joachim !
Ask when needed. It is not a problem for me (finding the answers maybe Happy).
Maybe installing the MoBo drivers helps (that would be a good idea, actually).
Notice that you can store the "downloads" of it on drive D: as it showed in your picture. That is just the harddisk with 385GB or whatever free. From there, install them (just be in the BASE and refer to D:\[location].
Anyway, don't fill up such a BASE version.
« Reply #6 on: March 11, 2016, 02:11:46 pm »
this PC will be sent back tomorrow. The PC should have a passive cooling design with an additionall fan for extreme loads, but the fan was running all the time with a:
Utilization = 0%
Speed = 0,59 GHz
Maximum Speed = 1,6 GHz limited via the BIOS (off 3,6 GHz)
In the end the casing was a small heating radiator.
« Reply #7 on: March 11, 2016, 02:36:02 pm »
Sorry to hear that ...
Heads up !
« Reply #8 on: March 31, 2016, 01:56:50 pm »
Hi Peter, I'm trying to set up RAM-OS on my office PC. I have exactly the same issue that Joachim had (see pic and shot below). It seems that my 16GB of RAM is just shy of the required amount. I haven't loaded anything onto the base disk (not connected to the internet anyway).
Any ideas?
Edit: You'll notice that both Joachim and I got exactly the same message: total sectors calculated from partition table (26621952). This seems suspicious to me.
« Reply #9 on: March 31, 2016, 04:54:54 pm »
Hey Mani, when I first tried to us the RAM-OS I got the same message. I removed the ram from the mb and reinserted it into the same slots and it worked--no more error saying not enough memory. I have no idea why it worked but it did.
« Reply #10 on: March 31, 2016, 06:02:30 pm »
Hey Brian, thanks for the idea. But you must have been lucky. Just tried the same thing and it hasn't helped. Even tried changing slots but to no avail.
I wonder if I have one or more 'bad' RAM sticks. Unfortunately I don't have any spare and am reluctant to buy some new ones on the off-chance they might work.
Anyone else have any ideas?
« Reply #11 on: March 31, 2016, 06:35:55 pm »
I can see how easy it is to think this is wrong. But this is just how it oughts to be.
With two examples at hand now, I notice this :
In both your screenshots it says that 16GB of memory is installed but that 15.xGB is usable. Maybe it tells nothing, but my situation just says that 16GB is installed and nothing else (nothing about a usable amount).
Also notice that when I booted from RAM it nicely tells that 3.26GB is usable.
I really don't know, but I feel something like it could be suspicious that it doesn't say 16GB usable in your case(s). And with that, something very different may be the matter.
Mani, what does your other PC tell regarding this ? I mean, when booted from 10565 TRIAL (or maybe any BASE is OK just the same).
And no, I do not recognize at all that I made something for precisely 16GB. But notice that when it would be the case that 1 DIMM is failing (without further notice ?) you'll be in trouble indeed; see my "3.26GB usable"; with 4GB less, (4x 4GB assumed/intended to be in the system), that figure would turn negative ...
« Reply #12 on: March 31, 2016, 08:40:50 pm »
Thanks Peter.
See shot from my 'working' PC below. I think this shows that at least one of the memory sticks in my office audio PC are corrupt. Oh well, I'll just use W10 from disk for now.
« Reply #13 on: March 31, 2016, 09:58:53 pm »
Mani,
I really don't know. I just never oserved such a thing. So don't blame me if a next set doesn't work as well.
« Reply #14 on: April 29, 2016, 01:53:19 pm »
My new 4x 4GB memory sticks just arrived. I installed them in my office audio PC and just as before got only 15.7GB showing in ControlPanel/System. Of course, I got the same "... cannot fit into memory..." error message when trying to load W10 into RAM.
Going into mobo's bios, I found a 'shared memory' option for the built-in GPU. This was set by default to 256MB. I reduced this to the lowest option, 32MB. ControlPanel/System then showed the full 16GB of RAM available and I was elated. But then...
The OS still wouldn't load into RAM and I got exactly the same screen as before (Joachim's first post).
Not sure what's going on, but it's definitely not the memory modules. I suspect it's the mobo still hogging just a little memory (because of the built-in GPU?).
Peter, is there any way of easily lowering the RAM size required for the RAM-OS by only 32MB or so? I really hope there is because otherwise that was 150 Euros down the drain... and more importantly, no RAM-OS in my office  unhappy
Let me know...
Page created in 0.213 seconds with 19 queries.
