November 23, 2024, 06:17:46 am *
Author Topic: 'Settings' screen tips in print??  (Read 4955 times)
doublelife
« on: March 11, 2016, 11:52:30 am »
Is it possible to get a printable version of all the screen/tool tips that appear when your mouse hovers on a particular option? I'm thinking particularly all the 'Settings' options, the 'Q' options and the 'Filter' options. There is a LOT of additional info in these tips that can be hard to digest in the heat of the moment when one is struggling with setting x, y or z. This would be very useful to me, and maybe others, and give me some good bedtime reading....
PC  i7 / W10 10074 (x64) / hyperthreading ON (12 cores) / 32GB RAM / XX - OS on separate dedicated 256GB SSD - XXHighEnd: 2.03 / Engine#4 Adaptive / 4096 / Q1=14  / xQ1=10 / Q3,4,5=0/1/0 / SFS=4-120 / Straight Contiguous / Clock Resolution = 1.0  / Scheme 3-5 / 16x Custom / Peak Extend = OFF / Unattended / Minimize OS / Phase Alignment = OFF / XTweaks = 43, 100, 1, 1, 1 > 24/768 NOS1a 75B async USB DAC driver v1.0.4 1ms > KGSSHV Carbon amp > Stax SR-009
« Reply #1 on: March 11, 2016, 12:06:29 pm »
Hi there Paul,
If you hover over the controls, the ToolTip of concern appears, but the text of it *also* appears in the Help Area (reachable by means of the [ H ] button in the top).
From there you can copy-paste it into a document, which you can print. I think that you will even be able to see automatically which ToolTip got printed because of the sort of header in there. Just give it a look and tell me what you think.
