vrao
« on: March 05, 2016, 08:14:08 pm » |
Something to balance out the fun win W10
« Reply #1 on: March 05, 2016, 09:51:51 pm » |
Haha... an Alfa 4c! You won't believe this but I test-drove the 4c spider only 2 weeks ago. Loved the car, but three things stopped me from placing an order:
1. the lower switch-gear (knobs and controls) are very low quality 2. on cr*ppy UK roads, the steering is simply too difficult to control (the car follows every camber, nook and cranny - and there are loads of those here in the UK on our back B-roads) 3. I don't have the money sitting around spare :-(
If point 3 were not the case, I would go out and buy one today. Simply a fantastic car:
- carbon fibre monocoque tub - non-assisted steering (phenomenal on the track) - sweet 1.75 litre 240bhp engine (plenty of power for a sub-1000kg car) - totally, totally gorgeous on the outside (in both coupe and spider form)
VJ, yours looks stunning. I hope you drive the hell out of it, and not have it become a garage queen.
You obviously have good tastes!
Cheers, Mani.
vrao
« Reply #2 on: March 06, 2016, 12:19:22 am » |
Hey Mani, Thanks !! I agree with your assessment, but man it's my first Italian, and a refreshing experience to drive a driver dedicated car! Every time you get into it, it makes you feel special  Also in a city where supercars are as common as superstars, this stands it's ground! I'll be tracking it soon, no garage queen here :D Cheers, VJ
« Reply #3 on: March 06, 2016, 09:44:30 am » |
Yesterday we were watching The Man from U.N.C.L.E. (2015). What a deception. Ciska and Paul didn't know better, but I recall an Illya who is blond and actually weird looking (sorry David McCallum). It was about nothing and went nowhere. I told about the TV series from the 60's somewhere, but both never heard about it. When the yawning movie was finally finished I went to the PC, dug up some WikiPedia pages about the old stuff and referred to "see, the same as Kit - that too does not work any more. Give it a new car also does not help.". Then I thought to browse XXHighEnd as a last thing for the night and found this; With everybody in the mood I showed this and asked where this would be : Paul said : "At Mani's; all is flooded". Ciska said : "No, Mani lives in a high place; he won't get flooded. It must be at Paul's, as the River Thames is so high. So I scrolled up to precisely this position : (mind you, this was all what fitted in the monitor's view and I just scrolled it to exactly this point). Ciska right away said : at VJ's !  Then I had prepared this one as well : And Paul said "that's the c4". Yes, we have been discussing this car the other day as a really nice looking muscle car (while in the end it really is not that) and that you must see it in real life to have that perceptin for real (Paul did not agree as he never saw it real life). These days Paul cruises around in the Impreza WRX (he doesn't use the horse power in there yet) but that fact doesn't make him right. I love that car !! VJ, happy touring, man ! Peter PS: Didn't we discuss crazy USA STOP signs ? So did you plant that in your trees especially for me, or what is it ? haha
vrao
« Reply #4 on: March 06, 2016, 10:15:58 pm » |
Guys, That's incredible memory!! How many years has it been?! .... Wow!!! I watched that movie too, quite disappointed by it!! I looked into the WRX myself, it's a great car. Tweakers paradise, especially in CA with its thriving underground racing scene and third party modifiers.... still on the radar, decided can't give it that much attention right now! The AR-4c, looks like a muscle car in some angles, and not on some. By numbers alone it's not impressive, but surprises you by its performance again. I would call this smart engineering, and not just brutal force as most American muscle cars. Cheers, VJ P.s. Peter: The sign announces  Being played here
Jud
« Reply #5 on: March 07, 2016, 12:41:33 pm » |
Beautiful - how is it Italians do red like no one else?
Alfa being involved in F1 this year unfortunately fell through.
(Getting ready for the new season - almost here!)
Win 7 64-bit; i7-950@3.07GHz; 16GB RAM; OS on SATA 6GB/s SSD; AIFF files on external FW HDD; XXHE and Playback Drive on separate RAMdisks; no page file; Audioquest Dragonfly DAC/preamp; PSE Studio IV amp; Pioneer SP-BS22-LR bookshelf speakers or Etymotic Research ER-4P in-ear monitors. XXHE 0.9z-8-3a settings for the moment: Peak Extend; Arc Prediction; Redbook files upsampled 2x; KS Adaptive Mode; Phase Alignment off; buffer=512; Straight Contiguous; Playerprio=Low; ThreadPrio=RealTime; Unattended; OS minimized; all services off; Q1=17, factor=2; SFS=2.1; XXTweaks=Ultimate; Time Performance Index=Not the best.
briefremarks
« Reply #6 on: March 08, 2016, 06:56:34 am » |
VJ,
Very nice machine. Looking forward to seeing it soon. I've been traveling (again!).
Owned a number of alphas in the past, spiders, duettos, GTV, nothing like this one. The big surprise was how extremely reliable the drive train was, even though everything else (handles, tops, knobs, etc.) slowly fell apart.
vrao
« Reply #7 on: March 08, 2016, 07:56:57 pm » |
Ramesh : I'll be not surprised if the 4C is similar!! cr*ppy interiors ... lol Looking forward to your visit. Jud: AR continues its usual troubled existence. Aah the red ... perfectly meets 4C
vrao
« Reply #8 on: May 21, 2016, 05:17:10 am » |
Handmade at this catagory hardly ever seen http://youtu.be/yde6Nbxdq-I
« Reply #9 on: May 21, 2016, 09:44:36 am » |
vrao
« Reply #10 on: May 21, 2016, 03:21:08 pm » |
Yup! Well known
vrao
« Reply #11 on: December 10, 2016, 09:27:16 pm » |
Hotel California album cover inspiration Currently in "Cal State Channel island University" https://g.co/kgs/tbgw7r***Edit: apparently not the right location... what a spectacular drive to this location.  Will redo in a few
vrao
« Reply #12 on: December 10, 2016, 09:51:24 pm » |
Strawberry fields for ever Some parallels with Oxnard, CA.... the strawberry capital of the world. https://g.co/kgs/0R3Zr6
vrao
« Reply #14 on: December 11, 2016, 03:26:06 am » |
Hotel California album cover inspiration Currently in "Cal State Channel island University" https://g.co/kgs/tbgw7r***Edit: apparently not the right location... what a spectacular drive...  Will redo in a few
