November 22, 2024, 08:39:15 pm *
Pages: 1 2 [3] 4  All
Author Topic: Remote Control + RAM-OS  (Read 40919 times)
Tore
« Reply #30 on: March 02, 2016, 01:41:38 pm »
nr.1
« Reply #31 on: March 02, 2016, 01:45:20 pm »
Keep in mind that for #2 there's something special the matter. So for later.
« Reply #32 on: March 02, 2016, 01:55:46 pm »
This shal not be easy
Tore, I am afraid you are right.
Did you set up the OS for that PC yourself ?
Tore
« Reply #33 on: March 02, 2016, 01:59:56 pm »
OK, i have manage to login from Ipad to Music-PC  Nice
« Reply #34 on: March 02, 2016, 02:20:50 pm »
Tada ...
Can you tell me what that password problem was ?
Just for the next one (or the next time Wink).
Tore
« Reply #35 on: March 02, 2016, 03:44:35 pm »
First i made a username and password inside RD Client on Ipad.
When i was trying to connect from Ipad i was asked for username and password. Then i was using that username and password, but it don`t work.
« Reply #36 on: March 02, 2016, 03:52:34 pm »
Ok, but what solved it in the end ?
Tore
« Reply #37 on: March 02, 2016, 04:06:25 pm »
Then i deleted username and password in RD Client
I made a password to the Music-PC
When i connect from RD Client in Ipad i`m asked for username and password. Username=PC-name   Password=PC-password
The only thing to put in RD Client is the IPv4 adress
Tore
Tore
« Reply #38 on: March 04, 2016, 09:39:42 am »
Hi Peter!
Can you guide me true next step ?  Remote Ipad to Audio PC
Tore
« Reply #39 on: March 04, 2016, 01:21:50 pm »
Hey Tore,
Next step is Music Server PC to Audio PC.
I talked about that a couple of posts back. But instead you got iPad to Music Server PC running, which is also needed, so, good !
« Reply #40 on: March 04, 2016, 01:25:47 pm »
This is what I said earier (I cut out irrelevant stuff) :
What you could do in this stage, is trying the same with your Audio PC and Music Server PC.
The topics 1-10 must now be performed on the Audio PC and the RDC screen (see in that Tutorial) is to be set up on the Music Server PC.
If possible, use a direct connection from Audio PC to Music Server PC (and not via a router/switch/etc.). This is not a real requirement but it is more easy to do and in the end faster as well.
Tore
« Reply #41 on: March 06, 2016, 05:16:04 pm »
Hi Peter!
Now i have two PC`s to connect on the Ipad RDC, Music PC and Audio PC.
No problem to connect to Music PC.
When i try to connect to Audio PC the message from RDC is: check that PC is set to Remote
Audio PC is connected with direct connection to Music PC
I have been reading this: http://www.phasure.com/index.php?topic=3213.0
and this: http://www.phasure.com/index.php?topic=3057.0
Tore
« Reply #42 on: March 07, 2016, 08:16:55 am »
Hi there Tore - so you make progress ! And almost done, as it looks like.
This is your aim :
1. Make connection from Music Server PC to Audio PC.
-> So now the Music Server PC could control the Audio PC;
-> This would happen when you go to the other floor and type on the Music Server PC's keyboard.
-> Let it be like this and proceed with step #2, below.
2. Make connection from iPad to Music Server PC.
-> So now you can control the Music Server PC.
BUT
-> The music Server PC is still controlling the Audio PC.
-> Thus you are controlling the Audio PC by means of the tablet (and via the Music Server PC).
Works ??
If it works, the next step is to scale them all correctly (so that circles remain circles and not become eggs).
Tore
« Reply #43 on: March 07, 2016, 09:00:19 am »
Peter, hi!
How do i make connection from Music Server to Audio PC?
Tore
« Reply #44 on: March 07, 2016, 09:15:50 am »
Hi Tore,
Read back in this topic (from bottom to top) and you will run into it. I told it two times in this topic alone, a third time in that other topic (there it was the first time I told about it). All addressed to you.
If you have a specific problem you can talk about it. But such a question "how do I do it ?" ... that is too much for me.
Page created in 0.116 seconds with 19 queries.
