Tore
« Reply #15 on: March 02, 2016, 09:05:11 am » |
I did a winrar update and the unzipping is OK
The problem now is that XX 2.04 will not start playing (paypal) XX message is "lower SFS" (error 03)
The only Sound Device to choose is S/PDIF Audio + HDMI Audio
Tore
Phasure Mach III, 12/24 core (Win 14393.0 on RAM-OS / controlled by RDC, / connected directly to music server / XXHighEnd 2.11 / Minimize OS / Engine#4 Adaptive / DB=4096 / Q1=10 / xQ1=15 / Q3,4,5=1 / SFS=0.69 max=140,19 /XTweaks = 35, 10, 0, 0, 0 / Straight Contiguous / Clock Resolution = 15ms / Scheme 3-5 (low/realtime) / Unattended) mobo USB3 port -> Lush^3 -> Phasure NOS1a B75 G3 -> Blaxius^2.5 , Crazy A monoblocs, Avantgarde Duo Omega
« Reply #16 on: March 02, 2016, 10:07:20 am » |
Well, did you set the SFS and SFS Max at 4 or so ?
Tore
« Reply #17 on: March 02, 2016, 10:26:57 am » |
Yes, and i think i have tested everything
« Reply #18 on: March 02, 2016, 10:36:57 am » |
Set the Memory Type to Mixed (not a Contiguous type) - that has to help. And you don't use it for real playing anyway, right ?
Tore
« Reply #19 on: March 02, 2016, 10:58:24 am » |
I don`t use it for real playing
I have tested mixed again, message : unsupported format
SFS= 4 , no upsampling, DAC setting 16bit, 44,1KHz
« Reply #20 on: March 02, 2016, 11:06:30 am » |
Tore,
I already told you how to use it with the MoBo sound device. See back in the topic. Or ?
Tore
« Reply #21 on: March 02, 2016, 11:09:50 am » |
I have seen that, how do i do ?
« Reply #22 on: March 02, 2016, 11:13:38 am » |
Now I don't understand the question. If you have seen it, please quote it here, so I can see what you saw. Ok ?
Tore
« Reply #23 on: March 02, 2016, 11:23:28 am » |
How do i pick MoBo sound device?
Have you seen this: The only Sound Device to choose is S/PDIF Audio + HDMI Audio (in XX)
« Reply #24 on: March 02, 2016, 12:32:16 pm » |
Tore, that is the MoBo (Motherboard) sound device ...
I don't know where I said it, but it is easiest like this :
Find a 24/96 file and upsample 1x. This must play.
Maybe 16/44.1 also plays with Upsample 2x.
Tore
« Reply #25 on: March 02, 2016, 12:34:12 pm » |
I removed the HDMI cabel from PC to screen and it is working
« Reply #26 on: March 02, 2016, 12:34:26 pm » |
Here I said it - and it was especially for you : Good. We will get there now ! just step by step (if that's OK with you). Now : That motherboard will have an audio device too. Select it (if not already) and try whether it works with 2x upsampling and a random album. Don't forget to switch off "Is NOS1". No need to get real sound from it, as long as the time cursor starts running. Just Attended (well, like how you do it always). If you keep on receiving error messages it will be about your MoBo supporting 48KHz "base" only. You may then want to switch on "96 Khz or192 KHz Only" (in DAC Settings). Or find a 24/96 album (and maybe not upsample now). Play a bit as usual. Go to PayPal, as usual.
« Reply #27 on: March 02, 2016, 12:35:02 pm » |
I removed the HDMI cabel from PC to screen and it is working Ha !
Tore
« Reply #28 on: March 02, 2016, 12:58:32 pm » |
OK, back to start Ipad is setup but password is wrong. I have uninstalled RD Client and picked i new username and password but i still get the wrong password message? This shal not be easy
« Reply #29 on: March 02, 2016, 01:38:50 pm » |
Ok, pay attention please :
1. Are you trying to login from the iPad to the Music Server PC ? or 2. Are you trying to login from the iPad to the Audio PC (XXHighEnd PC) ?
