Tore
« on: February 27, 2016, 04:34:05 pm » |
OK Peter, if you have time i`m ready
The times i have tested this i think i have done somthing wrong with the ipad/RD Client. I get this message : you alredy have one remote or something like that.
Tore
Phasure Mach III, 12/24 core (Win 14393.0 on RAM-OS / controlled by RDC, / connected directly to music server / XXHighEnd 2.11 / Minimize OS / Engine#4 Adaptive / DB=4096 / Q1=10 / xQ1=15 / Q3,4,5=1 / SFS=0.69 max=140,19 /XTweaks = 35, 10, 0, 0, 0 / Straight Contiguous / Clock Resolution = 15ms / Scheme 3-5 (low/realtime) / Unattended) mobo USB3 port -> Lush^3 -> Phasure NOS1a B75 G3 -> Blaxius^2.5 , Crazy A monoblocs, Avantgarde Duo Omega
« Reply #1 on: February 27, 2016, 05:19:10 pm » |
Ok, so first you are going to connect an iPad to the Music Server PC. Agreed ?
On the Music Server PC :
1. Start Explorer. 2. RightClick on ThisPC (or whatever it is named); 3. Choose Properties; 4. In the left top, click Remote Settings; 5. Check Allow Remote Assistance connections to this computer; 6. In the bottom section select Allow remote connections to this computer; 7. Click OK.
8. Start a command prompt (cmd fron Run under the Start Button); 9. Type : IPConfig [enter] 10. Write down the IP Address listed behind "Autoconfiguration IPv4 address" (or similar, but something with IPv4 in it, not IPv6).
On the iPad : 1. Find RDP (just from Windows !) in the Apple Store and install it (it is free). 2. I must find out myself at this moment. Haha. But if you are familiar with that part, use the IP Address you wrote down under 10 above.
There's a little bit more to this for proper settings and scaling, but let's start with this.
Tore
« Reply #2 on: February 27, 2016, 06:07:29 pm » |
OK, i`m on the Ipad with the Windows RDP app.
Under "Gateway" i have the IPv4 address from the Music PC
But now i don`t know what to do?
« Reply #3 on: February 27, 2016, 06:25:50 pm » |
There should be nothing under the Gateway section. And what I see myself over here is this (but I already have a "desktop" created) :
There's an account and it has a Username and Password (probably you already finished that step as it is above "Gateway"). Notice that this will be the Account Name and Password of the Music Server PC. This is actually all I filled in and we can see that later by means of the "service wheel" in the top left of the general screen. Now :
Once you have this desktop, hold your finger on it until at the bottom right corner a service wheel appears. Click that.
Now you see PC Name at the top, and it is there where the IP Address goes. The second line is the Account Name you filled in (see by text above).
Then lastly in that screen there's Settings and in there I again have no Gateway (possibly you are stuck at this moment right on that screen - hard for me to tell). Sound : Play on device. Leave mouse buttons as they are unless you are left handed. I have Admin Mode switched on.
I think that should be all.
Tore
« Reply #4 on: February 27, 2016, 06:41:36 pm » |
all that is OK on the Ipad now but it will not connect What about all this? http://www.phasure.com/index.php?topic=3213.0
Tore
« Reply #5 on: February 27, 2016, 06:51:24 pm » |
The message on Ipad when it is not connecting: check that external desktop is on
Tore
« Reply #6 on: February 29, 2016, 12:46:37 pm » |
Peter, do you have any idea about what to do?
I think i have done pkt 5-6-7
Tore
« Reply #7 on: February 29, 2016, 01:04:20 pm » |
Hi Tore, Sadly I have no idea. What you could do in this stage, is trying the same with your Audio PC and Music Server PC. Possibly that brings some insight plus it should be slightly easier to do. And for that you can indeed use this : Btw, I just looked in there and my eye fell on the "Password is required" ... do you use a password in the Music Server PC ? you must, otherwise it does not work. The topics 1-10 must now be performed on the Audio PC and the RDC screen (see in that Tutorial) is to be set up on the Music Server PC. If you can get this running, you may have a better feeling about the other connection, which is then just iPad stuff (but a bit depening on how your LAN is organised). If possible, use a direct connection from Audio PC to Music Server PC (and not via a router/switch/etc.). This is not a real requirement but it is more easy to do and in the end faster as well. Regards, Peter
Tore
« Reply #8 on: March 01, 2016, 10:19:37 am » |
The problem with the Music PC is Windows !0 Home, not Pro I only have remote Assistance Tore
« Reply #9 on: March 01, 2016, 10:31:59 am » |
Tore, that explains it. I am not even sure whether you now talk about the Music Server PC -> Audio PC connection, but at least the iPad -> Music Server PC won't work because of this. Anyway, now people know why I am always saying that Home is no good; No RDC possible ... Stupid stuff ... Peter
Tore
« Reply #10 on: March 01, 2016, 10:38:22 am » |
I have a PC with W10 Pro, then i need one more XX licence
Tore
« Reply #11 on: March 01, 2016, 11:30:38 am » |
That is fine of course.
Don't give up !
Tore
« Reply #12 on: March 01, 2016, 04:45:25 pm » |
Peter, the other PC have W10 Pro 32 bit. Is 32 bit a problem?
Tore
« Reply #13 on: March 01, 2016, 06:53:25 pm » |
Tore,
Unless I forget something (and that can happen !) I don't think so. But keep in mind that you need XXHighEnd 2.04c for that (for Tidal). Thus :
Download and unzip the main .rar. After that download and unzip the smaller 2.04c .rar over that.
Side note : I think I know quite a lot about the W10 sh*t and licensing. But I really don't know what happens when you have a 32 bit version and want to upgrade to 64 bit. It should be allowed ... But literally upgrading would not be possible. Anyway notice that Microsoft servers will know about your W10 license (assumed it is activated). So would you wipe the disk in that PC and next install a new W10 version (like 64 bits now) you would automaticaly be activated. I am not saying that you must try this, but if you like you can and it should be free.
Kind regards, Peter
Tore
« Reply #14 on: March 01, 2016, 06:59:02 pm » |
I have problems with unzipping XX 2.04, i get error messages from winrar
Is it 32bit that is the problem?
Tore
