April 08, 2025, 06:43:11 pm *
Author Topic: VNC and Remote Desktop on Vista  (Read 8824 times)
datawolf
« on: January 27, 2008, 01:39:03 am »
I've just set up my 'record player' a Vista Ultimate system with plenty of DAS and XXHE works great.
I wanted to put that system in the attic and remote control it using UltraVNC but...
When I log onto the system from my workstation I can see everything except XXHE which is really wierd.
So... XXHE is invisble.
I've tried everything I can think of but no luck.
I tried using Remote Desktop and it worked perfectly but ofcourse you can't 'share' a session on the remote system which is very useful and in fact RDC makes simple tasks rather awkward.
Any ideas on a solution?
Apart from all this non audio stuff, XXHE sounds absolutely terrific.
Roni
« Reply #1 on: January 27, 2008, 09:13:22 am »
Hi Roni,
Are you sure it is XXHighEnd which is not visible ? I mean, you don't talk about the Wallpaper ? the Wallpaper indeed won't show unless it is reshown by the software. Well, that's what I know from RDP.
Otherwise I really really can't imagine how it is even possible in theory.
Page created in 0.021 seconds with 19 queries.
