April 05, 2025, 06:00:27 am *
Author Topic: Q5 issue  (Read 19858 times)
« Reply #15 on: February 23, 2016, 09:06:29 am »
One more thing :
Is it possible, please, to at least for one time mention your name ? I'm having difficulties with who is who and hwk doesn't tell me much.
If you want to keep it secret, then fine. But if you don't care then I do (I think we all do Happy).
Thanks !
hwk
« Reply #16 on: February 24, 2016, 10:40:03 am »
Henk-Willem is the name...We met already two times at Veldhoven.
But more important: the problem is solved!!!!!
As you and Johan suggested: I changed the Processor Scheme to NOTHING, restarted and the problem was no longer there. Sorry I missed the suggestion earlier. Did I already said I'm sorry?
With a Little Help from My Friends......
A small issue did pop up however:  when I changed the Processor Scheme on the SETTINGS page and then restarted, the Processor Scheme under the Q button still indicates CORE 1-2
I play now again with Core 1-2 on both places and no troubles anymore.
I will play with the XTweaks as you suggested  another time, for the beautiful sound I hear now doesn't make me eager to change anything at all.
I'll change my profile with the new settings, so other i3 users might profit.
Best Regards, Henk-Willem
Music Dedicated PC, Power: Silverstone Nightjar 300, MB: ASRock H87M Pro4 + I5 4570T + 4GB, Internal Memory: 16Gb Kingston DDR3-1333,  500Gb Crucial MX500 SSD with W10 Build 14393.0, 2x 4Tb WD 40EZRZ HDD for Music only), Soundcard: Seriously Modified Prodigy HD2 PCI Card 24 Bit/192 KHz with Amplimo's (van GooiPC), W10 10586-11 Home Edition 64bit
XXHe 2.11: KS mode: Special, Device Buffersize: 1024; Processor scheme: CORE 3-4; Player Prio: Below Normal, Threadprio: Above Normal, Clock Res.: 10 msec; HDCD on; SFS: 105.19,  Mem.Org.: Mixed Cont.; Q's=13x10,0,0,0; PE: Off, Custom: On; Playing Mode: Min.OS; XTweaks= On Indicates: "OPTIMAL": Bal.Load=45, Nervous Rate=99, rest=1  -  Sound Gear: Meridian 502 PreAmp (upgraded), 588 CD, 2x 505 MainAmp (upgraded) (all balanced driven), Speakers: Magnepan 3.5 SE, extra: Aphex 204 Aural Exciter; Cables: CD>Pre: Siltech SQ88, PC>Pre & Pre>Dedicated Headphones Class A Amplifier: John van Gent Reference+, Amplifiers>Speakers: Discovery 4; Headphones: AKG K1000 & Ultrasone Pro550 + dedicated Class A amp; Music Dedicated Power Group (copper shielded main cables + Oyade plugs) with parallel noise filter for the main-amps and PS Audio Quintet for the front-end. Analog: Micro Seiki DD33 modified, Denon301
« Reply #17 on: February 24, 2016, 12:10:44 pm »
Hi Henk-Willem,
Super !!
I will look what happens with this selection of "Nothing" and that it won't stay. Should be some bug ...
Best regards !
