April 05, 2025, 05:30:14 am *
Author Topic: Small Pane Issues  (Read 9825 times)
hwk
« on: February 15, 2016, 05:41:19 pm »
Since a week or so I'm using XXHe204 with W10 Home Edition.
I'm very, very content with the sound quality.
In my system it's a huge leap forward in quality compared with the sound  from version 1.186a. Thank you!
I've still a small amount of questions/issues for you:
In my music dedicated computer system I use a small (10") VGA screen.
I've played a bit with the screen settings from XXHe and have now a reasonable looking UI with a convenient 4 rows of thumbnails.
The settings concerning the screen and coverart are now:
Skin Settings: Scale Factor 1.20.
If I use "Apply CoverArt Background Image to Empty Area Only" I've the message on my screen after starting up XXhe:
"Show CoverArt from Actual Album - 2147417834- Er kan niet worden uitgebeld  omdat de toepassing een asynchrone aanroep verzendt. (Uitzondering v. HRESULT: 0x80010100 (RPC_E_CANTCALLOUT_ININPUTSYNCCALL))" So I don't use it.
What is the use of this choice anyway?
Every time I start XXHe, slider 2 is set to the left while I saved the settings with it way to the right (I never use the "Show Data" button at all)
Is this normal? For I find it a bit tiresome that I have to reset it every time (although less annoying than before when also with every time a playback was finished, the slider was set a bit to the left and the number of showed rows of thumnails was smaller..)
Is this a standard "issue" or can it be changed in a way?
What is the use of the slider on the mainscreen for the CoverArt Pane Picture Size? It doesn't effect anything...
Best Regards, HW
Music Dedicated PC, Power: Silverstone Nightjar 300, MB: ASRock H87M Pro4 + I5 4570T + 4GB, Internal Memory: 16Gb Kingston DDR3-1333,  500Gb Crucial MX500 SSD with W10 Build 14393.0, 2x 4Tb WD 40EZRZ HDD for Music only), Soundcard: Seriously Modified Prodigy HD2 PCI Card 24 Bit/192 KHz with Amplimo's (van GooiPC), W10 10586-11 Home Edition 64bit
XXHe 2.11: KS mode: Special, Device Buffersize: 1024; Processor scheme: CORE 3-4; Player Prio: Below Normal, Threadprio: Above Normal, Clock Res.: 10 msec; HDCD on; SFS: 105.19,  Mem.Org.: Mixed Cont.; Q's=13x10,0,0,0; PE: Off, Custom: On; Playing Mode: Min.OS; XTweaks= On Indicates: "OPTIMAL": Bal.Load=45, Nervous Rate=99, rest=1  -  Sound Gear: Meridian 502 PreAmp (upgraded), 588 CD, 2x 505 MainAmp (upgraded) (all balanced driven), Speakers: Magnepan 3.5 SE, extra: Aphex 204 Aural Exciter; Cables: CD>Pre: Siltech SQ88, PC>Pre & Pre>Dedicated Headphones Class A Amplifier: John van Gent Reference+, Amplifiers>Speakers: Discovery 4; Headphones: AKG K1000 & Ultrasone Pro550 + dedicated Class A amp; Music Dedicated Power Group (copper shielded main cables + Oyade plugs) with parallel noise filter for the main-amps and PS Audio Quintet for the front-end. Analog: Micro Seiki DD33 modified, Denon301
« Reply #1 on: February 15, 2016, 06:04:13 pm »
Hi there HW,
No, nothing you tell there I regard to be intended. But now what's going on ...
First off, I will try with that 1.20 Scaling Factor and see whether that's maybe too small for some things (I never try it that small). What is the resolution of your screen (like 640x480 etc.) ?
LOL That must be some fine Windows translation. Anyway it is not mine. "Uitgebeld" should be something like "called" (like in calling a program). I can imagine the message but I never heard of it. Fair chance that this is wacky W10 or even the Home edition (I don't think I know of anyone using Home).
Well, it should - size the pictures in that pane. But it is my bet that you don't show anything in that pane.
Notice that to the right of the LAn On button there's a combobox with Playlist Name. Under that there's a Save button and under that a Show Data button. That one must be active.
(and I am saying this all because probably you don't see that button because of your small screen in the first place).
I'll be back when I know more. Let me know your resolution.
hwk
« Reply #2 on: February 15, 2016, 08:20:38 pm »
HI Peter,
the resolution of my screen is 1024x600.
Q. re.the slider: the pane you're referring to: is it the pane left with the thumbnail or the pane right (for the data)
Best Regards, HW
hwk
« Reply #3 on: February 15, 2016, 10:07:16 pm »
BTW: I also get the message: "Show CoverArt from Actual Album - 2147417834- Er kan niet worden uitgebeld  omdat de toepassing een asynchrone aanroep verzendt. (Uitzondering v. HRESULT: 0x80010100 (RPC_E_CANTCALLOUT_ININPUTSYNCCALL))" also with  "Apply CoverArt Background Image to Empty Area Only" not "On". So I Always get this message when I start up XXHe...
What other setting could give this effect?
Best Regards, HW
« Reply #4 on: February 16, 2016, 08:42:46 am »
The rightmost pane, with my explicit mentioning of 3 panes being there (not two, which is what you might think). Drag the [ 2 ] slider to the left to see it.
« Reply #5 on: February 16, 2016, 06:24:03 pm »
Is this normal?
Can it be so that this happens because you use the "maximized" screen (of XXHighEnd) ? Thus, does this also happen when you drag the right hand screen border to the left a few cm - same with the bottom border up a bit ?
Just to try so I know what is happening ...
« Reply #6 on: February 16, 2016, 06:33:06 pm »
"Show CoverArt from Actual Album - 2147417834- Er kan niet worden uitgebeld [...]
I have just been trying for 35 minutes - in all combinations imaginable - to let this go wrong. But I can't. Not in Windows 7 and not in Windows 10 Build 10586.0. So it should be either of this :
The Home edition of Windows 10 you use there;
The Windows 10 specific Build;
The combination you have in order and which I apparently can't find.
So notice that in my view the error can only happen when you also have an image file in the "Coverart Background Image" field, and or you have that "Show Data" button active (the one I talked about earlier and of which you say that you don't use it anyway).
It won't be helpful much, but notice that this is about something you see below - denoting an image which shows where you see the "flakes" (black and white) of the image I chose for pointing it out. So if you can survive with not having such a thing ... I really don't know where to go when I can't copy the behavior ...
hwk
« Reply #7 on: February 18, 2016, 01:48:15 pm »
You were right: it was the "maximized" screen as set in the properties of the desktop icon of XXHe.
Since I set this to Normal, I don't get the strange message anymore. Futhermore I believe Slider 2 stays in the position I want it to. So, these problems seems to be solved.
Thanks.
Did I mention already, that I like the sound of XXHe very, very much?  Wink
Best Regards, HW
