November 23, 2024, 08:07:28 pm *
Author Topic: Reset to initial Startup  (Read 5690 times)
« on: February 10, 2016, 11:12:16 am »
Hi Peter, in the Save as button when we make right click appears a window that says Reset to initial Startup? Does it mean the original settings that comes in the Ram-disk? I mean, the very first ones?
« Reply #1 on: February 10, 2016, 11:22:25 am »
Hi Juan,
No !!
The working of that button (RigtClick) did not change (ok, it did a little as I recall but this is technical);
What that does is reset your XXHighEnd install to initial values. Say similar as that you would select the "PresetLoader - FreshInstall.XXSI" file for loading back settings. You would lose all of your settings, including Activation. It is a sort of emergence button/procedure for when all was messed up (for whatever reason). Some times I ask people to use that in order to overcome problems.
Ok ?
PS: When you want to go back to the original RAM-OS settings, copy the file as indicated in the Backup/Restore Tutorial of the RAM-OS stuff.
« Reply #2 on: February 10, 2016, 11:34:34 am »
Thanks Peter
Page created in 0.154 seconds with 19 queries.
