November 23, 2024, 06:08:51 pm *
Author Topic: Activate Windows Message  (Read 8655 times)
« on: February 08, 2016, 12:37:47 pm »
In Ram OS I am getting a message in lower right of screen to go to settings to activate windows, but when I boot into the base version there is no activation message. Do I need to do anything?
« Reply #1 on: February 08, 2016, 12:56:15 pm »
No.
And probably when you boot into the (a) RAM version there's also no message visible. Yes, the next day or so. Same with the (a) BASE version.
Can I be right ?
« Reply #2 on: February 08, 2016, 01:19:17 pm »
While I know that the question is not addressed to me, I can say that it takes less than 24 hours to trigger that activation thing, but a reboot does the trick Happy It does not really bother me. Anyway, I experienced this with Windows 8 also and my copy was activated, so... No real problem for me Happy
« Reply #3 on: February 08, 2016, 01:31:08 pm »
I think you are right Peter, I'll check tonight when I will initially boot from the base before going into the RAM version. Like Alain said, it really is no problem, just wanted to make sure. Thanks!
« Reply #4 on: February 08, 2016, 02:40:59 pm »
What Alain just rightfully reminded me of, is that no matter what, in MinOS the message is there anyway (after whatever certain time). So even if you are activated.
It doesn't bother me (as it shines through only vaguely). And when in Unattended nothing of it shows. Wink
« Reply #5 on: February 09, 2016, 01:17:57 pm »
So this message actually has nothing to do with the dates in BIOS and the OS being too old?
« Reply #6 on: February 09, 2016, 02:19:26 pm »
No ...
