April 06, 2025, 12:15:09 am *
Author Topic: NOS1 (not NOS1a) driver: 1.03 or 1.04 ?  (Read 14095 times)
« on: January 28, 2016, 01:44:18 pm »
Am I right to assume that the driver for the NOS1 (not the "a" version) needs to stay with the 1.03 driver ?
If so, do I need to rename an extension for another to allow the right driver to be used ?
In other words, what is the sequence I should follow to have the correct driver used (remove the 1.04, then install the 1.03)...
Thanks
« Reply #1 on: January 28, 2016, 01:50:20 pm »
Hi Alain,
If all is right the 1.04 Driver works for NOS1 and NOS1a.
So if you're talking about the RAM-OS Disk, you can leave all as it is and it should work.
Test with switching between 44.1 and 48 based material (and watch whether the speed is OK - just stopwatch a track for its expected length).
« Reply #2 on: January 28, 2016, 02:11:15 pm »
Super Happy This evening I will listen for the first time to the OS-ram drive Happy
Page created in 0.022 seconds with 19 queries.
