April 05, 2025, 07:12:47 pm *
Author Topic: RDC in RAM-OS cannot connect  (Read 6585 times)
« on: January 28, 2016, 11:38:07 am »
SO I am in w10586 BASE on the RAM-OS HDD that you sent out in Normal OS XXHE (so the os should be largely operational) and I am setting up a wired ethernet connection from another computer (which will be used as a server) with the AudioPC.
The networking is fine and I can shoot files back and forth between the two directly wired computers and I have made shares and added them to XXHE on the AudioPC for the Music Root and Tidal files and they all work well and I can play music using the music files stored in the Music Server.
But what I cannot do is connect RDC from the Music Server to the AudioPC.  I set up RDC and even followed your tutorial when it did not work the first time (the process was exactly the same) but it just will not connect...apparently I am using the wrong password or account.
On the AudioPC I have not changed the windows login at all so it is still user "XXHE" and pword "xx"...but it does not work.
Any clues?
« Reply #1 on: January 28, 2016, 12:02:59 pm »
Hey Anthony,
Maybe you can link me to that Tutorial you read ? so then I know what you read and thus did/tried.
The only thing I can think of right now is that you did not obtain the proper IP address from the Audio PC (thus from the OS involved). Btw, the IP address is different per OS in there but it is always the same for BASE and adjacent RAM version.
Can that be it ? (I know, too simple for being the problem, but ...)
And of course *use* that IP address (at the remote), and not the PC Name etc. But this is a known thing ?
Let me know ...
« Reply #2 on: January 28, 2016, 10:17:29 pm »
I followed this tutorial  http://www.phasure.com/index.php?topic=3213.0.
I've definitely got the ip address correct because it pings just fine from Music Server.
« Reply #3 on: January 28, 2016, 10:55:07 pm »
Well, that was interesting.  I am normally very reluctant to use a computer name when setting up RDP and always tend towards the ip address, but just now I replaced the ip address with "RAM-OS" (the computer name) and everything just worked.
So it is working...somehow without the ip.
