April 05, 2025, 10:33:08 am *
Pages: 1 2 [3]  All
Author Topic: Windows Defender  (Read 31704 times)
« Reply #30 on: January 27, 2016, 10:40:26 am »
And dont forget to unminimize in BASE.
tillen
« Reply #31 on: January 27, 2016, 11:20:56 am »
OK Arnt, then I suppose that should be solved first, with the notice that one might remain :
See at the mouse pointer. I never could/can get rid of that and I don't even know what it is (maybe other people know ?). So I always disable that (see little black arrow).
It playes all right for now, hope it lasts.
Have disabled the suggested Device.
But there are many more. all of them are Intel Devices.
PC- Asrock X79 Extreme 4-M -
« Reply #32 on: January 27, 2016, 12:01:42 pm »
Hmm ... that doesn't look te best. Happy
Go to the BASE and make that Normal OS as Gerard suggested.
In the c:\Installs folder (of each OS) there's an "ASRock xx 64" folder (it is named something like that (van be 8.1 in there which is fine) and I do not refer to the "ASRock Extreme Tuning" folder. Now :
In there, there's an INF folder. Run the Setup.exe and notice that it really can take two minutes before something gets back to you.
N.b.: When you're asked to reboot, just do that.
Next do the Sata folder (setup.exe in there).
Next the LAN.
Next the USB.
That is all.
What does that bring ?
tillen
« Reply #33 on: January 27, 2016, 12:43:40 pm »
Seems to be ok, no missing Devices anymore ;-)
« Reply #34 on: January 27, 2016, 12:50:26 pm »
Ok, case closed for now. I mean, now all should be and remain fine. And when not ... well ... we will see about that then.
Now, back to MinOS and from there to RAM.
Btw, officially this should be done for the other OSes just the same. So if you are going to try one of the others, don't forget about this, ok ?
Well done !!
tillen
« Reply #35 on: January 27, 2016, 01:16:16 pm »
Ok, thanks for now
Arnt
Pages: 1 2 [3]  All
