April 05, 2025, 08:07:53 pm *
Pages: 1 [2] 3  All
Author Topic: Windows Defender  (Read 31718 times)
« Reply #15 on: January 27, 2016, 09:39:34 am »
Side note :
I saved my 10565 same (?) situation, so I should be able to debug that ...
tillen
« Reply #16 on: January 27, 2016, 09:43:29 am »
1. I can not do anything, because I can not come out of unattended playback when I try alt-x. Then " XXHIGHEND stopped working " Message appeares
PC- Asrock X79 Extreme 4-M -
« Reply #17 on: January 27, 2016, 09:52:20 am »
Aha ...
Does Alt-R work ?
It should bring back the desktop. But possibly it goes wrong for the same reason.
tillen
« Reply #18 on: January 27, 2016, 09:54:32 am »
No it does not, for the same reason.
« Reply #19 on: January 27, 2016, 09:56:18 am »
Is this a boot from RAM ?
If yes, just reboot.
You must of course hard-power off for that. But this is no problem.
If it is a boot from the BASE version, just do nothing but tell me.
tillen
« Reply #20 on: January 27, 2016, 09:58:05 am »
It is a boot from RAM.
Rebooting now, just a minute.
« Reply #21 on: January 27, 2016, 10:00:42 am »
Meanwhile my "bad" denoted 10565 is just fine or I forgot what was the matter with it.
So that is not much helpful.
tillen
« Reply #22 on: January 27, 2016, 10:10:35 am »
I have rebooted into 10856 BASE.
Teamviewer is ok through my Laptop.
« Reply #23 on: January 27, 2016, 10:16:09 am »
But Arnt, I was not asking that. I just said "reboot". This means that it will (should have) booted back in the same RAM Boot.
Please do that ASAP and don't touch anything else. I want to know whether it still works.
But I guess it did or otherwise you could not have booted into the BASE, right ?
Teamviewer is useless (now) because nothing is the matter.
More in a next post.
First now please boot into the 10586.0 RAM and see whether all is fine. Do not start playing music in the BASE (also not 5 seconds).
« Reply #24 on: January 27, 2016, 10:18:43 am »
What I suspect is that something is wrong in general, but I can't tell what. Bad memory is perhaps too far sought but possibly you see something in Device Manager, like unrecognized Devices.
What MoBo do you use there ?
Btw strange : I was quite convinced that you have an XXHighEnd PC, but can't find anything (invoice) about that.
Did you (need to) do anything for Driver installs etc. ?
tillen
« Reply #25 on: January 27, 2016, 10:21:48 am »
Yes I tried to boot into 10586.0 RAM, but it did not work. So I booted into 10856.0 Base
« Reply #26 on: January 27, 2016, 10:25:21 am »
Ah ...
And why did it not work ?
Messages ?
How did you try it ? (switch on PC I suppose).
tillen
« Reply #27 on: January 27, 2016, 10:29:47 am »
I have the same mobo as the XXPC.
No drivers installed.
A lot of unrecognized Devices in Device manager.
Will check what Devices it is in vendor/device search
« Reply #28 on: January 27, 2016, 10:35:42 am »
OK Arnt, then I suppose that should be solved first, with the notice that one might remain :
See at the mouse pointer. I never could/can get rid of that and I don't even know what it is (maybe other people know ?). So I always disable that (see little black arrow).
« Reply #29 on: January 27, 2016, 10:38:29 am »
PS:
After you know it plays all right from RAM, do not forget to boot into the BASE again in order to apply the Drivers etc. *there* !!
Doing that in the RAM version is useless (it will vanish after a reboot). Ok ?
Pages: 1 [2] 3  All
