April 05, 2025, 09:30:57 am *
Pages: [1] 2 3  All
Author Topic: Windows Defender  (Read 31696 times)
tillen
« on: January 25, 2016, 08:29:01 pm »
Hei, Peter
I just ran into a problem With RAM-OS. everything went fine until I rebooted into min-os in Version 10856.0. then XXHE would not start. Got an error Message about XXHE.exe could not start- serching for a problem............
Then I checked win-defender, witch was running.
Had to copy and reset, Shut off Defender and booted into min-os. and everything is ok now.
Regards
Arnt
PC- Asrock X79 Extreme 4-M -
« Reply #1 on: January 26, 2016, 08:20:04 am »
Hi there Arnt,
Man, I now see you are right !!
But strange that I never noticed myself ? or what about other users ?
And why did you need that "restore" ? In there it is the same ... (as you noticed).
Interestingly on about the last day before I started to make the Disks, I had similar with 10565. So XXHighEnd just does not start and a small screen with as I recall a lot of dots (.....) pops up instead. I ended up in setting back a copy myself. So maybe 10565 has the same problem ?
It is only that I wonder what the trigger is to let it go wrong.
Thanks ...
« Reply #2 on: January 26, 2016, 09:11:00 am »
I just checked and in 10565 it is the same. 10074 is OK.
Thinking back ... I just never had to shut it off myself. I actually only recognize it from making the Tutorial (which I made under 10074 - that's why that one is fine).
Windows 8/10 Tutorials - Shut off Windows Defender
tillen
« Reply #3 on: January 26, 2016, 01:23:03 pm »
I could not start XXHE 10856.0 again, so I just copied it, and deleted the old one. I don`know if that was right way to do it. But it seemed easiest to me at that point.
Had not much time lately, so mabe I should read some more instructions later.
Anyway - It Works well now. and the sound is outstanding.
Regards
Arnt
« Reply #4 on: January 26, 2016, 05:15:33 pm »
Hi Arnt,
Can you describe possible "unique to you" situations ?
I don't trust this, since it happens to nobody else.
Did this happen in the BASE version, the RAM version or both ? (but also tell me which the two you actually tried when it happened).
Last question for now :
On the disk are two green stickers. Do they have markings on them ? If so, please decribe ...
tillen
« Reply #5 on: January 26, 2016, 05:51:54 pm »
It happened in the base Version, but it was no problem before I booted into min-os. After booted into min-os, I could not start XXHE. I knew about the active defender problem. and checked defender. defender was not shut of, I used Your prosedure the turn it of, but I could not start XXHE (still in min-os).
Then I reboted Windows from the start button, and booted into the 10565 Version, and copied the 10856 Version. and deleted the old one. Booted into the New copy of 10856 Version and checked defender, and shut it off. Then rebooted into min-os, and everything was ok.
There are two green stickers With no markings
Regards
Arnt
« Reply #6 on: January 26, 2016, 06:08:33 pm »
Thank you Arnt.
But can you confirm :
What you just wrote is about the first time that it happened (and not the second time). Is that correct ?
tillen
« Reply #7 on: January 26, 2016, 06:12:19 pm »
Yes the first and only time. because I checked Defender after copying.
Arnt
« Reply #8 on: January 26, 2016, 06:38:17 pm »
Yes, but this was a second time, of at least not being able to start XXHighEnd.
True ?
Did the message "stopped working" or something, show exactly the same as the first time ?
Thanks ...
« Reply #9 on: January 26, 2016, 11:40:46 pm »
Turned off Defender in 10586 Base and am now in Ram mode and everything runs faster.  Cool
tillen
« Reply #10 on: January 27, 2016, 09:15:13 am »
True ?
Thanks ...
Hello Peter
After the reboot and copying I shut off defender before I started XXHE, so then it was no problem, I did not try starting XXHE before that.
And about the first "stopped working" Message: It showed "stopped working" the first time I tried to start XXHE, after that there was something flashing on the screen, when trying to start XXHE, I suppose it was the same Message but I could not see because it disapeared to fast, and nothing more happened
XXHE did not start.
I had then shut down defender.
Rebooted with the Windows startbutton, but XXHE did not start, just the same flashing "Message".
Regards
Arnt
tillen
« Reply #11 on: January 27, 2016, 09:30:12 am »
I have played in RAM-OS for 2 days with no problem. But now I Just started and album, unattended in 10586. Nothing happened, after 20-30 Seconds, and there was the error Message again "XXHIGHEND Stopped working".
Playback won`t start and I can not bring up XXHE again.
Arnt
« Reply #12 on: January 27, 2016, 09:31:32 am »
Ok, let that be for now !
So don't touch anything.
Must think ...
tillen
« Reply #13 on: January 27, 2016, 09:32:48 am »
Must think ...
Ok
« Reply #14 on: January 27, 2016, 09:37:52 am »
In my 10565 situation I saw a "missing component" in the Windows Event Log. I don't know anymore whether that was the System or Application log. I think Application.
I had to apply tricks to let that work (view the logs) but possibly it worked without tweaks as well. So first two questions now :
1. Can you go to Explorer, Rightclick This PC, choose Management and then Event Viewer. In there those logs. CAn you get to that or does it give an error message ?
2. How "accessible" is you PC for Teamviewer ? This is just a question because it is an option, although I don't know yet what to do. But if you did not set it up for the Internet (from 10586.0 BASE) then better don't, yet.
Pages: [1] 2 3  All
