November 23, 2024, 10:17:54 pm *
Author Topic: Galerie open's after i have been on other tab. (B.V. Playlist)  (Read 23563 times)
« Reply #15 on: January 22, 2008, 12:24:15 am »
It works like that here ... yes
« Reply #16 on: January 22, 2008, 07:02:50 am »
I thought I just answered, but my post is not here. Hmm ...
What I said was :
This is a know problem, and you should copy bits and pieces. It is about all being too much, *or* something wrong in a particulat folder. Anticipate on the first, until you can prove otherwise.
Same answer like before post  Wink
Btw, your own post has gone too scratching ... it's hard to understand what it's about now.
Ok, you can't copy a lot of data, and the thing hangs for a minute or so and then errors out. Well, one of the reasons I found that this happens, is when you copy from folders that contain *and* normal data (like WAV) *and* meta data (MTA). Such a situation should not exists of course and the MTA should not be in there. Delete the MTA and it goes. *If* that is the cause of course.
« Reply #17 on: January 22, 2008, 07:16:16 am »
These are my settings..  (T6)
When i click on a gallerie (T62) and than all the cd's in that gallerie are shown at the right side and click on a cd ( To load into playlist) and i go to B.V. the playlist. Than after going back to Library the galleriemap i clickt on the last time open's automatically. (T63)
I have to close it first before i can go further...
Also going to another tab b.v. Settings causes opening up gallerie i have clickt the last time.
Ps ( before going to another tab it was not opend. I only clickt once. Not on the plus. Not by means of search.)
Gerard, you are right, and my story is wrong;
The fact that you told that you didn't have CD's twice anyway got me thinking "but then he should be able / just allowed to do what he does".
Woke up this morning and saw the light ...  prankster
With me too, the AllMusic (look at that it's bold because I clicked on it !) opens after the Library Area is reselected. But ... you *can* click on the root (GALLERIES in your case), and it *does* work, only ... it takes a while before all is reloaded, and I never saw that it worked !! So for me it looked like my AllMusic did not re-open, while in fact I had selected the root, and *I* have the redundancy I told you not to have. Hahahaha.
Conclusion : it is not working correctly.
I'm not sure yet how to solve it, because I thought it was nice to be able to jump into the structure (automatically) to see where you are. But indeed not at the cost of not being able to select a genre easily.
Gerard, once again thank you for your persistancy and time. And once again ... you were right.  good
« Reply #18 on: January 22, 2008, 11:14:27 am »
Ha that's a nice wake up...  Happy
youre welkom.....  thankyou
Page created in 0.144 seconds with 19 queries.
