April 06, 2025, 07:08:57 pm *
Author Topic: Check to see if your computer can cause drop-outs  (Read 38566 times)
« Reply #15 on: March 05, 2008, 06:04:33 pm »
Ah ! but you can't use ANY USB device once you use an USB DAC !! no
The way the DAC plays over USB, say, has no priority (well it has, the lowest).
You could try to find another USB "hub" in your laptop plus withgoing connection. But I'm not sure whether that can help (all may end up in the same interrupt pool).
« Reply #16 on: March 05, 2008, 06:07:36 pm »
Since I see that you have a CD10, a few people would be interested to know whether you can (over USB) play 96/24 (or actually any "DAC is" 32 setting) !
kberge
« Reply #17 on: March 05, 2008, 08:16:35 pm »
Thanx for the usb answer, I my simple mind with the pc technology in 2008, I thougt this was possible, but OK I can live with this  thankyou
I just love the CD10, the soundquality is superb both for cd and usb playback with 16/44 WAV files. I still have some more tweaking to do, but that is just great fun to have something to work on further.
I just now tested two flac files and on WAV files, downloaded from the 2l.no site.
flac 24/96 + 24/48: Convert from FLAC -> Length error in FLAC file ....
wav 24/96: No sound and after pushing 'play' again, got the error message: ENDPOINT CREATE FAILED -> The DAC does not accept this byte sequence
XXHE user 0.9z-2:Engine3,KS mode=normal,scheme-3,pp=belownormal,tp=high,devicebuffer=1024,split file size=50.  Eximus CD10 CD/USB player, Laptop PC: HP Pavilion DV9655 AMD Dual core 2 GB, Vista Home Premium
« Reply #18 on: March 05, 2008, 09:08:25 pm »
What were your "Dac is" and "DAC needs" settings here ?
And could you please post the Notapad report of your DAC with the "DAC Test" setting ?
kberge
« Reply #19 on: March 05, 2008, 09:35:44 pm »
The DAC setting is 16/44, and this is the only value I able to set wihout getting an errormessage.
Trying to set e.g. 24/96 afterwards, XX acccepted, but playing the WAV file resulted is message 'INVALIDARG'.
The test DAC setting gave me the same as seen before on this forum for Eximus and Stello USB.
I played the VAW 24/96 file.
* XXModeSupport.log (0.72 KB - downloaded 699 times.)
« Reply #20 on: March 05, 2008, 10:05:33 pm »
Thank you very much.
As I said elsewhere, the CD10 (as the only April Music product I think) officially states that it supports 96/24 for input in the specs.
Do what you like with this information.
And don't blame me !
« Reply #21 on: March 06, 2008, 07:53:34 am »
Wait... let me understand this.  You have the DAC setting in XXHE at 16/44.1, but are playing and hearing 24/96 WAV files?  I've never actually tried to play a 24/96 wav file.... hmm time to go to the linn site and grab one and see...if only I had a working amp heh... tomorrow if I find time, I'll dl a file and see if it plays in XXHE.  But that doesn't sound like it should work?  Is some down/resampling taking place?
« Reply #22 on: March 06, 2008, 10:19:54 am »
I don't think kberge said this. Happy
Downsampling does not take place.
I could make that (to 48K !), but I don't think it's the best thing to listen to. At the time things come down to "better that than nothing", IMO we are 10 years ahead at least, so *then* it has a good reason, weren't it that by then everybody has the DACs, or tweaked the input receiver the least. Hehe.
kberge
« Reply #23 on: March 06, 2008, 02:55:48 pm »
I should have said: I tried to play the 26/96 WAV file. But no sound.
The test was done on request from PeterSt with the latest XX version.
Well, the statements from April Music saying their players accept 24/96 input; this is not according to tests done by me or pedal. The simple fact that the usb unit in the box is limited to 48 KHz says it all.
« Reply #24 on: March 06, 2008, 03:53:36 pm »
I am very sorry, and have been confused; the CD10 obviously is the same as the Eximus. So what I read was from that other device, including amp. blush1
« Reply #25 on: March 08, 2008, 04:00:07 am »
I think our units can accept 24/96 through coax though,,, right?
LydMekk
« Reply #26 on: March 10, 2008, 04:03:22 am »
Yep, 24/96 through coax should work, but not through USB.
