April 05, 2025, 11:14:42 pm *
Author Topic: Check to see if your computer can cause drop-outs  (Read 38533 times)
Chris V
« on: January 21, 2008, 10:44:30 am »
Those that followed my early tribulations will know that I had (and still occasionally have) drop-outs during music playback.
This is not an XXHighend issue, but is to do with how 'busy' the computer is internally, and how other tasks is has to do can cause music playback (which has relatively low priority) to stutter.
Here is a bit of software that tests you computer.
http://www.thesycon.de/deu/latency_check.shtml
Mine shows that "some device drivers on this machine behave bad and will probably cause drop outs". Nice to have it confirmed Happy now i just need to identify what processes are causing it :wacko
Then to SW1X Signature DAC
« Reply #1 on: January 21, 2008, 10:50:36 am »
Great Chris !
I suggest the following : Put the graphs from your machine into here, and I will produce the same graphs so we can compare. As you know my system has no dropouts/glitches (apart from two in twoi months) so we must be able to find the (dis)similarities.
You are first !
And for others with problems : please go ahead too.
Chris V
« Reply #2 on: January 21, 2008, 11:13:02 am »
OK Peter
One small problem, can you remind me (us) how to capture the image and post it scratching
Cheers Chris
Chris V
« Reply #3 on: January 21, 2008, 11:50:24 am »
Just out of interest:
Most small spikes of about 150us(green), many at about 1000us (yellow), and one or two beauties at about 50,000us (red).
« Reply #4 on: January 21, 2008, 12:01:38 pm »
Just tried on my gaming machine (when i listen to music into headphones only, its a dualcore with vista x64).
Most spikes green, a couple of yellow along a 2 minutes test period.
This machine is NOT optimized for music, there are quite many background processes, including diskeeper, kaspersky7, outlook, uTorrent, msn and vmware virtual drivers.
I do experience an occasional dropout of music playback sometimes, thanks to creative cr*ppy drivers for the x-fi.
« Reply #5 on: January 21, 2008, 12:48:24 pm »
OK Peter
Cheers Chris
A program like SnagIt is most convenient, but not free (I suppose it has a trial period).
If you are really in need, various combinations with ctrl, shift, alt (?) and the PrintScreen button. This copies parts of the screen (depending on the key combinaton used) to the clipboard, and from there on you can struggle further to get it into something you can attach here. Happy
« Reply #6 on: January 21, 2008, 01:25:08 pm »
I use a program called gadwin, it is freeware and very convenient.
See gadwin.com
« Reply #7 on: January 21, 2008, 01:25:40 pm »
Well this is mind.... Most green spike's though...... unhappy Happy
« Reply #8 on: January 21, 2008, 06:10:05 pm »
Well, this should tell something (but what ??).
The first picture shows my Vista audio PC. It doesn't look right to me, and the deviation is 14 us or so. Veeery consistent, but with once in a while a drop to normal levels.
The second picture is right after a reboot of Vista. It's a bit busy then (as usual).
This third picture is my offical HTPC, which I hardly care about, but for having the proper drivers etc. running, and, might it matter, it's tuned for PCI latencies (Chris, I think I once handed you a program for that).
The Vista machine seems to have a minimum of 992us (apart from the few drops) and that sure is smelly.
Chris V
« Reply #9 on: January 21, 2008, 06:42:09 pm »
Hi Peter
The measurements I gave earlier were with the laptop sitting idle and not even running music or on the Internet.
I now have XXHighend running. For 99.9% of the time all measurements are steady, just like yours, between 1000 and 1080us. About every 30 miniutes I get a single red bar at about 4000us - this is probably my drop outs.
FIO I did try the PCI latency program some time ago, but the software did not apply to vista unhappy
Have we just opened another can of worms??
« Reply #10 on: January 21, 2008, 06:46:08 pm »
Maybe ... but until I understand this, say not.
Here it doesn't matter whether XX is running or not, but for the greens to disappear completely. The steadyness remains. After a reboot without starting XX no difference.
Strange ...
Chris V
« Reply #11 on: January 21, 2008, 06:50:11 pm »
YES Just had an audible drop out that coincided exactly with a red bar of 3886us good good
kberge
« Reply #12 on: March 05, 2008, 12:50:06 pm »
Hi (I'm fairly new in the XX area, and were I live they call guys like me  'a simple guy from the countryside').
First of all: The sound from XX is really second to none! Thanx PeterSt!
Second: I do have problems with lots of dropouts when playing music (WAV) from local disk or file server to the usb connected DAC and move the mouse (usb) around in XX or using other programs. Disconnecting the mouse helps a lot.
I ran the latency analyzer and clearly there are problems (see attached file). I assumed problems with the usb driver, yes, all possible drivers are at the latest available version. I contacted HP support and after some emails back and forth, they stated that the cause must be within the XX player, no doubt. So what do I do now? I'm using a brand new HP Pavilion laptop pc, dual core 2 GB ram.
XXHE user 0.9z-2:Engine3,KS mode=normal,scheme-3,pp=belownormal,tp=high,devicebuffer=1024,split file size=50.  Eximus CD10 CD/USB player, Laptop PC: HP Pavilion DV9655 AMD Dual core 2 GB, Vista Home Premium
« Reply #13 on: March 05, 2008, 01:34:35 pm »
Well, Welcome ! then !
Where I live we kind of say it the other way around : "I'm only a city boy", but we mean the same by it. We must have respect for country boys ? Happy
Anyway, if you have any infrared connected devices (could be keyboard, mouse), disconnect them.
If you have Wifi on board, shut that off too.
Bluetooth ? the same.
Everything only for trials of course.
If you don't have those devices, then actually I don't know (apart from that it sure is not XX related, but you guessed that I suppose).
But let's first see what your answer is ...
kberge
« Reply #14 on: March 05, 2008, 05:50:59 pm »
Hi again, (and you city boys are fast resonders, countryside guys love that  Happy)
Well, I have disconnected ir and bluetooth devices from the very beginning  scratching. I have not started the cumbersome exercise to disable services, the pc is also used by others.
The dropouts occur most often when the usb mouse is connected and I hear always dropouts when used, therefore I suspected the usb internal service. Dropouts occur also sometimes starting new programs. I have tried to change the Processor Core Appointment scheme; no change. I have also tested various combinations of player & thread priority.
Still wondering what to do.
