November 23, 2024, 01:44:00 am *
Pages: 1 2 3 [4] 5 6  All
Author Topic: NOS1a (v1.0.4b) : Fifo errors  (Read 59458 times)
« Reply #45 on: January 24, 2016, 11:06:28 am »
So Driver at 16ms and ClockRes at 2.5ms could be an acceptable combination - for me over here at least.
I had the impression that you adviced to avoid the 16ms?
Last evening i Test the following route: silverstone usb>clairixa 1.2m>itona>Clairixa 0.3m>Nos1a and only streaming errors. For me not audible. This was not in unattended mode. I did not switch the voltage off. Order of connecting from pc to nos1a. This morning switching all on still no fifo an usb errors. At this moments not even streaming errors. I red on the site computeraudiophile.com a lot of discussions about the itona and connection problems with different cabels. Someone wrote the connection order and the short cabel on the dac site. Others wrote succes with the $1 usb cables.
I hope i can keep this situation. Today back to unattended playback.
Regards
Johan
« Reply #46 on: January 24, 2016, 11:42:03 am »
Last track of the first cd i had a small hickup and 2496 streaming errors but no fifo and usb errors.
tillen
« Reply #47 on: January 24, 2016, 11:53:03 am »
First off, thank you for sharing, bbbut ... it is not so clear to me what your conclusion and final setup is.
Also, you have the short Clairixa and seem to avoid mentioning that you used that together with your long one.
Is it possible to briefly tell it in a somewhat better fashion ?
Thanks !
Sorry for that, I saw i now that this could be misunderstood.
Conclution is that I continued playing With The Entreq usb to the NOS1a from the Intona, and the long Clarixa from PC to Intona. And did nothing more, after a while, just listening to different Music, the distortion was gone, and has been away since.
The reason I did not mention the short Clarixa, is because It has not arrived yet.
Arnt
PC- Asrock X79 Extreme 4-M -
« Reply #48 on: January 24, 2016, 12:00:33 pm »
Hi Arnt,
So I registered something wrongly or something *is* wrong. But it is a bit tough to find out now for me.
At this moment 4 have not arrived at customers yet and you are not in that list. Maybe it is no big deal for you to forward me your last UPS email (so I know your tracking number and can follow myself). But if all is right that email shows that it arrived ? (otherwise clearly my bad).
Otherwise thank you for the explanation.
« Reply #49 on: January 24, 2016, 12:07:47 pm »
Hi Johan
That is a matter of following the sequence. I mean, if I first say that the 16ms should be avoided indeed because of audible anomalies - which I already said months (if not a year) ago - and if I next only yesterday start to combine with the ClockRes and see that 2.5ms looks to be acceptable (still a few errors, but acceptable) then ...
Then I don't think nothing much is wrong with that.
Something else - or actually not ...
I asked a few questions (in bold) trying to solve your problem and you never answered upon one of them.
Now you don't have no errors but forget to mention how you did that or what you have changed.
This makes me a bit dizzy - as usual.
And if you don't know what happened you can always explicitly tell THAT. Now I still don't know while I still try to help.
(and this takes time)
tillen
« Reply #50 on: January 24, 2016, 12:29:18 pm »
Hi Arnt,
Peter, the shipping has been in the same destination for 3 days, this is about POSTEN NORGE.
it will arrive tomorrow.
Arnt
Arjan
« Reply #51 on: January 24, 2016, 12:59:24 pm »
Hi Peter
Shoot me, but currently I am listening to the both clairixa's and intona in the chain........
Johans remarks gave me some new ideas. Also now I have the short clairixa on the dac. (I had it running already between the intona and dac for some hours, maybe burning in needed?) I put a separate linear psu on the Silverstone AND I only can use the lower Silverstone connection!!
Also my CPU is now at 1200 because of my bios issues last night. I use 10586.0 in RAM. sfs 0.05 and clockres 1 ms and usb buffer size 2 ms.
To much variables....... do not know what did it, seems a lucky shot to me.
regards, Arjan
March, 2024 (2.11)
« Reply #52 on: January 24, 2016, 01:17:47 pm »
The least I should do is tell you both is that I am the most happy that you solved  it.
If you did !!!
 Happy Happy Happy
« Reply #53 on: January 24, 2016, 01:45:24 pm »
....So Driver at 16ms and ClockRes at 2.5ms could be an acceptable combination - for me over here at least.
Qustion: Driver at 16ms, what driver are you talking about?
Something went wrong yesterday in the answering. I wrote two reactions, but they did not arive on the forum. Arjan's reaction was very fast. saterday is a bussy day for me. I did some teste in the night.
Now you don't have no errors but forget to mention how you did that or what you have changed. /color]
I wrote my answer in the same reaction on this forum playback. "Last evening i Test the following route: silverstone usb>clairixa 1.2m>itona>Clairixa 0.3m>Nos1a and only streaming errors. For me not audible. This was not in unattended mode. I did not switch the voltage off. Order of connecting from pc to nos1a. This morning switching all on still no fifo an usb errors. At this moments not even streaming errors. I red on the site computeraudiophile.com a lot of discussions about the itona and connection problems with different cabels. Someone wrote the connection order and the short cabel on the dac site. Others wrote succes with the $1 usb cables.
I hope i can keep this situation. Today back to unattended"
"I asked a few questions (in bold) trying to solve your problem "
What happens with either of your situations when you set the SFS to 4.00 ?
Still fifo and USB errors
What happens to either of you when you swap your both Clairixa's ? Thus, the long one coming from the PC, the short one going into the DAC ?
That was what i have done in the late night. See my answer before. No fifo or usb errors anymore only sometimes streaming errors.
I have the impression that it also something has to do with the Silverstone USB card. In an configuration with first the short and then the long Clairixa with the PC USB port the fifo errors don't exist anymore.
Long post but Peter I appreciate especially your efforts in your work and solving this problems. But sometimes we have some communication problems. XXHighend is difficult software with a lot of parameters. The understanding of this parameters is not always easy.
Do I forget something to answer? unhappy
Best Regards,
Johan
« Reply #54 on: January 24, 2016, 01:57:31 pm »
Haha, all ok !
But of course, if posts disappear then it gets a bit difficult.
Thank you for your extensive answer !
listening
« Reply #55 on: January 24, 2016, 02:01:36 pm »
after reading all the posts I feel that one aspect isn't be under consideration: The Intona is powered via PC. Could there be any dependency on the PC with different power supplies, different USB ports or the used USB cable?
Georg
-> SMSL SU-8 ES9038
-> 2x Neumann KH-120
« Reply #56 on: January 24, 2016, 07:04:26 pm »
Hi Georg,
You probably are very right. But how to "control" that ...
« Reply #57 on: January 24, 2016, 08:02:32 pm »
regards, Arjan
Strange, I  had the same problem. Before the HDD from Peter. Now it is ok.
vrao
« Reply #58 on: January 24, 2016, 09:20:46 pm »
I had ticks with 1.03 on W8.
I changed the USB port (3.0 to 2.0) and the USB/FIFO errors stopped.
I suspect powers supply issues.
Short Clarixia on the PC side.
VJ
listening
« Reply #59 on: January 24, 2016, 10:20:22 pm »
Another question: Do all NOS1a users with silverstone card problems have connected the power via molex plug?
Georg
-> SMSL SU-8 ES9038
Page created in 0.114 seconds with 19 queries.
