April 06, 2025, 11:17:13 am *
Author Topic: Date Setting RAM DISK  (Read 6405 times)
« on: January 21, 2016, 03:56:41 pm »
Before there was a lot to do with the date settings. Date is now 13-10-2015
Is that ok? Do whe have to do anything regarding the correct date?
Grtz Gerard
« Reply #1 on: January 21, 2016, 04:04:55 pm »
Yes, the correct data that being the September one.
The October 13 comes up because that was the Release Data of 10586.
« Reply #2 on: January 31, 2016, 07:19:02 pm »
Today I have installed 10586.0 using the present date and related to that all seems to function normally even after many reboots...
No idea when or if it will expire but setting the date to 31st of januari seems to be no problem.
I will reset the renew date to today... or not ;-)
« Reply #3 on: January 31, 2016, 07:38:29 pm »
Bert, that is because you set the date *after* the date of birth. Of course that works normally - why wouldn't it ...
And why would it expire ... it is an RTM version.
You can't see it, but Gerard was talking from the context RAM-OS ... (which includes 10074, which ... ... OK ?).
