November 22, 2024, 08:18:15 pm *
Author Topic: Configuration Questions: Multi-RAM Boot Disc without RDC/Server Connection  (Read 24135 times)
« Reply #15 on: January 25, 2016, 04:30:58 pm »
Hello you strangers ...
I'm afraid that you both start to deviate too much to be "judgable" from my side. But these are your own choices of course.
If anything, the RDC sounds BETTER and this is so since the Bluetooth means of doing that (but I certainly don't use that any more).
I have said it before : the sequence of things is of vast importance and Brian, your means of (dis)connecting things is encouraging for the best pile of sh*t imaginable.
Why ?
uhm ... because I tell you ?
Each time you connect something or disconnect something, you provoke a ground loop change. So, those loops are everywhere (all invisible, all inaudible if the further act is okay) but changes are implied for sure.
If this comes across as hard or sudden or strange ... yes, there was a time that I myself wondered what actually happened in between the pulling of a power cord and putting it back for whatever (non-)maintenance. Today I seriously don't wonder at all because I now know how ground"loops" MUST find there way. Always. So your "net" regarding this is an always balanced "something" (say with a net potential of zero) and cutting out a piece of that (like your USB drive) may change it all over. "May" but better is to state it "will".
Maybe it is good to point out our endeavours about the "switching power supplies removed from the system" (still in my Sig) ? It is similar.
Only the other day (two weeks or so ago ?) I mentioned in this forum the importance of the boot up sequence of really all. So, I *know* this is crucial. It is only that I don't know yet what THE sequence is. Think like having in the monitor, keyboard and mouse cable when the PC is completely Off, boot it and only then pull those cables. Not before.
Hey, 10 to 1 that when you unplug your monitor from the power that you will see a huge DC change somewhere. Monitors are baaaaad (and the same for everyone).
Ok, what was I saying ?
Well, that you should have a stable system. Stable-wrong or stable-right. But not at the will of God etc. and that things always change - and as in your case even a few times per hour.
I know, you weren't even complaining ... Happy
Sleep over this somewhat, ok ?
Make it decent, please.
« Reply #16 on: January 25, 2016, 04:48:49 pm »
Hi Brian,
Thanks. I tend to rely on different perceptions from others, so I will try to make comparisons.
« Reply #17 on: January 25, 2016, 04:57:43 pm »
Ha ha Happy Strangers from America Happy We have 120V here, maybe it triggers different things Wink Would it ?
« Reply #18 on: January 25, 2016, 05:43:24 pm »
Sit tight Alain ...
YES.
When 20 or so DACs were out with the USB version, all to the 'hood over here, a first 110V did not want to work for DC Offset (issues).
We were working for a month in a row to get that right ...
This was all before your time, but people may recall posts about the quite many mains set ups (in "your" town) with phases and grounds and stuff which all influences.
It seems that the UK is the most various with that, but except for one with the same behavior as the 110V they are all harmless (I recall 5 different set ups in the UK).
« Reply #19 on: January 25, 2016, 06:17:15 pm »
When I see the advantages of the shucko plugs (they do not get half the way out of the wall when the cable is heavy, they can also be inverted with ground still in contact), I wish we would have the same format here...
Or maybe have AC cables in wi-fi mode Wink Grin
