April 06, 2025, 03:38:10 am *
Author Topic: OS preference for Music Server  (Read 28111 times)
toddn
« on: December 28, 2015, 12:52:39 pm »
I was wondering what OS everyone with a separate music server is using? And is there one that is recommended over another and for what reasons?
Todd
« Reply #1 on: December 28, 2015, 01:03:58 pm »
Hi Todd,
All I can say is that I use Windows 7 Ultimate and this is just because it's on that particular machine.
All OSes I tried for Audio PC on the other side, work well with it (W7, W8, W8.1, W10 various builds).
PS: What happened to your Sig ? or was it never there ?
toddn
« Reply #2 on: December 28, 2015, 08:42:29 pm »
Thanks Peter,
Sorry for being a lazy "f" and not adding my signature until just now oops
Todd
« Reply #3 on: February 12, 2016, 01:16:37 pm »
I've got almost everything here for my music server build (to replace my Synology NAS, which I have to say has worked perfectly for the last 3-4 years). Just thought I'd share my thoughts on which OS to use...
Win10 RTM still seems a bit under-developed to me. Loaded it on to my work PC and am having massive problems getting USB 3.0 to work correctly. And I don't really like 8/8.1. So it's going to be Win7 Ultimate for my music server build.
Stanray
« Reply #4 on: February 12, 2016, 10:13:53 pm »
I recently set up my system with a music server PC and started with Windows 10. I couldn't get it going (problems with network) and in the end installed Windows 7 Ultimate, which works fine, .... now. The network problems probably had to do more with not working in normal OS and it does work minimized.
In back sight I'm not so sure anymore that Windows10 was to blame for the problems and I think I read that Juan uses Windows 10 for his music server.
Stanley
briefremarks
« Reply #5 on: February 13, 2016, 01:51:23 am »
I've been using W10 on my music server with no issues so far.
XXHE version 2.11.
« Reply #6 on: February 13, 2016, 01:09:36 pm »
Stanley
Hi Stanley,
Yes I´m using W10 in the Music Server with no problems at all. As I said in some place my present configuration is:
Dock with 2 music drives (2Tb each) > USB 3.0 cable > Music Server PC (W10) with WiFi for Internet and with its own monitor (not a tablet) > Ethernet Gigabyte cable > Switch > Ethernet Gigabyte cable > Audio Pc with the Ram-disk
The components I use are:
- A docking station like this: http://www.amazon.co.uk/Inateck-Docking-Station-Function-Tool-free/dp/B00LN0GX4I/ref=sr_1_3?ie=UTF8&qid=1455363600&sr=8-3&keywords=DOCKING+STATION+USB3.0
- A desktop Pc: Always better with its metal case than the plastic laptops or tablets to protect from interferences.
- A Switch: Like this one: http://www.amazon.co.uk/TP-LINK-TL-SG1005D-Gigabit-Unmanaged-Desktop/dp/B000N99BBC/ref=sr_1_2?ie=UTF8&qid=1455363403&sr=8-2&keywords=TP-LINK+TL-SG1005D
- A couple of Ethernet Gigabyte cables, better CAT7 for the same reason than above e.g. http://www.amazon.co.uk/Ugreen-Ethernet-Gigabit-network-10Gbps-Black-flat/dp/B00QV1F1C4/ref=pd_sim_147_1?ie=UTF8&dpID=51QLDGlxAgL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=0B6CANZ235YCS40PZWV3
It is important also that the Ethernet ports in the PC´s are up to 1Gb, otherwhise would have a bottleneck there.
The software and the configuration is the most important part to make it work correctly.
To sumarize this part I use:
Windows 10 Pro version 1511. The Remote Desktop. As I don´t use a router I made the IP configuration manually. It is also important to configure it as a Private network not as Public (don´t know if this is the correct word in English). Know how to share the hdds with music and how to map it.
I´ll try to post a step by step tutorial next week with images on how I did it.
« Last Edit: February 14, 2016, 10:17:27 am by juanpmar » Logged
Stanray
« Reply #7 on: February 13, 2016, 08:45:08 pm »
Hi Juan,
Thank you for the details of your setup.
I have it running smoothly now in this configuration:
Tablet <RDC-WiFi> router <cable> MusicPC <RDC-cable> AudioPC.
The router is a "dedicated" router, not standard connected to the internet. For the home network I have a separate router which can be connected to the "audio router" if necessary.
The music server pc is a simple ex-corprate desktop with my music HDD built in (http://www.micmac-computers.nl/webshop/pc-systemen/detail/857/uitverkoop---fujitsu-siemens-esprimo-e5730---core2duo-2x-300ghz---4gb---160gb---dvdrw.html).
I think for the purpose of ripping/organizing music files Windows 10 doesn't add much, so I let Windows 7 run.
Next: OS in RAM disk, I'm reading the tutorials now  wacko bzz.
Stanley
« Reply #8 on: February 13, 2016, 09:41:24 pm »
That would be great. I do not understand this part very much.
Grtz Gerard
« Reply #9 on: February 13, 2016, 10:30:03 pm »
Seems it's an incompatibility between the USB 3.0 H/W on my mobo and the currently available W10 drivers (the mobo is a pretty new design). I installed a USB 3.0 PCIe card today and everything works perfectly.
I will now use W10 on my music server because I think it's slicker than W7. Still waiting for the music server mobo to arrive... and the 4x 4TB WD Red Pro HDDs  yes. But the case, CPU and ECC memory are here. I'll post the full details once it's all up and running.
I've decided that I will go all-out with Roon and Tidal on the music server too... along with XXHE to load tracks ready to be played on the audio-PC. Exciting times!
music33
« Reply #10 on: February 14, 2016, 01:20:20 am »
I must be missing something with the quote below - I thought XXHE has to be on the audio server and the music server contains your music files.  The audio server has a network drive setup pointing to a music server directory.  This info is from Peter's posting http://www.phasure.com/index.php?topic=3211.msg34887#msg34887
Is there a tutorial on setting up the XXHE on the music server and is it then on the audio server as well?
« Reply #11 on: February 14, 2016, 09:48:46 am »
Hi Dave,
Not explicitly and here's why :
In sequence, this is about two main things :
1. Having as much as possible out of the Audio PC;
2. Utilizing the Music Server PC for "server tasks" for the Audio PC.
Ad 1.
This is clear, I think. It is tendency to move all out of there, and with the latest incarnation of the whole setup, referring to the RAM-OS, this is now accomplished.
Ad 2.
In (further !) evolution, this is about my ever "warning" to have a Windows PC instead of a NAS, just because that Server PC can do so much more; so far I have been referring to "Tidal Preparation" as the one example, speaking for most (I mean, most understand the example).
Notice that as far as I know you are still on 1.186(-i) so you can't really tell what I am talking about.
There is no Tutorial as such for installing XXHighEnd on the Music Server PC because it would be a moot thing; it's just an XXHighEnd install like always. But, the reason is lacking so far and this would be explicit client-server functionalities. Look :
What one does at this moment (at least I do) is having the Music Server "Prepare" Tidal albums, and this can be during music playback by the Audio PC. The Audio PC obviously takes its music files from that same server which can do those Preparations. One thing :
The client-server process is a manual process, so to speak. Thus, it is me who needs to go to the Server's screen, search for some Tidal Album(s), start the Preparations, move back to the Audio PC for further control, which control physically is done by the Server PC again over RDC (nice knot, right ?).
The real client-server thing goes like this :
I am on the Audio PC which is playing music, then I think "oh wait, I want to look for more Ray Brown's" and next I hand a command to the Server to sort out what's all available - that Server being connected to the Internet while the Audio PC surely is not, and the Server calling me (the Audio PC) back with the results. Nothing disturbed the Audio PC here, except for a few bytes the Audio PC sent out with the command and the few bytes the result occupies as was asynchronously returned by the Server (the result actually only messaging that things are ready to look at on the Server('s, hey, disk).
What next happens is that I choose for Albums to be prepared out of that result list which thus resides on the Server like all resides there, and after that command is handed out it may be after 5 minutes that I'm called back with an "All ready !". Or after 20 seconds that Album A is ready to be played; it is available like all else on the server.
Now, besides we can now see a real reason for a client (Audio PC) and a server (Music Server PC) to exist, we can also see some additional "tutorial", because it requires a few more Settings to set. Example below (field at the bottom). And with some TCP knowledge you can see that the communication is setup "internally" just the same, as 127.0.0.1 is the Local Address. So the Client-Server principle has been set up for in-PC processes and tasks just the same.
Technically this is all working already, including a nice protocol. It is only yesterday that I started working on the first real functionality for it, which indeed is Tidal. So in XXHighEnd 2.06 this will be there.
It is my intention that working exclusively from a Tablet, all can be done in integrated fashion. That some tasks are performed on the Music Server PC you will not notice. It is like you performed them on the Audio PC and that the Audio PC under the hood is dealing with them. But instead the Music Server PC does and Audio Quality remains 100% untouched, playing meanwhile).
music33
« Reply #12 on: February 14, 2016, 08:32:42 pm »
Your explanation helps a lot.
Are you thinking that in the future that the music PC will prepare (i.e. apply filtering, etc) wav files and then the audio PC essentially just streams music to the DAC.  The user interface and the preparation is on the music PC.  In doing this perhaps the requirements for the audio computer CPU becomes less and a lower wattage can be used, hence improved sound quality.  Maybe a core M chip, 4.5 watts...
Thanks, Dave
« Reply #13 on: February 14, 2016, 08:40:31 pm »
Dave,
Yes, the filtering could be an example. However, while I already typed that into my previous post, I scratched it again because I don't see it happening that this works out because of the large output files. Otoh you now mention streaming and taking that literally, yes, that could happen.
But no such (demanding) filters in sight yet, tough.
If that would be the objective, that would be running right now. But that doesn't work out, really.
So remember, our XXHighEnd PC runs at 230MHz now (Windows 10), if you want. That sounds superb, but the processor is still quite beefy.
« Reply #14 on: February 14, 2016, 11:18:28 pm »
http://www.phasure.com/index.php?topic=2084.msg21418#msg21418
