November 24, 2024, 01:57:26 am *
Author Topic: Wishlist XXHighEnd  (Read 25982 times)
« Reply #15 on: January 22, 2008, 12:04:46 pm »
Yes this is obvious. You suggest though that I don't.
Where ?
andy74
« Reply #16 on: January 22, 2008, 12:27:13 pm »
Thinkin of it again, in fact the double click wouldn't be much different from usual (that deselecting other stuff which ... I btw now wonder, because I think you could ctrl-doubleclick as well), so I guess I can make it.
Okokokok.
thankyou
I may have misunderstood you again, But I never saw ctrl-doubleclick in media players.
« Reply #17 on: January 22, 2008, 01:13:53 pm »
I don't think this has anything to do with media players, but with, as you say, the user interface.
The user interface is Windows (and I did not try to let that be or look different, compare Foobar), so we have to deal with Windows in this case.
Now go to Explorer, and select two files, and hold ctrl and shift. Now double click ... yes
So the only thing I'm saying, with explicit means to make it justified Shocked is that it is legal to double click a selection, that selection not disappearing in the mean time. If you only hold ctrl and shift, this works and this is formal Windows.
Of course ... nobody knows this combination, and after making a selection people will complain that double click deselects all. Please note that this is not much different than the questions about "can I click a file and let play start ?" where nobody realizes that it deselects again. And that you should press ctrl at the same time, (relatively) nobody knows ...
Arrggh, this is hard to explain, because all has to do with challenging for the bad things by allowing one. Maybe I can give the selection of Items in the Library Area as an example;
All in there works perfectly normal, hence by standards (apart from ctrl-a, which is not my fault really) if you leave the checkboxes Off. Now use all these beautiful standards to select your albums out of, say 1000, in order to make a Galery. Can you do that ? I bet you don't, and if you do you are dead of stress for a couple of hours afterwards. Why ? because it is not allowed for any one single time to click different than you should, or otherwise you'd loose your selections (for 1000 albums this is 2 hours of work including proper judgement).
Now, do you know what would solve this ? just not allowing the selections ! Hahaha. It would not direct people to the wrong path.
Same is with the one-click-play-please. That would be used automatically, and 95% of people (trust me) would not even know selections can be played. Or, that the click on a next track during playing, immediately would start that track for playback, nobody knowing that pressing ctrl would let the other track finish first.
Solution ? again, just don't allow it. So, click on a next track does not start the playback of it, and it needs the Play button to do so. A very easy choice everybody understand, excpect a few complaining people, eager for one-click-play not realizing the consequences for even themsleves, let alone for others.
I hope that by means of this writing you at least see that it's all thought over (even rather carefully). This does, however, not necessarily mean that I made the best choices out of things. So please keep on shooting.
bye
« Reply #18 on: January 22, 2008, 01:28:40 pm »
After some usage of XXHighEnd version 09t-5, i have the following wishes / suggestions:
Do you have a reaction on mine suggestions http://www.phasure.com/index.php?topic=344.0 ? Because i didn't receive a reaction i was hoping that you realized them in 09t-6....... unhappy
Johan
« Reply #19 on: January 22, 2008, 01:41:15 pm »
Hi Johan,
you couldn't guess it, but the sole fact that I said nothing, implies that I think the ideas are good. I will implement them differently though.
When ? not yet. I think everybody would agree that it's 24bit time now.
Sorry I did not honour your idea by a response at least.
andy74
« Reply #20 on: January 22, 2008, 01:47:51 pm »
I see now. Happy
Then it would be nice to have all of those key combinations and possibilities explained somewhere in a help file.
Or is it described already.
« Reply #21 on: January 22, 2008, 01:55:07 pm »
No it isn't. Okay, in Windows help somewhere I guess. wacko
But on that matter, since XX is getting closer to an official version, it needs an official manual as well. So that will be there.
A lot of work, but in fact a substraction of all the bits and pieces from the Releasenotes in a structured form.
« Reply #22 on: February 12, 2008, 01:31:04 pm »
  • Rip function: is it possible to implement a ripping function in XXHighEnd?
Ok, somehow today I think this needs special attention;
On one hand you could say that there are enough rippers in this world. So why another one ?
On the other hand though, I myself can't feel safe by the one(s) I use, just because I don't know what's in there. In fact, nothing different from the moment I started XX ... "what the h*ll is in the other players that makes them sound different ... err ... not good ?".
I'm confident that I will be able to at least make ripping more comfortable to the matter of a high speed rip not needing to be bad. Or, when the rip goes slow, it's really necessary. Or : when something is just wrong, mention that explicitly, instead of trying to make the best out of it -> better use it as a frisbey.
All together you could say that good ripping takes a lot of time, and IMO that time can be much less by better "IT support".
So yes Johan, I sure plan to create a *good* and friendly so-maniest ripper. But the priority really has to be low. I think that's understandable.
