November 24, 2024, 02:35:41 pm *
Author Topic: W10 - Problem with Monitor Off  (Read 7142 times)
Tore
« on: December 20, 2015, 11:15:01 pm »
I have a problem with Unattended, but that is with XXHE 2.03 + W10 build 10565.
First time i tested Unattended it was OK
Then i was testing Unattendet + Monitor Off.
The playback stopped and the screen was black.
I had to reboot two times before i could start XXHE 2.03 again.
After this i can play with Unattended but when i press next track the same happens: playback stops, black screen and i have to reboot two times
Tore
« Reply #1 on: December 21, 2015, 09:21:04 am »
Tore, Yes, I only found out two days ago that Windows 10 can not bear the Monitor Off function (and wrote it in the forum somewhere). So do not engage that please.
For the next version, in Windows 10 it can not be engaged any more, until I find another means to do it.
« Reply #2 on: December 22, 2015, 07:49:05 am »
There is no problem with 2.03/10074 with monitor off. Works just fine. Alt+X brings up XXHE screen.
« Reply #3 on: December 22, 2015, 08:24:59 am »
Ok, who is getting dizzy here ?
Re: XXHE 2.03 doesn't show desktop.
« Reply #4 on: December 22, 2015, 08:33:07 am »
That was prior to the fresh reinstall of W10074. Now it works just fine.
