November 23, 2024, 09:20:12 pm *
Author Topic: Power Line Ethernet  (Read 7449 times)
briefremarks
« on: December 15, 2015, 04:05:15 am »
I am looking to use power line ethernet between the NAS and XXHE PC.  Does anyone have any experience with SQ and power line ethernet.  I am assuming that there will not be a problem.  The NAS will be in a media closet downstairs, the XXHE PC is upstairs in a part of the house that is not currently wired for ethernet.
XXHE version 2.11.
« Reply #1 on: December 15, 2015, 06:20:27 am »
I would avoid it.  Tried it once as a stopgap solution and then brought forward plans to wire up the whole house straight away. Was not good in my situation.
« Reply #2 on: December 15, 2015, 09:08:10 am »
Since I don't have a real answer and sort of must say the same as Anthony (acg) for theories, I found another way of rejecting it (now I'm rid of the "problem") :
It is unncessary slow.
So notice that we are (or I am) used to 1Gb/s of Ethernet speed. This is raw speed, meaning : reality, because I avoid switches or routers (direct PC-PC (PC-NAS) connection).
At this speed and further proper set up in XXHighEnd of diverse parameters (like the necessity of a RAMDisk) you won't notice speed differences with the Ethernet connection vs the usage of an internal SATAIII-speed HDD (SSD).
Ethernet over Power is at best half of that speed, but count on 10% of it. Now also count on the loading of an album (for Unattended) of 30 seconds instead of 3 seconds.
Problem solved (hence don't do it).
http://www.pcadvisor.co.uk/feature/network-wifi/what-is-powerline-3491484/
