November 24, 2024, 03:04:47 am *
Pages: [1] 2 3 4  All
Author Topic: Track start and Wallpaper problem  (Read 45280 times)
Eric
« on: January 07, 2008, 02:42:54 pm »
Hello Peter. My name is Eric and I am new on this forum. I am using XXHE for 7 months now and IMO it generates the best (digital) sound I have heard so far. Now I like some help with a few rather weird behaviours of my setup. My XXHE 09t-5 runs under Vista Ultimate and I would like to report 2 (independent?) problems.
1) My music is stored in 2 different kind of ways. One way is Album divided in Tracks, the other way is Album but not divided in tracks. No doubt this has to do with the way the CD has been ripped. If I load an Album of the 1st kind (i.e. divided in tracks), and Play, it runs starts playing the 1st track etc. However if I load an Album of the 2nd kind, all the track titels appear in the playlist but the last track titel is highlighted blue. And if I start Play, only the last track plays. So if I like to play the whole album (some albums are worthwile to play from the beginning instead of just the last track Wink, I first need to click on the 1st track before I start Play. Question: what am I doing wrong ?
2) The 2nd problem I would like to report is the Wallpaper. When I play an album of the 2nd kind, it works ok. However, when I play an album of the 1st kind (i.e. divided in tracks), the error message "ChangeWP does not work anymore" appears. Question: how can I fix this (something wrong in my setup?)
Please help,
Cheers, Eric.
« Reply #1 on: January 07, 2008, 03:01:43 pm »
Hi Eric,
On your first subject : I have seen this happening myself, although I never realized that this would be a Cue File (that's what your 1-file albums would be) problem. I will look into it, and most probably with the next version it will be solved.
The second subject, ChangeWP erroring out, I have seen too, but so far I did not recognize that this occurred with the separate tracks only. Anyway, this too will be solved in the next version.
Thanks for reporting,
« Reply #2 on: January 07, 2008, 06:30:10 pm »
No, this is not just separate tracks. I'm not sure what it is yet, but I sure once had an album where each track produced the error.
« Reply #3 on: January 07, 2008, 07:35:07 pm »
As far as I can see now, the second problem is also related to Cue Files;
That is, in the situation I have here, the Cue File itself (the .cue file) is named differently than the folder name it is contained in.
I don't think I can solve this ... but maybe I can afterall. Happy
Anyway, maybe you can check whether this is your case too Eric ?
Eric
« Reply #4 on: January 07, 2008, 11:23:32 pm »
Peter, the CUE file name is identical to the Folder name containing it. However, I continued testing a little bit more and here are my findings. I performed this test with a cleaned XXHE playlist.
1) First I ran a Registry Scan and Repair using RegistryBooster2 to ensure an errorfree Registry
2) After Rebooting, I loaded a CUE type album from the library and started to Play. Actually only the last track as indicated by the highlight in the Playlist.
3) I selected Stop and Off.
4) Again I ran a Registry Scan to see if something interesting has occurred. YES, the scan resulted in the following message.
Missing or Invalid Path. The Key OpenWithList under HKEY_CURENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.wav contains a bad path a for the value
I do not know if this is related to the problem but I hope it helps.
Ciao, Eric.
« Reply #5 on: January 08, 2008, 07:23:31 am »
I get the ChangeWP error sometimes...I don't know what the rhyme or reason of it is.
« Reply #6 on: January 08, 2008, 05:00:22 pm »
Sinds the latest vers. I do not anymore.   Happy
« Reply #7 on: January 08, 2008, 06:11:45 pm »
You could try to put below ChangeWP.exe (coming from the Zip) to put in your current XXHighEnd directory.
If it helps (which I assume yes) it *must* be so that the name of the Cue File is different from the folder the Cue File is in (without .cue of course).
I know you said that this is the case Eric, so this should not help. But then I need the example somehow. scratching
* ChangeWP.zip (9.55 KB - downloaded 576 times.)
Eric
« Reply #8 on: January 08, 2008, 09:29:38 pm »
I downloaded the ChangeWP.exe and put it in the XXHighEnd directory. I selected an album and renamed it (the Folder containing the .CUE and .WAV files). After loading the album I observed no change in the behaviour of XXHE. The last track is still highlighted. It does ask me for permission to run ChangeWP.exe, which worked fine. After playing, I checked the Registry and found that the same error as before has been generated.
I also tested an album that does not contain a .CUE file. Still the message "ChangeWP does not work anymore" appears before every track before the music starts.
Cheers, Eric.
« Reply #9 on: January 09, 2008, 01:38:18 am »
Hi Eric,
I notice that you mix the two subjects "last track highlighted" and "Does not work anymore". I didn't change anything to the "last track highlighted" subject (nor did I say so). Thus, I have been working on the "Does not work anymore" only. Ok ?
Of course you are talking about the last track thing, but "no change" cannot be true. Before this did not work (Does not work anymore), and now it does. Hence, now the folder name where the album is in, does not need to be the same as the name of the .cue file.
I don't think this is related since this is about a .wav file, and in the process concerned it is about a .cue file (it doesn't look good this registry entry, and sure it comes from somewhere / some problem). Looking at your description there's not even something going wrong (and the last track thing is no error as such, but just something inconvenient I must solve).
After loading the album I observed no change in the behaviour of XXHE. [...] It does ask me for permission to run ChangeWP.exe
Note that this implies that before it also asked you for permission. Assuming this is correct ... WHAT ?!! swoon so you say that at the start of each track the system asks you whether it's okay to run ChangeWP ?? wacko In fact I can't believe that and maybe this is the first time (with this newly downloded version) only ? But if it's all the time indeed, please read this : Vista Users ... prepare yourselves ... and arrange for you rights. yes
If indeed it is so that the system asks you for permission each time, please copy the message(s !) concerned to me.
At least this shows that you have this outside of Cue Files. scratching Since I can't copy this behaviour, I need data to do so (but please, if your rights weren't arranged for, do that first ! (see before)). So :
Please make a screen copy of explorer, showing the full path to the album concerned, and make a screen copy of the full contents of that folder (showing the .wav files and all that's in there). Also indicate which track you run when this happens.
To speed things up a bit, in parrallel you could email me the folder.jpg from this folder (album) so I can check whether something is just wrong with that image.
Sorry for the nitwitting, but I'm trying to find the culprit ! (on the "Does not work anymore", *not* on the "last track" thing, that's for later).
I hope I'm not too confusing ...
« Reply #10 on: January 09, 2008, 02:15:06 am »
This looks to have solved my problem! Thanks
Eric
« Reply #11 on: January 09, 2008, 04:18:18 pm »
the "does not work anymore" problem never showed up when I play Cue file albums. I am afraid that this was not clear in my initial description. However, when I play an album without Cue files, the "does not work anymore" problem always shows up. And it does so before every track is played.
Cheers, Eric.
« Reply #12 on: January 09, 2008, 06:00:49 pm »
Help !
What shall I do ? the problem never occurs here. Shocked (nor with anybody else I think)
Is it a problem for you to provide those screen copies ?
Leo
« Reply #13 on: January 10, 2008, 09:16:54 am »
Hello Peter,
I have a/the ChangeWP error with wav files. Happens with a single core pc, haven't checked it yet with my duocore laptop yet. With the single core I don't get the cover eather in unattended mode.
If I don't check the unattended box I don't get the error but then probably this program ChangeWP  is not started. It gives the error message with every new wavfile in the playlist. It does not stop the XX playing . At the end of the album I have a lot of errormessages to click away.
The last version of ChangeWP does not make a difference.
I have changes the rights to administrator as explained by you before Peter.
hope this helps you looking for the solution.
Eric
« Reply #14 on: January 11, 2008, 04:46:09 pm »
I am getting the ChangeWP error both in attended and in unattended mode. I will be happy to send screenprints and other debugging aids, however I will be away from my system until January 28.
Enjoy, Eric.
