November 23, 2024, 06:34:46 am *
Author Topic: Not enough space in Playback Drive...  (Read 18832 times)
nik.d
« on: November 27, 2015, 11:56:56 am »
Peter knows already from previous XXHE version(s) and with 2.03 this 'problem' is wider: Whenever I have a file name containing diacritic character
like "ñ" or "ö", perhaps several others and with some characters from local language (Serbian Latin - previously was one character only, now few others)
I get the message "Not enough space on Playback Drive". Playback drive is ImDisk RAM disk of course. Tried to install different ImDisk version, same again.
I'm always installing standard, US language, US keyboard Windows, be it W7-W8-W10. Is anyone else having this playback error?
After clicking away above error message, clicking on next or any other song in playlist, I get another one (both pic attached hblw)
« Reply #1 on: November 27, 2015, 12:00:08 pm »
Not only George, but me too are desperately hoping for someone to respond.
Please don't hesitate, anyone who recognizes this !
Thanks a lot,
« Reply #2 on: November 27, 2015, 12:07:49 pm »
George,
It could be a good thing if you describe what you think what could be all different from everybody else.
Context : If I try your tacks all is fine.
Suggestions :
Operating System which is natively not English but another Lange (like official German which can be bought and which is different from e.g. W8 Pro which can install different languages but which is English in the base).
The selection of another language (in the Pro version) other than the one which was shipped natively.
Whatever locale (country) settings you apply and of which you might recognize people usually won't do that.
(maybe it is about someone else but I recall that you guided me/us to stuff like that for comma/dot notation ?)
Is it actually so that this only goes wrong with IMDisk ? I doubt that ...
A special type of Harddisk. Notice that all what is USB and NAS can already be special.
A special means of formatting (like you could apply EXFAT while NTFS is standard).
And so on.
nik.d
« Reply #3 on: November 27, 2015, 12:18:02 pm »
The only recognizable trace in your questions would be: I use exFAT formating (since this was in (me thinks) in your very short bat script)
All other remains original, perhaps just change Time Zone and run further to installation of NOS1 drivers, SW needed and XXHE of course.
So, exFAT as disk format, yes.
« Reply #4 on: November 27, 2015, 12:28:33 pm »
I am not talking about the Playback Drive re exFAT. Just the music drives ...
nik.d
« Reply #5 on: November 27, 2015, 12:35:00 pm »
No Peter, standard NTFS, 2x2TB WD Red.
Eventually I change date format to dd-mm-yy on "AudoPC". Tried Notherlands locale on it Happy
PC holding the music library is very similar, just changed numbering to EU style (dot for thousand, comma for decimals)
nik.d
« Reply #6 on: November 27, 2015, 12:46:50 pm »
What I can add is tt XXHE on "AudioPC" (or any other app actually) has no write permission to music HDD's (on other PC) so I get errors in XXHE when adding a song to a Library.
« Reply #7 on: November 27, 2015, 01:13:53 pm »
Ahaaaa ...
But you say it as if this was done on purpose by you ?
nik.d
« Reply #8 on: November 27, 2015, 01:20:30 pm »
In sharing options I did granted full access (@ 'workPC') and in reality there's no write allowed through local network. So I continued like that.
« Reply #9 on: November 27, 2015, 01:45:01 pm »
Small language problem perhaps;
Now I still don't know whether you do that on purpose or whether you rather had that solved.
I'm already for 99% convinced this is the problem. I only need to find out "how exactly". But look at that error on the .DAT file ... and didn't I point at that before ...
(puzzle starts to close)
nik.d
« Reply #10 on: November 27, 2015, 03:19:10 pm »
Sorry, had to go out for a while (will have to again, soon)
As said, I left it as it is - no write permission from other PC, in this case no write from "AudioPC" to "WorkPC" where music files reside. This has
to do with my need to re-build XXHE Library since I moved some albums/folders from one to other HDD so XXHE metadata are not correct anymore.
I need to delete all meta info and let XXHE build new main Library file/directory, whatever is needed.
This second error message we did mention in e-mails and it was "the most unexpected error" as you said Happy
And it points to A: disk, RAM HDD of course.
« Reply #11 on: November 27, 2015, 03:50:45 pm »
So is it allowed that this no-write "issue" is going to be solved ?
nik.d
« Reply #12 on: November 27, 2015, 03:58:43 pm »
Yes, I will 'fix' this 'not allowed writing' on HDD's containing music Happy
nik.d
« Reply #13 on: November 27, 2015, 04:04:29 pm »
And I'll make a quick test: I'll copy whole album (seen above) to the partition on 'MusicPC' an try playing the song #4, named "Sueño Latino", a 'problematic' one, directly from AudioPC.
nik.d
« Reply #14 on: November 27, 2015, 04:10:06 pm »
Same error. No space available  unhappy
Edit: above 'MusicPC' should read 'AudioPC'
Page created in 0.113 seconds with 19 queries.
