Tore
« on: November 27, 2015, 09:22:17 am » |
In scandinavia we have the letters æ, ø and å in the alphabet. Many artist have this letters in the artist-name.
To me it looks like it is not posible to search for artist with these letters
Example: Hanne Kolstø
Tore
Phasure Mach III, 12/24 core (Win 14393.0 on RAM-OS / controlled by RDC, / connected directly to music server / XXHighEnd 2.11 / Minimize OS / Engine#4 Adaptive / DB=4096 / Q1=10 / xQ1=15 / Q3,4,5=1 / SFS=0.69 max=140,19 /XTweaks = 35, 10, 0, 0, 0 / Straight Contiguous / Clock Resolution = 15ms / Scheme 3-5 (low/realtime) / Unattended) mobo USB3 port -> Lush^3 -> Phasure NOS1a B75 G3 -> Blaxius^2.5 , Crazy A monoblocs, Avantgarde Duo Omega
« Reply #1 on: November 27, 2015, 09:30:58 am » |
Ah, good point Tore. Well, there's so much more strangenessess in there ... you don't want to know.  Anyway, *can* you find Hanne Kolstø, and if Yes, how ? Maybe normal Hanne Kolsto ? I will try to find a solution but I need some hints. Do / did you also use the normal Tidal Player interface ? How would you find that Artist in there ? Also not possible ? Btw, I already can do more than 2.03a. Look below. Is that her ? I guess so. Peter
Tore
« Reply #2 on: November 27, 2015, 09:44:06 am » |
Yes, it is her
No problem to search her up in Tidal Player
Tore
Tore
« Reply #3 on: December 01, 2015, 09:39:55 am » |
Peter, when i search for Luke Elliot to find the album "Dressed for the Occasion" i just find one track.
No problem in Tidal Player
Tore
« Reply #4 on: December 01, 2015, 10:32:05 am » |
Hi Tore,
It is worse ... I don't know how, but I don't find any albums of Duke Elliot via XXHighEnd. Also, in the Tidal player I find two albums of him (Provisions and Death of a Widow) and not yours.
I know (or can expect) it can be country related, but I can tweak that and it doesn't help.
So I am puzzled ...
If you have more examples, please don't hesitate to bring them forward. Maybe I can start to see a line.
Oh, you can do this for me : If you rightclick on the Album (in the Library Area) and choose Location ... - Explore Original Location, you end up in the \Streams folder if you prepared it already, or otherwise in its main folder (name of the Album). Anyway go to that main folder and find the file TidalDummy.wav.mtt. In there is a number and I like to know it.
Something seems very strange here ...
Tore
« Reply #5 on: December 01, 2015, 10:44:46 am » |
Peter, you need glasses Luke Elliot, not Duke
« Reply #6 on: December 01, 2015, 11:27:12 am » |
Ohh f*ck. Well, I did it right in the Tidal player and in XXHE I applied a typo (and the text lasted for the almost an hour I was looking for the problem). Grrr.
See below. First screenshot is from when you're in Norway. Second one is from when you're in Holland. That is what I see in the Tidal Player as well (can't tweak that or at least not easily). In the Tidal player I see the first two albums you see in the first screenshot.
All of them is again what I call "fakes". So the bottom two are denoted as Singles and the other two are EP's or whatever, but with 5 tracks only and including those singles again. So now you experience what I am saying all the time. 25 million tracks perhaps, but 24.5 million are the same.
The album you seek is not there, but I may wonder whether it exists on CD. It's on LP that I can see, but ...
Tore
« Reply #7 on: December 01, 2015, 12:58:48 pm » |
The album i seek is on Tidal here in norway. It is the only album with him, all the rest is playlists, singles, EP
Tore
« Reply #8 on: December 01, 2015, 01:12:20 pm » |
Tore, OK. Is it possible to give me a screenshot of how it looks like in the Tidal player ? Including Titel and all ?
Say that this is about providing more than we are allowed to see (like you see different stuff than me in XXHighEnd). A bit of tweaking. But I must have examples, and you have one there that I can't see anywhere. But it *is* there, obviously.
Regards and thanks, Peter
PS: I am going to make different border colours for the Singles etc. garbage.
Tore
« Reply #9 on: December 01, 2015, 02:16:44 pm » |
OK, here is what I see in Tidal and xx 2.03
« Reply #10 on: December 01, 2015, 02:53:32 pm » |
Tore, two questions :
1. Can you play that in "HiFi" quality on Tidal ? (look at the "HIFI" characters to the left of the loudspeaker at the bottom-right - when lit it is CD quality, when dimmed MP3). Test it with others too when yuo see it dimmed, because it is also a setting in the player.
2. Can you find a CD of it anywhere ? I can't (LP's yes). But (somehow) I run into many Norwegian pages and they are a bit hard to read.
I now just wonder what this is and I am trying to learn (for the furture and possibilities).
Thank you ... Peter
Tore
« Reply #11 on: December 01, 2015, 03:59:28 pm » |
1. Yes i can play in HIFI quality on Tidal (hifi caracter is not dimmed) I have not found any CD`s that is dimmed 2. http://cdon.eu/music/elliot_luke/dressed_for_the_occasion-34780204 Tore
« Reply #12 on: December 01, 2015, 04:40:27 pm » |
Great. Thank you !
« Reply #13 on: December 03, 2015, 01:06:27 am » |
Here is another one. I am after the "Spirit of Eden" album and can play it in the Tidal player at HiFi quality, but it does not show up in the XXHE search.
« Reply #14 on: December 03, 2015, 10:35:01 am » |
Thank you Anthony.
Here's my list and you can see that we both don't get 'm all.
On with the tweaking ... Peter
