November 24, 2024, 01:46:02 pm *
Author Topic: XXHE 2.03 doesn't show desktop  (Read 26318 times)
« Reply #15 on: December 15, 2015, 02:23:28 pm »
Hmm ... Now I start to be afraid that your W7Shell install did more harm.
Is this in MinOS ? if not, can you test it there ?
And maybe to be 100% sure : do you see anything about Windows Defender in Services (in TaskManager) ? In there it is named WinDefend.
For processes (TaskManager again), look for MsMpEng.
« Reply #16 on: December 15, 2015, 02:28:20 pm »
Question, meanwhile :
Did you set up a normal account (including password !) ?
Or did you set up a Microsoft account (one which requires x capticals, y lower case charcters, a sign and whatever sh*t) ?
The first one is what you'd need, without me knowing what the second one all causes (for the worse).
« Reply #17 on: December 15, 2015, 03:36:26 pm »
It's a normal account with the password being 1234. Actually I can really do away with the password altogether as its a dedicated audio pc with no Internet connection.
« Reply #18 on: December 15, 2015, 03:40:12 pm »
Sorry missed your earlier msg, will check it out once I reach home & get back to you.
« Reply #19 on: December 15, 2015, 03:42:46 pm »
Arvind, to be clear : As password is *required*. Otherwise many things won't work (this is rights related).
Your 1234 is fine. Don't tell it to anyone.
« Reply #20 on: December 15, 2015, 07:51:05 pm »
Don't tell anyone that mine is music Wink
« Reply #21 on: December 15, 2015, 07:56:20 pm »
I am in min OS mode.
Task manager - Services shows WinDefend as stopped.
In processes there is no MsMpEng.
« Reply #22 on: December 16, 2015, 07:57:39 am »
Hi Arvind - My question was whether the problem also occurs when in MinOS. At least that was my intention ... Happy
« Reply #23 on: December 16, 2015, 11:26:25 am »
The problem persists in Min OS as well as in normal OS mode.
« Reply #24 on: December 16, 2015, 12:05:57 pm »
Hello again Arvind,
Before you keep on struggling and struggling ...
I seriously think that your W7Shell install (attempt) is not a good thing. The now "inlog" problem seems too much related to that (this is all Explorer = Shell stuff).
Best is now to reinstall 10074 ...
sorry
« Reply #25 on: December 18, 2015, 02:30:06 pm »
All,
The problem was found (yesterday) in the end by Arvind himself :
It is caused by the Setting "Monitor Off at Unattended".
Maybe no wonder, because I had to eliminated that at rebooting as well (could hang on it).
For the next version, the Monitor Off setting can not be done any more for all Builds of Windows 10 (although only for Build 10074 it was proven that the login screen presents itself after the monitor has been shut off).
« Reply #26 on: December 22, 2015, 09:03:23 am »
Hi Guys,
After the reinstall of W10074 I don't have the problem of the blank screen or logging in after every playback.
Maybe is was a faulty install in the first place or the damage caused by installing W7 shell.
In the end a fresh reinstall, as suggested by Peter, solved all these issues. Monitor off at Unattended also works.
