April 01, 2025, 12:28:17 am *
Author Topic: Getting Specific W10 Builds  (Read 32750 times)
« Reply #15 on: February 14, 2018, 05:45:11 pm »
which means spending two hours to tweak the OS back to its basic form, without the add-ons and default settings.
Hi Joseph,
Not sure whether this is useful for you, but personally I never "tweak" anything in the OS any more (I stopped doing that with Windows 10). However, the Minimized OS of course still does all and more (with Windows 10 than before).
So maybe you have some personal tweaks that help SQ, but then I wouldn't know about them.
Of course there's the installing of things around XXHighEnd. That already could take an hour or more, easily.
tempo
« Reply #16 on: February 14, 2018, 10:35:43 pm »
Sorry, Peter. There's a mistake in my previous posts. The correct version to download from WinISO.net is TH2, standard or single-language, released in November 2015. TH2 is the code for Version 1511, Build 10586.0.
TH1 was the previous release of Version 1507, known as Build 10240, which you don't want. Oy!
~Joseph
PS. Is there some reason why the ability to modify posts disappears so quickly?
XXHighEnd:
Audio System:
« Reply #17 on: February 15, 2018, 08:15:47 am »
Hi Joseph - is it ? Then this is unintentional. But 4 weeks ago some things changed, so I guess there it went wrong. I will look into it.
« Reply #18 on: February 15, 2018, 08:19:57 am »
Jospeh,
Go ahead with editing your post.
Drew65
« Reply #19 on: July 11, 2024, 12:08:15 pm »
Hi Peter and everyone!
I have been searching through the forum and haven't found a working link or app to Win10 14393.0.
Does anyone know where I could source an Iso? I'm setting up a pc and would like to stick with a compatible build version to avoid windows problems.
Thanks
« Reply #20 on: July 14, 2024, 10:09:02 am »
Hi Drew,
The 14393.0 version would be available through me. But it is only available on request and when an Activation Code for XXHighEnd has been obtained first. This is not to get your money, but because this has been the agreement with the person who made it available to me/Phasure myself.
Drew65
« Reply #21 on: July 16, 2024, 04:20:53 pm »
Thank you for responding Peter. A family member found a copy and I'm going to set up the pc soon. If this copy doesn't work I'll ask after I purchase xxhe.
« Reply #22 on: July 17, 2024, 01:08:31 pm »
Hi again Drew,
You can ask what you want, as long as it is for a compatible OS.
This is all about going to Minimized OS, which is not possible without Activation anyway, which will kill the OS when attempted if not compatible.
On an other note, nobody forces you into MinOS, but it is there where the magic happens. This is where the OS for Music Reproduction resides.
Without MinOS and with Unattended there's a glimpse of that too, but way less.
Anyway, no need for an Activated version in order to ask questions - as long as it is on the forum (here).
