April 05, 2025, 03:32:46 pm *
Pages: 1 [2] 3  All
Author Topic: Tidal Login Failed  (Read 39495 times)
« Reply #15 on: December 29, 2015, 11:21:54 am »
Ok. How important must I judge your reference to "the same messages as Tore" ? I mean, can't it be so that you have something not right yet with the Internet communication ?
And I am not sure whether being able to get an Activation Code (which you apparently did over the same PC ??) prooves all.
So what is your "feeling" about the Internet connection itself ?
KnB
« Reply #16 on: December 29, 2015, 11:52:23 am »
I do not know what to look for.. Message I have is 100% same as Tore had... OK was hoping there was something to look for.
Will re install OS as it is an older computer not used in a few years.
Internet connection is working on everything else, can't see anything wrong.
Did try to install 2.04 on my new main server, but got some issue with that as well... Now New attempt with a different PC but still some issue..
I am sure it's me, I very close to give up streaming.
« Reply #17 on: December 29, 2015, 12:26:13 pm »
No, come on !! don't reinstall !
You guys always think that new installs help. And I never know why it would.
FYI and fun : I never ever (ever !) reinstalled any OS.
I know, not completely fair, but it tells that you shouldn't either and rather learn what the problem is.
Tell me quickly, can you stop yourself from reinstalling ?
KnB
« Reply #18 on: December 29, 2015, 12:38:38 pm »
I know, re install is not the way. Not done yet, just installing w7 upgrades
« Reply #19 on: December 29, 2015, 01:46:37 pm »
Ah, good.
I am a bit busy at this moment, but watch your email (soon).
« Reply #20 on: December 30, 2015, 12:32:14 pm »
Solved.
It only now appeared that a part of the Login procedure for Tidal was made for 64 bits only, and the 32 bits OS rejected the Login.
This is now solved in 2.04c, which is at the bottom of the 2.04 download topic.
For Kjell Narve :
You have 2.04d but this only contains additional logging, compared to 2.04c.
Tore
« Reply #21 on: February 26, 2016, 03:24:09 pm »
Hi Peter!
I`m playing with my RAM OS disk and SQ is best ever  smile smile
But i can not play with Tidal, i get the same "Login Failed" message.
Tore
« Reply #22 on: February 26, 2016, 06:06:24 pm »
Hi there Tore !
But do you mean : while normally Internet connected ?
I don't have a problem here - same version. But not via Windows 10. It shouldn't matter, but at least the internet connection is normal (no MinOS and such).
Tore
« Reply #23 on: February 26, 2016, 06:19:11 pm »
Music PC:  W10, no problem to login to Tidal with XX 2.04
Audio PC:  W10, build 10586.62  Login Failed with 10586 base and 10586 RAM
Tore
« Reply #24 on: February 26, 2016, 06:40:38 pm »
Tore, I understand.
What I don't understand is how you should have Internet connection on the Audio PC. And I think you don't (or ?) ...
Put in another way : why would you even like to use Tidal from the Audio PC ?
It should (in my view of course) be on the Music Server PC and the Audio PC uses it from there.
I feel that or you don't understand me, or I don't understand you. yes
Tore
« Reply #25 on: February 26, 2016, 06:47:45 pm »
OK, but how do i use Tidal on Music PC ?
« Reply #26 on: February 27, 2016, 09:03:48 am »
Tore,
The same as how you used it previously ?
Prepare it on the Music Server PC and load it on the Audio PC. The versy same as you do with all your music ...
Tore
« Reply #27 on: February 27, 2016, 09:49:42 am »
when i do that i get error messages:
1.Error opening SettingPreset file
2.Something wrong at initializing Sound Device
Tore
« Reply #28 on: February 27, 2016, 10:48:58 am »
Well, uhm ... I don't hope you are asking me how to install XXHighEnd ?
There must be some huge misunderstanding; You have had all running, including Tidal, and now you don't know how to do it ? then I don't know what to tell or explain !
Anyway ... just do as if that Music Server is your Audio PC. Set it all up as if it were. But leave out the DAC connection and the real playback.
That is all !
Notice that I feel something more is wrong, because I did not see you obtaining a new code for XXHighEnd. So or you had that already (for that Music Server PC, but which seems unlikely) or you forgot it and ... well, I really can't tell.
Maybe you tried to copy the XXHighEnd install from your Audio PC to your Music Server PC. Well, that most certainly will not work. Install it right from the start as usual, that works.
If you don't know what to do, then at least tell me what you did and how that Music Server PC was created. Ok ?
Tore
« Reply #29 on: February 27, 2016, 11:05:14 am »
I was using Tidal before RAM-OS, this is the first time I`m trying with RAM-OS
Music PC is in another room, W10, Build 10240
XX 2.04 is installed, activated with my old code (i got the message "Done")
Tore
Pages: 1 [2] 3  All
